Results 1 to 6 of 6
    UK
    Default WANTED: Hewland MK8 12-11/16" 'long' Input Shaft
    Hi all,
    I'm looking for a Hewland Input Shaft to suit the Mark 8 and 9 type gearboxes with the thicker (Lotus) 3-1/4" engine adapter, the shaft is 7/8" diameter / 20 Spline with a length of 12-11/16 (or 322.3mm). This is a longer type than the more common shaft which typically mates up the xflow engines and the thinner adapter. Would appreciate any help finding one.
    Im UK based.
    Destin FL
    Liked: 731
    Let me check my inventory.
    Quote Originally Posted by Davrian1300 View Post
    Hi all,
    Im UK based.
    UK
    Much appreciated
    Liked: 307
    Default Longer shaft
    Try the lotus 23 sources in the uk like Peter Denty or PDS
    From memory the Lotus 23 is a 3" bellhousing on a twin cam with a 7/8 x 20 clutch spline
    Phil
    UK
    Phil
    Thanks Phil, will do
    UK
    I'm still after one of these if anyone has anything
