Page 14 of 22 FirstFirst ... 4101112131415161718 ... LastLast
Results 521 to 560 of 874
  1. #521
    Liked: 560
    Peter,
    How did Flagtronics facilitate fast pick up of the leader by the pace car?
    Is it because the Flagtronics has the GPS making the leader very easy to locate?
    Yes, the GPS enables all Flagtronics equipped cars to be seen on screen crawl.
    Peter Olivola
    (polivola@gmail.com)
  2. #522
    near Athens, GA
    Liked: 1125
    To elaborate on this... the MAIN control for Flagtronics is in Race Control and there are generally at least 2 screens (provided by SCCA HQ (so far)) that are viewable by anyone in Race Control. The FT "OPERATOR" - a person experienced (hopefully) with the system CAN "FLAG" any single car on the track and that puts a BOX around that car in the display. This is GENERALLY the overall leader, but it is subject to the information and action to/by the FT Operator. In some classes the leader changes OFTEN and it's hard to keep up with all the other things going on. FT does NOT automatically 'find' the LEADER.. that's up to the FT/OP person. IF he/she is correct, (and it IS "mostly" correct), then anyone in RC can immediately find the leader - at least someone CLOSE to the leader. RC can also see WHERE the pace car(s) might be at any given moment (in addition to ambulances, wreckers and other EVs - all ID'd appropriately on the screen).
    There are also 'other conditions' that are controlled by the FT/OP that.. if not done correctly, COULD cause a bit of confusion... THAT is much more of an issue than I ever expected before seeing it in action at NOLA.
    It IS a pretty neat system, but does have it's limitations. It does NOT function in the msec range continuously.. there are sometimes delays depending on LOTS of factors.
    Currently, it's also sometimes QUITE CONFUSING when *ALL* cars are NOT equipped with FT200s.. especially so, when the lead car(s) are NOT so equipped. THAT issue should resolve itself in the not too distant future.
    Fortunately, from a driver viewpoint, MOST of the potential problem areas are ultimately controlled by the FLAG STATIONS .. but again, THAT is also a MANUAL ACTION taken by someone at the corner. Someone handles the actual FLAGS.. presumably someone ELSE (COULD be the same person - not REQUIRED to be someone else - just whoever has the CORNER CONTROLLER BOX) must take action to control the FT indications.
    I wish I could be in RC at Mid Ohio next weekend to see how the SMX sessions go with 'total' FT.
    BLS
  4. #523
    Liked: 560
    Check in with the Race Director early in the weekend and request permission to do just that.
    Peter Olivola
    BLS
  6. #524
    Liked: 271
    There are 'some' instructions on the website. I'd suggest that you contact 'romoman' (poster here). HE has come up with most of the answers and offered help to others in various posts regarding this option.
    I should add.. it's not a 'trivial task'. It CAN BE DONE, but takes a LOT of knowledge and understanding about the protocols involved to actually come up with a FIX .. and most will be quite UNIQUE compared to the others.
    Thank you Steve!
    @CheckeredFlag - I have seen a list somewhere (maybe earlier in this thread) of the AIM systems that can be integrated - I believe mainly the current generation.
  7. #525
    Londonderry, New Hampshire
    Liked: 129
    Yes, current RS3 configured systems can be integrated with the FT200. It depends a little on the ECU connection and logger, but it's mostly able to be done. It's really not too hard. I'm happy to help people out if they shoot me an email to matt@trailbrake.com
  8. #526
    Liked: 1003
    If I read Steve Davis's post correctly, the corner station could be showing one flag and the falgtronics could be showing a different condition because of the independent human operators on both ends. Right??
  9. #527
    Ottawa
    Liked: 1277
    Caveat: I have not worked a Flagtronics event yet.
    There is all kinds of latency built into the existing race control/flagging architecture. Adding Flagtronics will add more (or different) latency.
    There is nothing yet in the GCR to indicate order of precedence.
    Speaking for myself, I would obey the local flag. Especially one that indicates track condition immediately ahead.
    John Nesbitt
    ex-Swift DB-1
  10. #528
    near Athens, GA
    Liked: 1125
    Not really... the RCFT unit can 'send' a command to all cars.. all stations or a specific car ID. The corner stations only control LOCAL (to them) flag conditions.. that OVERRIDE anything RCFT might be commanding... so a BFA issued by sitting chair in RC, would need to 'acted on' by RCFT control, but will still be overridden by any "issued" LOCAL flag commands for any station. At least that's the way it's SUPPOSED to work.
    My mention of the 'responsibility' of the RC operator is more like when all cars leave the grid.. some times it's All yellows, sometimes it's all WHITES.. sometimes it's NOTHING. So the RC operator has to be ACTIVE and ON THE BALL. Say.. it's YELLOW till turn 12 at VIR.. RCFT has to (NEEDS to) set the proper yellow as the cars leave the grid.. and then CLEAR the RCFT command for each station as the last car passes each station. The proper corners will (should be) issuing their matching flag condition... but could change to WAVING or DEBRIS if something happens. RCFT has to CLEAR each flag station as the last car goes by so that when the T12 station yellow is dropped when the FIRST car passes 12.. but all prior stations remain yellow until the LAST car goes by.. each in turn. If RCFT is not active, when the last car has passed all stations (and they have each 'cleared' their local flag condition in turn), RCFT could still be commanding yellow. .. i.e. when the station goes NoFlag (NF), if RC has NOT also gone NF, then the FT200 would revert back to yellow.
    I think that makes sense .... say RC calls for the Pace Car to STAY OUT on a start.. RCFT would immediately go FCY again as would all stations. Or something like that . RCFT can command ALL stations at once, or any one or more at a time.. again possibly overridden by any NON 'no flag' condition at any specific station.
    I might not be describing this perfectly.. I have only seen it in operation once at one track.. the NOLA HST in February.
  11. #529
    Royal Oak, MI
    Liked: 401
    From this weekend's MO Super Tour... Flagtronics implementation etc was definitely imperfect... and yet I was still happy to have it. I got very advance warning of one waving yellow during quali (damp track, not great visibility) on the middle of the back straight for a car spun on track by China Beach. Nice to have a few extra seconds to see what's up when you're over 130mph! (Group 5 - P1, P2, and FE2)
    But there were other incorrect general notifications... local yellow on the front straight for what may have been a flat tow in the pits... disconnect/lag between green and checker laps... sounds from the above that these may be likely a lack of practice/alacrity in the human operator in race control...
    Vaughan Scott
    #77 ITB/HP Porsche 924
    #25 Hidari Firefly P2
    http://www.vaughanscott.com
  13. #530
    Muncie, Indiana
    Liked: 1234
    The SMX class embraced Flagtronics and agreed to require it in all cars at Mid-Ohio last weekend. There were two opportunities to use the Virtual Safety Car (VSC) mode and it worked quite well. In one instance a car was able to be towed and the course cleared in 4 minutes. Had that not been available the session would have been black flagged which, at a minimum, would have cost 10 minutes. There will certainly be some hiccups with the system as our volunteers and racers become familiar with it. I am also sure that there are yet to be discovered inconsistencies in our rules/applications that we will stumble over, but in time I am a believer that this will help to improve the safety and administration of our races.
  15. #531
    Liked: 573
    I wonder if you can "turn in" a gen 1 Flagtronics (my term), for credit towards the next iteration when it comes out.
    If yes, I might get one now. I can see a personal benefit to having one in the car.
    However, I had someone (who is familiar with Flagtronics and Aim integration), suggest I wait until the bugs are worked out before buying one.
    villa park, illinois
    Liked: 164
    I watched race 1 from the keyhole. There were several cars stuck in T1 gravel. All cars came thru the next lap at 35 mph all the way to the back straight where they appeared to accelerate to maybe 50 or 60. I could be wrong but I think they changed the condition from code 35 to double yellow and were picked up by a pace car while cars were towed out. It was interesting
  17. #533
    Muncie, Indiana
    Liked: 1234
    VSC was only used in practice and qualifying in the SMX run group per the briefing that I received last night. I will inquire about the race. Thanks.
  18. #534
    Liked: 164
    Default First impressions
    I like it. I didn't have high expectations but figured I would put in the work to get it on the car. The first session I saw it change to yellow from below the cowl. It was in my periphery but it caught my attention. This happened several times throughout the weekend, sometimes I would scan further down track to see flagger, sometimes I would look down into cockpit at flagtronics. The debris flag was sometimes confusing, as in it took a couple seconds to realize what flag it was, but I am sure I will get used to it. I don't know why I need it counting my time on pit lane.
    I am happy SMX volunteered to experiment with code 35, I think it will be a huge benefit down the line. It should cut down huge chunks of time wasted waiting for cars to catch up to pace car at some tracks. I heard it has allowed Watkins glen to do a "hot pull" for the first time in 15 years.
    Anyway, my mind has been changed, I now think this is a valuable tool for a driver and race control. This doesn't change my opinion of how scca decided to force it upon us too soon, while ignoring member feedback. Hopefully tracks pick it up and spend money for systems and big led flag boards around the track.
  19. The following 6 users liked this post:
  20. #535
    Ferdinand, Indiana
    Liked: 170
    I was one of those flaggers on Friday. Having done IndyCar events, I was familiar with the process and so were some of the others.
    1. Without the light panel like IndyCar, it's easy to forget what your handheld (HH) is set to. So, you gotta take your eyes off the track to look at the HH.
    2. Since the HH is battery powered, the screen dimming to save power was unfortunate. If the battery can't make it the whole day, either put bigger batteries in the unit or provide recharging power packs to the corners.
    3. I wish the LED's for the buttons were bigger, too.
    4. The IndyCar HH has a shoulder strap, keeping both hands free for work like holding a flag or making notes.
    5. I do worry about the flags and the flagtronics disagreeing at stations; practice makes perfect.
    6. RC calling over the net to remind a station of their state or asking about their state, while they're trying to be helpful, is truly helpful. But, I could see where some flaggers could see it come off as bossy (I'm not one of them).
    7. Several of us are still hoping that when the VSC ends, all stations could wave the green signifying the change of state instead of just going dark.
    8. I thought the VSC was a fantastic use of the tech.
    Dean Fehribach
    Co-owner: SCCA C-Spec Mazda 3
  21. The following 4 users liked this post:
  22. #536
    Ferdinand, Indiana
    Liked: 170
    <snip>However, I had someone (who is familiar with Flagtronics and Aim integration), suggest I wait until the bugs are worked out before buying one.
    I want to put it in our FE2, but not before the integration with the Formula wheel. Integration into the car dashes will not only save space, but darn near all of them are much bigger screens. Integration into the Aim Formula Steering Wheel(s) will be a game changer for the formula classes.
    Dean Fehribach
  23. #537
    Liked: 1003
    Default Precedence ON track vs Flagtronics
    According to this BOD emo the on track flags take precedence
    SCCA Fastrack News April 2024 Page 4
    Motion to approve CRB Race Memo RM 24-05 GCR Section 6.1 Flags Addition related to in-
    car flagging.
    Motion - Steve Strickland
    Second - Dayle Frame
    RACING MEMO
    ISSUED: May 9, 2024 NUMBER: RM 24-05
    TO: All Participants
    SUBJECT: GCR Section 6.1 Flags Addition Related to In-Car Flagging
    In GCR section 6.1 Flags, add as follows:
    6.1 FLAGS
    Flags convey the commands or information indicated below. They must be obeyed
    immediately and without question. The content of this section cannot be amended by any
    event Supplemental Regulations unless expressly approved by the Chairman of the Club
    Racing Board, the Chairman of the Executive Stewards and the Head of Road Racing for
    the purpose of incorporating in-car flagging system procedures
    I guess that means for the time being that we need to follow thee flags held by the F&C folks
  24. #538
    Liked: 915
    As it should be.
  26. #539
    South Carolina and wherever the SCCA sends me.
    Liked: 155
    I worked the Flagtronics system at Road Atlanta and VIR and will be heading it up at the Glen next week. I was hoping it would get said in driver's meetings (and I think it did) but if I could impart one piece of info for the folks with the unit:
    "Until there is full adoption and everyone has it, there is no question that flags must take precedence. The signal that everyone can see must be the primary source of flag condition. So - if you have a Flagtronics unit, use it as a digital tap on the shoulder, as in 'hey, I know you're pretty busy right now, but make sure you double check the next corner station.' If at that point you see the flag you got extra warning, and if there isn't a flag you know there has likely been some human error in the digital process."
    When we give the flag meeting, we tell the flaggers that it's cloth first, digital second. Sometimes this means the digital yellow is late/doesn't come, and sometimes it means the digital yellow might stay up longer than was necessary. As flaggers get used to it and we refine processes, this will smooth out I'm sure.
    I'm glad to see the positive comments about folks experience with it, because while I liked the idea I had some skepticism even when I took the controls at Road Atlanta. Once I'd worked with it, I became a much bigger believer. It's not without its situations that need to be refined, but the foundations of how it works within the flagging procedures is phenomenal.
    I'm not sure what the control room to impound proximity is at the Glen, but I'll make every effort I can to be able to answer questions.
    If you run into Greg Amy (Driver Ambassador for the SM/SMX crowd) he has some good working knowledge at this point, and when he sat down with me at Road Atlanta his words were, "I want to learn about it so I can hate it from a position of knowledge instead of ignorance." Within two events he was instrumental in the entire SMX field having it at Mid Ohio.
    Jon K - 1986 Swift DB3/Honda
  28. #540
    Liked: 155
    1. Since the HH is battery powered, the screen dimming to save power was unfortunate. If the battery can't make it the whole day, either put bigger batteries in the unit or provide recharging power packs to the corners.
    2. The IndyCar HH has a shoulder strap, keeping both hands free for work like holding a flag or making notes.
    3. RC calling over the net to remind a station of their state or asking about their state, while they're trying to be helpful, is truly helpful. But, I could see where some flaggers could see it come off as bossy (I'm not one of them).
    4. Several of us are still hoping that when the VSC ends, all stations could wave the green signifying the change of state instead of just going dark.
    Thanks for these notes, the ones I've selected to copy in particular.
    Battery power: We can see all of the battery charge in the control station - and it seems to me there is plenty of charge left at the end of the day. I'll mention this and ask if there is or can be a way to keep the brightness up for those sunny-day situations.
    Shoulder strap: This is a great one. We know that having to wave a flag and then "turn around and find" the corner station unit can cause a delay on each end of the flag condition. Some stations have made a "holder" for them so it can be mounted on a post, but I like the shoulder strap idea. I'll pass that along.
    VSC ending: I personally spoke with Eric Prill about this for nearly an hour yesterday, and then when I spoke with our new Director of Road Racing (Jeff Barrow) later in the afternoon I found that he had been giving it thought as well. Expect to see us continue to refine that process. I'm not sure if it will be green flags at every station, but there will be procedure evolution.
  30. #541
    Royal Oak, MI
    Liked: 401
    I'd have sworn that I saw something in either the Mid-O supps or pre-event communications (email, most likely) reiterating that the flag station shows the flag condition and is the "official" track status (such as for on course conduct, protests etc.), while the Flagtronics display is an advisory. But flag station condition takes precedence/overrides.
    It was certainly clear to me going into the event that this was the case.
    Then again, some are still just now finding out about FIA rain lights, so...
    Vaughan Scott
  32. #542
    Liked: 271
    Found this video for integrating Flagtronics with AIM systems that have a programmable CAN bus input.
    Also got the FT200 dimensions from Flagtronics. It's a lot smaller than I envisioned, so hopefully I can mount it in a visible location and not deal with the AIM integration.
    https://www.youtube.com/live/W4NMQyTPbBY
  34. #543
    Royal Oak, MI
    Liked: 401
    Yeah, I was pleased with how small it was... didn't get around to posting pics of mine installed, but you can see it in my video from Mid-O, tucked under the cowl just fine with a little shelf to hang by...
    Vaughan Scott
  36. #544
    Liked: 1003
    Hhhow much did it help you with anticipating and responding to the flags??
    Curious minds want to know
  37. #545
    Liked: 915
    Why did the FT show checkered flag throughout the carousel on the first lap? That is very concerning. I also couldn't see a yellow flag that corresponded to the LY on that same lap. Is the delay between the actual green flag and the FT showing green intentional to prevent jumped starts?
  38. #546
    near Athens, GA
    Liked: 1125
    I wasn't there .. much less in the car.. BUT.
    FT wasn't showing CHECKER on that first lap - it was just GREEN. (one of the comments I have sent to FT). FT goes GREEN for about 15? seconds at the start and then goes (if no other flags) to a 'reduced green' indication.. which varies for reasons I don't understand.. Some times it's just a green DOT and other times it's a varying 'dot pattern' (like what you saw). I do NOT like that at all and have let them know - some MONTHS ago. Green should show when the GREEN FLAG is waved .. for some relatively short time.. after that NOTHING.. and I mean NOTHING should be shown UNLESS there is a FLAG CONDITION CHANGE that requires driver action. As for the LY on lap 1, I also saw nothing... possibly something in the PITS or boneyard could have triggered it (overlapping 'envelopes of coverage'? Still LOTS of things to 'learn about' for FT and all of us as well).
    The delay in showing the green is also one of the issues I previously pointed out. The START GREEN is MANUALLY triggered MANUALLY by the FTOP in Race Control - normally by WATCHING Start. In this case, that OP was probably in the normal START/FINISH tower coming out of the carousel... but the actual START was mid ways down the back straight at about T5 1/2. Most likely OUT OF VIEW of the main tower. SO the FTOP was probably re-acting to what he was seeing on the video monitors and it took him some 3 seconds to be SURE that the green was out.
    Just guessing
    ... actually.. going back and looking again, that DOES appear to be Black/White Checker rather than GREEN/White in the 1st lap carousel... SO.. I have NO IDEA why on that one.
  39. #547
    Liked: 129
    Did anyone get the DB flag?
  40. #548
    Royal Oak, MI
    Liked: 401
    It did help, BIG time, in one specific case not shown here. I think I mentioned it in a previous post in this thread; during quali, a car had spun just in China Beach, was still parked across track just wide of the track-out point, waving yellow... the Flagtronics gave me warning in the middle of the back straight to anticipate the yellow, which was wonderful coming steaming into that corner at some 135mph or so in iffy/damp conditions with sub-optimal visibility!
    Wasn't a factor in the race, as we ran green (at least, while I was out there).
    The yellow on the front straight, as noted in the comments, was probably an erroneous trigger (human-initiated, to my understanding) for a flat tow active in the pits for another P2 which overheated on the pace lap... blown HG...
    Vaughan Scott
  41. #549
    Liked: 164
    The debris flag was most confusing to me, it was the one that didn't automatically register like green, yellow or red. The first time I got the flag, I caught it out the bottom of my eye, had to look down at the flagtronics to get a better look and I thought, what is the tan color flag? Then I passed the station holding the debris flag. Next lap I got it again and took a better look, it was red dots reading DB over yellow. Without taking more than a brief glance I saw it as solid tan, but at least have an idea of what I am seeing in my peripheral for future reference. It looks like the color blind tests, Glad I eventually passed it.
    Last edited by brian styczynski; 06.05.24 at 10:39 AM. Reason: Spelling autocorrect
  43. #550
    Liked: 155
    I wasn't operating Flagtronics at Mid Ohio, but I was at Road Atlanta, VIR and Watkins Glen Supertour (just this past weekend).
    I'll try to answer these questions:
    Saw this, don't know. There are only two controllers that can signal a checkered flag - the "full course" controller in operations and then the start stand can show a local checker. Because of where this was, I almost wonder if this was a local checker displayed by S/F.
    I wasn't in the tower so this is only speculation but my guess is it was accidentally left it on from the previous race. Accidentally leaving it on should have been seen by the workers in control before the race and changed, so that feels weird to me but it could have happened.
    I didn't see it either, and it wouldn't show a yellow for something on pit road (we don't have a zones for flags on pit road). It could be a couple things - if a car went off and came right back on, the flagger might take a second to "clear" the yellow and you might see the delay in the dropping of the digital flag in that case. (Or, if this was a split start there could be an issue as well because that process is complicated and I could see it creating this issue. I can explain more if needed.)
    Short answer: Yes-ish.
    Longer answer: At Road Atlanta, we watched the start stand and pushed the green light as we saw the starter wave the green the same way a spotter might call, "green green green" over a radio. But, because of the hill there and the fact not everyone had the Flagtronics unit it created a situation where drivers with Flagtronics saw the green light and reacted to it before the Turn 10/11 workers had time to hear the radio call from control AND drop the double yellows.
    So those drivers were not "jumping" the start, but it did create a situation of having a light that could contradict the flags they see. Because of that we've made the choice to listen to the radio instead of watching the flag stand, and then pushing the button as if we were dropping a double yellow so that the flagtronics and all local yellows will "match up." This means a purposeful delay of a couple of seconds and that's what you saw here.
    As I keep saying as we work through this process, more people adopt the unit, etc:
    Use the Flagtronics as an extra reminder to check the next flag station closely. If you see a Flagtronics flag but not a cloth flag, assume either the incident was gone and there was a delay in the flagger pushing the clear button, or there was an initial operator error. From everything I've seen - false flags are operator error and not the system having an issue.
  45. #551
    Liked: 129
    That is an undocumented flag! The documentation all shows the standard debris flag, but the device shows something else. I'm not sure why it was done and have not received an answer about why it's different than the standard.
  46. #552
    Royal Oak, MI
    Liked: 401
    Quote Originally Posted by racerjon1 View Post
    ...I didn't see it either, and it wouldn't show a yellow for something on pit road (we don't have a zones for flags on pit road). It could be a couple things - if a car went off and came right back on, the flagger might take a second to "clear" the yellow and you might see the delay in the dropping of the digital flag in that case. (Or, if this was a split start there could be an issue as well because that process is complicated and I could see it creating this issue. I can explain more if needed.)
    Ah-hah! This was indeed a split start, we were the lead group, I'd have been 3rd or 4th on track overall at this point...
    Vaughan Scott
  47. #553
    Liked: 155
    So, if there wasn't an "off" it would have still been a mistake that you saw it, but the procedure makes it so that we're doing a lot of manipulation during the split starts.. I'll explain.
    Typically:
    FCY is out (and controlled from the "tower") Field does pace lap under FCY, and when the green comes out - we push the "green" button in control and the FCY is replaced by green. All local flags are then controlled by local stations. Easy!
    WIth a Split Start:
    • We start off with FCY, but then ALSO select local yellows at the last few corners (for Mid Ohio, this is probably 1-2-3)
    • When the second pace car gets to the "lights out" then we turn off the FCY, leaving the last few corners local yellow.
    • When the first field gets to the green - we manually select green flags at the first few stations.
    • We then turn off the start stand after the first field takes the green.
    At this point - the first field is getting "green" under local green, but the second pack is still under those local yellows.
    When the second pack takes the green, we then go "full course green" and have one of two options...
    • Option 1 - if everything it clear we can then click a "clear all local flags" button and it clears those local yellows that held the last pack.
    • Option 2 - if there is a local yellow elsewhere for a spin (let's say one of the lead pack spins, or the second pack has a spin) we obviously don't want to "clear all local yellows" so then we'd have to go back and individually clear those last few yellow flags.
    In your case - you might have gotten back to T1 fast enough that those hadn't been cleared. So.. operator "error" in a very complicated situation.
    It's one of the reasons I say "use the Flagtronics as a reminder to double-check the cloth flag."
    Hopefully we get an updated Split Start procedure at some point, but until then - it's the computer screen dance.
  49. #554
    Liked: 915
    Maybe it's hard to see on my screen but I didn't see FCY on Vaughan's FT prior to the green.
    There seems to be potential with FT but it sure looks like there is a lot of work to do before the Runoffs, for both FT and SCCA.
  50. #555
    Liked: 155
    You wouldn't - by the time the video cuts in we would have dropped the FCY and covered the "back half" of the track with local yellows. We drop the FCY when the second pace car gets to "lights out" which is still usually before the first group takes the green.
    That local yellow as residual from the split start might have been what we saw on his display in T1.
    As far as lots of work, I'd put the thing in my car right away. Greg Amy (the class "ambassador" for SM and SMX) came to Road Atlanta hating the idea of Flagronics and said "I want to hate Flagtronics from a place of Education" and within two events lobbied for it to be mandatory in SMX.
    I wish I'd been at Mid Ohio to see what might have gone on in this specific instance with the yellow and the checker, and the notes about the debris flag being hard to identify is an interesting one, but from what I've seen 90% of the issues are with the humans working the buttons and them learning it - not the system itself.
    My personal frustrations have been with the fact not every car has them yet which drives some procedures which can create issues, and individual corner-station struggles whether that's the workload of the folks on the corner being too much to also push a button on the corner unit, not being in the habit of using the corner unit, or reluctance to use the corner unit.
    Those items create the hit-or-miss performance I see us struggle with the most, and the one that I feel is so important as a driver: individual corner consistency.
    The good news for the Runoffs is:
    • More people on corner so more attention being able to be put on the Flagtronics unit.
    • More people working the system in the tower, including Flagtronics personnel I believe. (Ironically, I won't work it at the Runoffs, I'll be full time photographer that week.)
    • All the cars should have it.
    • I don't believe we'll have any split starts or worry about that specific procedure. (I think there has been the occasional split start in other years, but don't believe there are any this year.)
    So, more work to be done - sure - but it's not enough that the system doesn't have tremendous value as it is.
  51. The following members LIKED this post:
  52. #556
    Royal Oak, MI
    Liked: 401
    So yeah, what I see on my video during the boring parts I didn't publish (pace lap), I have the FCY indication (Yellow dash with a "Y" displayed) until we're approaching the Carousel. Then I see a checker. Obviously wasn't watching this while I was driving, because we were FCY and I was right behind a P1 trying not to ass-pack him while warming my tires!
    As we turned onto the front straight, I got the FCY indication again... which changed to a local yellow across the stripe (actual start of race lap 1, but haven't taken the green yet because back straight start.
    As we approach the Bus Stop, the screen goes dark, and that's what you see until the green is dropped.
    Obviously, none of this caught my attention while driving, because I wasn't worried about flag condition, I knew what was up.
    There is a recording of the FG data/feed available for after-the-fact review, right? I'd gotten the impression there was - so if these issues were of serious import, it would be possible to review as needed and see what was actually done with the system...
    I agree, I like the system, I'm more than happy to have it in there, I'm glad I did put it in early to get some time with it, and I'll be happiest when everyone has it.
    Vaughan Scott
  53. #557
    Fredericksburg Va
    Liked: 95
    In my humble opinion,this system is Not Ready for prime time.You can’t count on there not being any split starts and we were told there would be an Available smaller Open wheel unit.
    Tim Minor
  55. #558
    Liked: 164
    Will there be someone at Road America that can look at it? Can you connect thru USB and force it to display a certain flag?
  56. #559
    Royal Oak, MI
    Liked: 401
    Quote Originally Posted by Tim Minor View Post
    Having driven it: I definitely disagree. It's an advisory indicator, supplemental to the actual flag stations and NOT replacing or superceding them.
    It was NOT a distraction or confusion on the pace lap. If you find that to be a challenge, I would be concerned about sharing the track with you - cars around you and flag stations are always more immediate and important than any lights in the cockpit.
    As far as the mandate for it in all cars... I do think more time to roll this out on that (mandatory) level would be appropriate. But my experience with the system over the course of one weekend aligns with Greg Amy's - it is useful, it is valuable, and DOES improve the safety on track in a real, meaningful way. Which of course should be the most important metric on this - with cost/value a close second, and that is IMO at a fairly reasonable point.
    Vaughan Scott
  57. #560
    Liked: 3890
    [QUOTE=Tim Minor;665014...and we were told there would be an Available smaller Open wheel unit.[/QUOTE]
    I'm waiting for the open-wheel version to install one in my Citation - there's no room in a visible area for the original configuration.
  58. The following 2 users liked this post:
There are currently 22 users browsing this thread. (0 members and 22 guests)
