Results 1 to 5 of 5
    DENVER, CO
    Default Lots More Vee Parts for Sale
    I have found a lot more formula vee parts.
    8 used front wheel ball bearings- inner $30 ea
    1 new front wheel ball bearing- inner $40
    10 used front wheel ball bearings outer $30
    1 new front wheel ball bearing - outer $40
    5 used steering boxes- German $50 All Sold
    1 roller bearing front beam $120 Sold
    2 bushing bearing front beam $80
    8 spring packs $35
    10 upper front beam trailing arms $20
    10 lower front beam trailing arms $25
    8 used front brake drums- German $25
    22 used front backing plates $15 All Sold
    15 used rear backing plates $15
    7 used complete rear axle tubes $45 Sold
    4 used bare axle tubes- no casting or side plate $35 Sold
    14 used tranny steel side plate covers $10
    15 used rear axles $45
    5 Ball Bearing Pinion Bearings $70 ea. Sold
    Shipping costs are extra from Denver 80110.
    Update List 11/17/23
    Member GrahamLoughead35's Avatar
    Carmel, IN
    Liked: 35
    Is the roller front beam new or used?
    Graham Loughead FV #35
    Formula Vee Hall of Fame Founder
    Liked: 339
    Do they even make new roller beams?
    DENVER, CO
    Quote Originally Posted by GrahamLoughead35 View Post
    It is not new. They do make new beams and they cost $250 without any bearing or bushings installed. The bearing and bushing will cost you another $229 for a total of $478.
    I have a brand-new beam that I would be willing to sell for $120. It has no bushings, and it is set up for all bushings. You would have to ream out the ends to be able to install the roller bearing. I have new roller bearings (old/new stock) that will sell for $25 ea.
    The used roller bearing beam that I am selling for $120 is a great deal when you consider all of the above.
    DENVER, CO
    Default Parts
    Quote Originally Posted by VISTARACER View Post
    8 spring packs $35
    Update List 10/17/23
    Bumped with Updates
