![Quote](images/metro/bw/misc/quote_icon.png)
Originally Posted by
tlracer
From your later pictures, it looks like the belt is rubbing on the hose clip? Can you not simply rotate the clip, so the tightening screw is away from the belt?
All Pinto water pumps are the same height. The body designs and materials vary, but the actual units are all the same dimensions where it's important.
Don't bother with trying to laser check alignment of the pulleys - just put a straight edge (steel rule is perfect!) across the face of one and check from that. You should be able to see if there is an alignment issue.
