Results 1 to 8 of 8
    Senior Member Buc01's Avatar
    Moore, OK
    Liked: 75
    Default VD - Suspension Part Search
    I am searching for the lock ring for the front lower wishbone that holds the spherical bearing in place.
    Hard to get a hold of Primus these days, so I wanted to ask APEX members if they may have one.
    Thanks, Aaron.
    Arizona
    Liked: 378
    Shoot Kevin a message and see if this is the same size as FE2 uses. FE2 was originally a Van Diemen chassis, so the part may be the same.
    Kevin Kloepferwww.comprent.net
    (706) 207-5714
    Pittsford, New York
    Liked: 34
    Default Gyrodynamics
    Moore, OK
    Liked: 75
    Thank you, got it ordered.
    Aaron
    Moore, OK
    Liked: 75
    Seems that piece was the wheel bearing retainer, I am searching for the spherical bearing retainer on the Lower A-Arm of not exactly sure what years took the threaded retainer. The A-Arm I had used a circlip.
    If anyone has one, please let me know.
    Thank you,
    Aaron
    Quote Originally Posted by Buc01 View Post
    Aaron
    Vancouver BC
    Liked: 500
    That's for the wheel bearing in the upright...
    ...not the spherical bearing in the front lower wishbone.
    Vancouver BC
    Liked: 500
    Thank you,
    Aaron
    Check with these guys:
    http://www.medinasport.co.uk/MSSpare...te=common/home
    Pittsford, New York
    Liked: 34
    Default My bad!
    Aaron,
    My apologies. I need to learn how to read...
    David Clubine, Britain West Motorsports, might have what you need.
    Craig
