SOLD
For sale my 2004 Stohr WF1 “Rocket” as a roller. (deposit in hand for car)
Excellent BM class SCCA autocross record, with 2nd in class at 2021 Solo Nationals, 17th overall PAX out of 1200+ entrants. Solid track runner that could be competitive in P1 with the right motor. Currently is without a motor after a rod came apart during my last track day at Area 27 June 2023. Motor was a 2005-6 “K6” GSXR 1000 - these are available for $2-3k, but even better would be an upgrade to a late model BMW, Kawasaki, or Suzuki power plant. I’ve done a ton of updates and improvements to this car over the years, but I’m retiring out of the country and am in the process of liquidating everything. Also available is my 2003 22’ ATC custom aluminum gooseneck trailer for $14000
Package deal for both with delivery option possible.
Onboard Area 27 with Mark driving Fall 2022
https://youtu.be/DnfE8cs7wxg
Phil
Day phone (Till end of December 2023) 36o 74o 4472
email: cmodgr00t@gmail.com ("o" not "0")
2004 Stohr WF1 Sports Racer
SCCA roll bar stamp 61-924 (no log book)
Body & Spar Updated to WF1 spec 2014 by Dauntless
HRP/Zebulon Front Diffuser/Splitter (2022)
Stohr WF1 P1 floor
HRP Primary Element P1 Carbon Rear Wing Assembly
Stohr WF1 2nd gen CF body and fenders
Currently finished in CF “look” vinyl to hide repairs
Dauntless dive planes (not mounted)
CF Side splitters (“ankle cutters”)
Chassis and spar bracing additions to engine bay and spar
Updated rear a-arm clevis mounts
Updated harness bar for Hans device
Schroth harness (2024 expiry)
New fuel fill hose (2023)
Taylor diff
Currently configured for K6 GSXR1000
Wet sump configuration
Stock ECU reflashed by George Dean
K6 wiring harness rewired for MME Pneumatic Gear control
Note: needs aftermarket gear position sensor to work correctly
MME pneumatic paddle shift system (Spring 2023)
With onboard compressor
AIM MXM GPS Dash (2022)
AIM sensors (Oil temp, Oil Press, Brake Press)
New chassis wiring harness by Mark Uhlmann (2023)
CF switch panel (2023)
Sparco CF 270mm Wheel (2023) with lockout button for shifter and spare unused button
Shocks (rebuilt 2021)
Front Ohlins ST44 shocks 2” perches
Rear Ohlins ST44 shocks 2.25” perches
Springs
Front:
2” ID x 4” L x 550lb/in (Qty 2)
2” ID x 5” L x 700lb/in (Qty 2)
2” ID x 4” L x 900lb/in (Qty 2)
2” ID x 6” L x 1400lb/in (Qty 2)
2” ID x 6” L x 1600lb/in (Qty 2)
Rear:
2.25” ID x 4” L x 700lb/in (Qty 2)
2.25” ID x 4” L x 800lb/in (Qty 2)
2.25” ID x 4” L x 1200lb/in (Qty 2)
2.25” x 5” L x 900lb/in (Qty 2)
2.25” x 5” L x 1150lb/in (Qty 2)
Updated calipers and master cylinders (Winter 2022)
Front
Calipers: Wilwood 4 piston, 1.75 Dynapro 120-9693
Pads: 15A-9835K - Wilwood PolyMatrix A Compound Brake Pads
Rear
Calipers: Wilwood 4 piston, 1.38, Dynapro 120-9703
Master Cylinders are
Tilton 75 7/8" (.875) Bore Front
Tilton 75 3/4" (.75) bore Rear
Cockpit adjustable balance bar
New front braided lines 2023
New hardlines front to rear for clutch and brakes 2023
Wheels
2 sets - With Slicks Mounted
Shaped inner Kodiak (no label)
F: 13 x 9
Also have shells for 8” setup for both sets
R: 13 x 10.5
1 set - Pirelli Wets Mounted
Flat inner Kodiak (labeled)
F: 13 x 8
R: 13 x 10.5
Multiple sets of one session Goodyear slicks
Mounted slicks have lots of wear left
Misc
Front and Rear Alignment bars
Specialty diff socket
Misc calipers and more
Includes quick lift jacks (and modified motorcycle lift if wanted)
