Page 2 of 2 FirstFirst 12
Results 41 to 63 of 63
  1. #41
    near Athens, GA
    Liked: 1125
    Danny,
    I THOUGHT that was what I was saying ... guess I'm not too good at wording things .. sorry. The FOCUS was on SINGLE CLASS RACING from NEFV.. CCS just added the Radials to it... and moved away from SCCA (mostly) to achieve that same goal (SCR). I have obviously been on the OUTSIDE of both groups, but following closely and in favor of both (same SCR) goals. More VEEs on track in their OWN group/sessions.
  3. #42
    Schellsburg, PA
    Liked: 145
    Danny,
    Steve, Buy a set of radials and come out and play....
  4. #43
    near Athens, GA
    Liked: 1125
    Quote Originally Posted by grapefarmeral View Post
    Working on it !
  6. #44
    NC
    Liked: 443
    As information - a picture of the Yokohama radial mounted to a very beautiful cast aluminum wheel that looks like an original VW slot -
    Just received a set today.
  8. #45
    Burr Ridge, Illinois
    Liked: 350
    BLS,
    What is the actual tire size? When I zoom in, it pixilates too much.
    Glenn
    BLS
  10. #46
    Member HB280ZT's Avatar
    Brandon, Florida
    Liked: 45
    Glenn,
    The tire information is here: https://driverzcup.com/tires-wheels/
    Tires: Yokohama ADVAN A052 195/50R15 110105269 ($871.96 per set)
    R/--
    Harry
    CFR FV#77
  12. #47
    NC
    Liked: 443
    BLS,
    Glenn
    Glenn, as Harry responded the info is at that link...
    The tires are Yokohama Advan A052, 195/50R15. There are multiple wheels now allowed. I chose the Mobelwagen that looks like the original VW slots. They are the required 5.5 inch width and correct backspacing. The picture doesn't do it justice IMO as it is quite nice looking. There are multiple brands of these on the market and I believe they are all from the same chinese factory. As I discovered a year ago when buying wheels for my Jeep, almost all cast wheels are made in China, including some that obscure their manufacturing location.
    Regards,
    Barry
  14. #48
    Member DannyPip's Avatar
    Wallkill NY
    Liked: 66
    Barry, those black Mobelwagen wheels look GOOD!!!
    Where did you get them? I know that Tire Rack is now a distributor. You can get them mounted and balanced and shipped easy peasy. Then you need longer lug bolts or studs and nuts.
    Just so guys know, Mobelwagen Interceptor(what Barry has above) 5 x 205 wheels use ball seat lug nuts/bolts.
    The Cip1.com wheels use 60 degree taper or acorn seat nuts/bolts.
    Make sure you don't mix and match.
    Longer bolts or studs are DEFINITELY needed no matter WHICH aluminum wheel you use, the flanges are WAY thicker than steel.
  15. #49
    near Athens, GA
    Liked: 1125
    Quote Originally Posted by DannyPip View Post
    "Ball seat" not true. I had same concerns but finally determined that the CURRENT VERSION of the Mobelwagen 520 series wheels are actually 60 dgree ACORN attachment hardware. I'm sure that Barry would agree.
    Steve, fv80
  16. #50
    Wallkill NY
    Liked: 66
    Steve, fv80
    MMMM yeah, OK.
    Check the manufacturer's website. They "might" know what they're talking about.
    https://mobelwagen.com/products/520b...SABEgK1E_D_BwE
    It's even highlighted in RED.
    If that's not the case, somebody should tell them to change their website. The ones I have seen made by Mobelwagen over the past few years have used VW group ball seats.
  17. #51
    NC
    Liked: 443
    Danny, I got mine through the local Discount Tire store after looking up the Mobelwagen distributor list. Unfortunately they could not balance them as they don't have the adapter for the spin balance machine. But they mounted them of course, and Yokohama has a dot on the tire that they say should line up with the valve stem location and apparently that helps the balance (no idea why).
    They are ball seat on mine. I suspect that Steve's source are the cone type. I'm guessing they are made in the same factory both ways and Steve's are cone. The CIP1 version is a cone and from the pictures it sure looks like the same wheel.
    And yes, the flange is pretty thick. They really do look nice.
  19. #52
    NC
    Liked: 443
    By the way, those wheels are also available as 4.5 inch width and would beat the replacement steel wheels all to heck and back looks wise.
    I think the lighter steel wheels are near the same as these cast aluminum so it would be nice if the SCCA would allow them for the slick tires...
  21. #53
    NC
    Liked: 443
    Just looking, Empi has a set of studs that are 5mm (3/16") longer than the standard stud. Empi part # 70-2877-0 . Lowest price I found was J-Bugs at $10.95 per set of 5.
  22. #54
    Wallkill NY
    Liked: 66
    These rims all MAY be from the same factory, but I don't think so.
    I have had Vintage 190 wheels on my 550 Spyder since 2017. The guy I bought them from (Greg at Vintage Motorcars Inc.) told me that his wheels are really Mobelwagen but re-boxed and without the logo on the wheel.
    I also have the 3-fifty-6 wheels from Cip1.com on my Vee. They are NOT from the same factory, if you look at them side by side. But I could be wrong.
    By the way, the 550 has 4.5" on the front and 5.5" on the back. Tires are Vredestein Sportrac5(NLA) in 185/65HR15 and 195/60HR15 respevtively. They are 300 treadwear and quite sticky for the street.
ID:	114135   Click image for larger version.
  23. #55
    NC
    Liked: 443
    I started a new thread related to the tires and wheels in order to stop robbing the original
    https://www.apexspeed.com/forums/sho...464#post672464
  24. #56
    Grants Pass, Oregon
    Default FST compatibility with FV
    I would also add (in support of Rich's post) that the original goal of the NEFV group was SINGLE CLASS group/racing. CCS took that another step and made it 'more' affordable as well as SINGLE CLASS racing by adding in a spec street radial. The Radial tire savings AND the Single Class racing aspects are THE ITEMS that got this radial thing going and made it fully successful. Brian's questions of 'how do you KNOW the radials are what made it what it is .. successful.. Well.. we don't KNOW for sure which carried the most weight, but NO ONE can argue with the success of the whole program. For MY money, Single Class racing out weighs the radial cost savings, but the RISKS of racing in multi class groups (for me) vastly outweighs any other aspect. The risks of racing in groups with other race cars that are 30+ MPS faster on the straights is just more risk than I'm interested in taking. I would support the inclusion of FST as well as long as they are scored separately. but that's another discussion for another time.
    On the west coast our race groups in FST and FV have diminished greatly. To race you have to contend with multi class groups where many cars are much faster on the straights and even have wings. This is one of the reasons (there are many) why I stopped running FV after many years of doing so and going to FST because we were initially grouped with Spec Racer Fords. Now with the lack of FST participation I went to FS changing my FST to having a bigger motor and taller 3.88 R&P gear box so that I could better survive out there on the track. The car now can stay with Club Fords on the straights, and I have a "dual class capable car". I am not advocating that others go to FS as I have but you should allow FST to run with the FV groups to have what is essentially similar reasonable speeds to get away from the multi class race groups which have killed our racing on the west coast. I remember 25 car fields at Willow Springs CA when I started racing SCCA with my FV. Mixing us in with Formula Fords and f440 's helped killed us off.
  25. #57
    Lakeside
    Liked: 66
    Default Rims
    Barry:
    Don't forget about the balancing hints on FV.ORG last April
    Dietmar
    Quixote Racing
  27. #58
    NC
    Liked: 443
    Hi Dietmar,
    Just re-read that last night! Thanks for the tips!
    For those interested:
    https://www.formulavee.org/viewtopic.php?t=5914
    Good information
  28. #59
    Londonderry, NH
    Liked: 19
    Default .....thanks ....
    So, we can blame you !!!
    He DID buy a set and WON!!!!
    Old age and treachery can always overcome youth and skill
    John Ferreira
    FV 15
  30. #60
    Brandon, Florida
    Liked: 45
    Default Tires
    Any update on new tires for 2026 and beyond yet?
    R/--
    Harry
    FV#77 CFR
  31. #61
    Liked: 335
    Default Aluminum wheel lug nut seat galling
    Assuming the correct lug nut shape/angle, is there much galling of the wheel lug nut seats when using steel lug nuts?
    I found some beautiful titanium lug nuts with a floating seat/mating surface. While this would eliminate seat galling, you would then be facing stud thread galling.
    Londonderry, NH
    Liked: 19
    Quote Originally Posted by HB280ZT View Post
    R/--
    Harry
    FV#77 CFR
    Received an email from SCCA that they have a response to my CRB proposal regarding making the Challenge Cup Class a Regional - GCR Class ...
    Fast Track - a survey is forthcoming for FV participants...
    John Ferreira
    FV 15
  33. #63
    Londonderry, NH
    Liked: 19
    Interesting solution. A link to where I can purchase a set?
    John Ferreira
    FV 15
There are currently 17 users browsing this thread. (8 members and 9 guests)
  1. ChuckP,
  2. CraigFV14,
  3. Dan Pyanowski,
  4. Dennis Richarson,
  5. pacratt,
  6. scott fairchild,
  7. T-Tom,
  8. Tim.R
