Results 1 to 14 of 14
    Destin FL
    Liked: 730
    Default Reservoir Venting
    Gents:
    From an Apex post:
    Thoughts on venting the reservoir. And if advisable, best location recommendations, please.
    Liked: 556
    I always vent all fluid reservoirs to catch cans and not just to atmosphere or ground. Cleaner and safer.
    Destin FL
    Liked: 730
    Yep.
    Senior Member Spengo's Avatar
    Vancouver, WA
    Liked: 143
    Isn't the back half of the bellhousing the catch can already?
    Liked: 1475
    Quote Originally Posted by Spengo View Post
    Depends on whether it was modified as expanded oil capacity.
    For the most part it worked 'poorly' and was better utilized for expanding the oil tank.
    Vancouver, WA
    Liked: 143
    I thought it was a funny design when I discovered that but who am I to question real racecar engineers?
    Member avakarl's Avatar
    Williamsburg
    I just discovered mine was blocked and capped off from previous owners. Currently just have a hose going into a water bottle mounted at the wing. Im debating on hooking this cavity back up or just upgrading to a little more official external catch can.
    I have also been told that the internal cavity catch sometimes starts to not be very reliable. Which one do you guys recommend?
    Liked: 1699
    the can still needs to be vented, either with a loose hose entry or a dedicated hose off the top and over the side. Otherwise you are going to build pressure in the system.
  13. #9
    Muleshoe, Texas USA
    Liked: 259
    Default Late model VD catch tank
    I have had many late model VD - all using the factory catch tank with no issues at all. Yours is already vented with small filter. I believe all of the ones I have seen also are vented through the four small holes in the top of the casing above the tank - YMMV
    We run a separate catch bottle per GCR for the water but not the oil - we drain the overflow tank after every event and if it doesn't have anything in it we raise our oil level. Typically we run 2-2.5 inches above the input shaft tube.
    If you have leakage problem it is likely not a design issue.
    JM
    Gents:
    From an Apex post:
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
    Orlando Florida 32812
    Liked: 684
    94/95 VD here. The stand up tube on top of the bellhousing that is used for adding oil, or checking oil level via a dip stick when the engine is running, has a tap about half-way up its side for a tube that leads down to a catch can. I guess it could be called a vent. The same catch can has a place in its top for a tiny tube's entry that leads from the tranny
    Destin FL
    Liked: 730
    Stan, Bingo
    Destin FL
    Liked: 730
    Stan:
    I was thinking about this.
    The oil return/fill port housing atop the reservoir also functions to vent fluids to the catch tank. But I think perhaps the aft portion of the reservoir still needs to be vented. Thoughts?
  17. #13
    Liked: 3853
    Stan:
    You would need to provide some serious baffling inside the reservoir to prevent oil from filling the catch tank and starving the engine.
    I would be very cautious before proceeding with a mod like this to prevent a disaster.
  18. #14
    Destin FL
    Liked: 730
    Fellas:
    Much ado about nothing. If it was needed, the designers and engineers would have put one in.
    Thx for the input.
    Stan:
There are currently 7 users browsing this thread. (0 members and 7 guests)
