SOLD - Built by Autodynamics circa 1968. Restored/painted, new tires/spare 2022. New aluminum ramps '23. Original designed rack for trailer spare plus 4 race wheels. $975.00 Located eastern PA. Call Cel; 954 294 6962.
Do you know how much the trailer weighs by chance?
Graham Loughead FV #35
Formula Vee Hall of Fame Founder
Thanks Paul. I ask because I would be towing with a Toyota Rav4 with a towing capacity at 1500. However, if you are towing with a sedan as show in the picture it shouldn't be too much of a problem.
Do you know the dimensions of the trailer? I have a Vortech and a golf cart & am not sure which I will tow yet so I want to make sure I would able to either option.
My 2-cents,
I think the 1,000 lbs. estimate is too much. Long ago I had an open trailer made from welded up steel angle iron, open center, 6' X 12', drop axle, leaf spring, steel 14" wheels, beefy fully boxed fenders, 2" X 8" X 8' wood ramps and a full width front tire rack... just under 800lbs.
My guess is this trailer's weight is 625 - 700 lbs. max.
Craig
