    Member Schmaz356's Avatar
    Richland, Michigan
    Default Release Bearing for Lotus 51 with Renault Gearbox
    I have a Lotus 51 Formula Ford that has retained its original style Renault gearbox. I found that the replaceable release bearing is bad. It turns but it’s very hard. I have been looking for a replacement but am having trouble locating one. I also cannot see any manufacturer’s name or number on the piece. The inner diameter is 35mm and the outer diameter is 66mm. If any knows where I could buy a new one it would be appreciated. Thanks.
    Lincoln NE
    something like this with a sleeve to correct the ID?
    https://www.burtonpower.com/clutch-r...15-hd3259.html
    Derbyshire, United Kingdom
    Liked: 357
    HD3257 - Ford Cortina Mk1, Anglia 105E
    OD: 66.0mm
    Thickness: 15.75mm
