Thread: Fe for sale
    Senior Member RacerDave51's Avatar
    Florida
    Liked: 30
    Post Fe for sale
    FE Chassis #45
    Reluctantly, I'm putting my "new" toy up for sale. As often happens, life has gotten in the way of plans.
    History:
    The car is on it’s second 2.3 motor with about 32 weekends on the replacement. Still running strong, so could be run for a while as-is in FE, but it’s obviously a good candidate for FE2 conversion. Originally I planned to run the car in Florida in 2023 in the SARRC series, but things changed.
    The car was serviced in FL by Duane Neyer Motor Sports (the Enterprise CSR) in 2023.
    Features, specs, options:
    It has all of the updates prior to the new engine & transaxle. This includes:
    Blade-type cockpit adjustable front sway bar,
    Penske shocks
    Floating brake disks
    Steering column
    Crush box
    Rear wing uprights
    Gurney flaps
    FIA rain light
    To my knowledge, all other maintenance upgrades and directives prior to engine & transaxle
    Very extensive data logging setup:
    Race-Technology DL-1
    Dash4Pro
    ECU interface
    4 shock position sensors
    Speed sensors
    Front and rear brake pressure sensors
    Steering position sensor
    Fuel pressure
    Oil pressure
    Water temp
    New parts in 2023:
    Schroth Hans approved belts - Dec '28 expiration
    Battery (Pegasus)
    Front rotors
    Fire Bottle
    All master cylinders replaced and system flush
    Services done by DNMS:
    Oil and filter
    Trans serviced: new gears; actuator spring; shift cable
    Aligned and setup
    2024 tech inspection
    Pit Equipment:
    Transport wheels / tires
    Setup bars
    transaxle assembly stick
    Trilobe joint lubing tool
    Setup notes for many SEDiv tracks
    Misc. consumables
    Spares:
    4 sets of wheels (1 set rains)
    1 wing upright
    ...and whatever I'm forgetting
    Asking price: $25k - Reasonable offers welcomed
    Photos upon text request
    David
    Text or call: 931-797-2426
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Djorgy20
