In order to stop "robbing" Brian's thread about inclusion of the radial tire for SCCA events, which has drifted a bit, I will post the data here...
There are now multiple wheels available that are allowed in Challenge Cup and Driverz Cup, all with the same basic 5.5" width x 15" diameter, backspacing and weight at just above minimum.
There are two different wheel lug seats, 1) the original VW ball seat (a radiused surface) and 2) a 60 degree cone seat.
It is important not to mix the two. Damage to the wheel will occur and the wheel will loosen. In particular, if you switch back and forth between original VW style wheels for slicks and the new wheel for radials, be sure you use the right lug nuts...
I purchased Mobelwagen wheels for the radials. They definitely have a ball seat. I already have studs installed in my drums and ball lug nuts. However I am changing from drums to discs so will need new studs.
What I find is the following:
My current studs are a standard 38mm total length, which leave approximately 1.1" sticking up above the surface of the drum.
The picture shows the rear drum mounted to a Mobelwagen wheel and the ball lug nuts are just flush with the stud, a bit short IMO.
The ball lug nuts I have are approximately 0.83 height, and are actually a Honda lug nut (12mm x 1.5), but I believe this is pretty close to standard for the 12x1.5.
Due to the thickness of the Mobelwagen flange, what works for the VW wheel is just short for the thicker flange. Looking at the two pictures included you will see the measure from the back side of each wheel (the contact to the drum face) to the top of the lug nut is approximately 0.2" longer on the Mobelwagen wheel. As a note, because the ball lug nut will wobble I placed a 3/16 plate on top to get my measurements so the numbers shown include that plate. It's the difference that matters.
45mm studs are commonly available that will be perfect for the Mobelwagen. Empi does have another stud even longer available should someone have a different wheel that is even thicker.
None of these measurements apply to the cone seat wheels.
