Results 1 to 5 of 5
    San Jose Ca
    Liked: 87
    Default Push/Pull switches
    Hello All,
    I have a push/pull ignition switch that I need to replace, what are your recommendations for a replacement.
    Voltage
    the amount of amp's
    type
    model
    Thank you
    Ben
    Liked: 1475
    Is it an aircraft circuit breaker?
    https://www.aircraftspruce.com/catal...on7274_2_3.php
    or like one of these:
    https://www.mcmaster.com/products/el...pull-switches/
    Does it need to be push-pull ?
    San Jose Ca
    Liked: 87
    I
    Like that one from mcmaster.com. I see it's only 10 amp's that's one of things i needed to know.
    No, it does need to be a push/pull, something better?
    Ben
    Liked: 991
    Check your wiring but I think 10 AMPS is more than adequate for just about any application we might encounter other than a master switch
    Torrington CT
    Liked: 620
    This is the switch that was used on Citation FV as a master switch and I am using it on my FV as a ignition power switch.
    https://shop.advanceautoparts.com/we...0051&langId=-1
    There are cheaper versions and many auto parts stores do stock them, but I would carry a spare, or easy to replace with a toggle switch.
    ChrisZ
