Page 5 of 19 FirstFirst 12345678915 ... LastLast
Results 161 to 200 of 753
  1. #161
    Royal Oak, MI
    Liked: 398
    1. The Tech Inspector corps is already overworked and understaffed. Their ability to handle another test may be too much to ask. [/QUOTE]
    Dayle - thanks for joining the discussion. Generally, I appreciate your representation on the board, as my rep, but you are 100% wrong on this change request. PLEASE listen to us and understand where we are coming from on this, respect our opinions and experience in the open wheel world.
    As noted by others already - the above assertion is definitely an extreme interpretation with its base as an assumption of a compliance check after every race, which is very much incorrect.
    Hell, you should leave it in there just so that tech has SOMETHING to check on our prototypes!!! 80% of the time, if my car is even inspected at impound, it's something inane like a data box plate, rain light, etc. The only place I've even ever been called for fuel has been the Runoffs!
    Quote Originally Posted by Dayle Frame View Post
    2. Regions are already getting blowback on the cost of putting on events. Getting qualified personnel and hardware to administer yet another test in the field may prove costly adding to these financial pressures. For example, the gear to record sound readings is expensive to purchase initially. It needs to be calibrated each year costs so the cost of ownership is also high.
    It has already been clearly illustrated that this is neither technically challenging nor expensive, neither in cost of aquisition nor ownership. I've already volunteered to buy a gauge out of pocket for DETR. Why do you cling to this fallacious argument?
    3. We have only to remember back a few months to the 2022 Runoffs when EFFECTIVE rain lights were extremely important. When driving in those conditions, do you really want your fellow driver to have an substandard light as you approach them? Or do you want to trust he/she sees yours?
    This statement also seems to make two invalid assertions. One, that there is a rain light that can be seen through any and all water levels. I think I already provided the video proof that even the FIA light on Mike's car (the requester) is drowned out in far less than downpour conditions. There is no silver bullet that provides 100% visibility/vehicle detection. We'd need radar for that. Which exists, for cars, but we don't need to go there - because of the second incorrect assertion.
    Two, this asserts that a driver will have NO idea there's another car ahead until they see the light. As already pointed out earlier in the thread - the spray tells you there's a car up there, the light tells you WHERE it is.
    After that - the responsibility for making a safe pass is on the PASSER and the passee.
    Having a spec from the FIA (or whomever) only makes sense. We don't ask our Tech Inspectors to test helmets or belts.....just look at the appropriate decal.
    There's a lot of things on our cars that don't require a sticker to pass tech. Lazy assertion.
    Like John said, if a few of you smart folks can come up with a better mousetrap, we're all ears. We have until 1/1/24 to figure this out.
    Dayle Frame
    ACTUALLY NO. We have as long as we want, if you don't force this rule down our throats in a rushed manner. That deadline is entirely of your own making, and we do not accept it.
    Vaughan Scott
    #77 ITB/HP Porsche 924
    #25 Hidari Firefly P2
    http://www.vaughanscott.com
  2. #162
    Liked: 991
    Well put 924 racr!!!!
  3. #163
    Liked: 332
    The CRB wants a better rain light without SCCA setting/developing a standard. Tech is not relevant without a standard to test.
    So why don't all you guys get together and develop a standard. Do you guys even know where to start? Exactly where do you set the lumens vs cost level/point? What and where do you get the data to determine such a point?
    All you guys are doing is whining about the cost. Provide a cheaper standard that has some data to back it up. Something the CRB can vote on.
    The CRB is not going to be swayed by cost whining when they have a FIA standard to hang their hat on.
  5. #164
    Liked: 1682
    I made a start in post 145. 800 lumens is equivalent to what sedans are allowed to run.
  6. #165
    Member HB280ZT's Avatar
    Brandon, Florida
    Liked: 45
    I just contacted the manufacture ACT Inc. of the Afterburner rain light
    FIA approved
    18 high-intensity red LEDs
    Light output:
    5800 mcd / LED at 30 degree viewing angle (this is per LED)
    Highest light output available, exceeds 900,000mcd in light meter tests
    That is all from the Installation documentation. I person that I talked with at ACT is looking into providing me more information on the light and they said they will email me the information. They also said that when the light is in flashing mode it is even brighter then just on.
    R/--
    Harry
    FV#77
  7. The following 4 users liked this post:
  8. #166
    Member TimWalsh's Avatar
    Bloomington MN
    Liked: 6
    Default FIA Rain light
    The Afterburner Rain Light is FIA approved homologation certificate ACCUS/ RWL/ 08.07.08.
    We also have a new focused beam rain light which is extremely bright. This is at FIA getting approved.
    Tim Walsh
    ACT Inc.
  9. The following 5 users liked this post:
  10. #167
    Liked: 1682
    what would the afterburner lights cost without the FIA sticker?
    I often buy MS bolts and and sheet metal without the certs....
  11. #168
    Bloomington MN
    Liked: 6
    Default FIA Rain Light
    Price is the same.
  12. #169
    Liked: 900
    But will it be on the FIA Technical List #76?
  14. #170
    Ferdinand, Indiana
    Liked: 164
    Assuming the need for a change is determined to be (I argue there isn't one), then whatever sticker the Afterburner has on it, that's what the SCCA needs in the GCR.
    Dean Fehribach
    Co-owner: SCCA C-Spec Mazda 3
  15. #171
    cranberry, pennsylvania
    Liked: 59
    Default Rain light
    i have 40 yes 40 lights on my rain light, it is round and led but i it does not flash,
    it works find and also works as a brake light when i have the P2 kit on it, does it need to flash???
  16. #172
    Ferdinand, Indiana
    Liked: 164
    Quote Originally Posted by david oleary View Post
    David, I'm not convinced a change is warranted. However, others here have advocated we come up with a recommendation in case the CRB and BoD force this unnecessary change. The Pegasus Afterburner has my vote instead of a $200 FIA overpriced attachment, should we be forced to a change.
    Dean Fehribach
  18. #173
    Liked: 572
    Or their "Ultimate":
    https://www.pegasusautoracing.com/pr...asp?RecID=2340
    It's $53, and a "cluster of 50 very bright red steady-burning LED's".
    It's hard (for me) to imagine a scenario where this light wouldn't prevent an accident just as well as the expensive ones. But, that's probably because we used trailer clearance lights for the first few decades of my racing.
  19. #174
    Liked: 1469
    I did write a letter and believe I mentioned the following, but why does the onus need to be on tech at an event? Add this to the annual inspection.
    There are 2 issues here:
    1. The cost of these specific rain lights.
    2. The verification of compliance.
    One of my concerns is once we "mount/package" one of these lights on a car, the likelihood the "sticker" will be visible for inspection is slim to none - unlike belts, fire systems, etc.
    Basically it should be done ONCE and noted in the Log Book. It never 'expires' .
    I do not want to show up for inspection having someone fiddling with a light meter and telling me my weekend is done because they didn't measure it right.
    If the objective is to make less expensive lights compliant, this is something maybe 'Enterprises' should be doing for the club. One meter, send them a light and they test and approve brands and models etc. Your light not on the list? Send it for testing - added to the list if it passes. Vendors can send lights for testing as well - "Enterprises Approved"
  20. The following 6 users liked this post:
  21. #175
    Liked: 900
    This is a fantastic idea. Devil's advocate: I could see Enterprises being inundated with hundreds of different LED lights. However, they can manage it by setting reasonable turnaround expectations, i.e. don't expect to send a light in a couple weeks before your next event and get approval in time. I would even be willing to pay a small fee plus shipping both ways if it means I can save $100 or more on a rain light. We could develop a lengthy approved list in a short period of time, possibly as a focused project at the end of the season.
    Another suggestion is to rewrite the rule so that the compliant rain light is only required if rain is imminent. It's moot to have a tech inspector check (and possibly fail) a rain light if there is no rain in the forecast. Some people might even remove the rain light (especially if they paid $200+) so that it isn't subjected to a season's worth of vibration and possible crash damage, and only install it when needed. Rally cars often remove their auxiliary lights during daytime stages for this very reason.
  22. The following 3 users liked this post:
  23. #176
    Liked: 991
    Default Candela to lumens ???
    See this link https://www.rapidtables.com/calc/lig...alculator.html
    I came up with 3600 candela because IIRC, that was the stated output on one of the FIA approved lights at a +/- 24 deg angle of incidence in one direction and +/- 4 deg in the other. Looking further %00 lumens is not very bright.
    If I am mistaken, someone please correct me. The point I am attempting to make is that it seems that the FIA standard is not very strict and bright??
  24. #177
    Liked: 1469
    A Vendor could send in 1 each of the lights they sell (and get priority turnaround).
    Enterprises could focus on the 10 most popular first - and probably should to confirm their testing process.
    I suspect the list will hit 20 and slow drastically. But it gives people an option.
  25. #178
    Liked: 4371
    This is a completely artificial crisis with artificial timeline.
    If you specify that "x" number of LEDs are functional then you can have safe lights that require no meters to monitor. The same test procedure could be used as now, but instead of checking for a red glow, the inspector would just make sure "x" or more LEDs were on.
    I would suggest that "X" would be the number of LEDs that are on a medium-grade marker light as used on trailers;.
    How much more KISS could we make it than counting LEDs?
  26. The following 4 users liked this post:
  27. #179
    Orlando Florida 32812
    Liked: 683
    So "X" rain light (that had FIA cert the other year) costs $100...............and "Z" rain light (that is FIA newer) is $200...........and they're both way brighter than a Miata brake light ....and they both have a whatever year sticker from FIA......I vote for allowing either X or Z because of the cost difference of one night in a nice Hotel near the track...........and I don't hear anyone as part of this thread saying they're lately having to sleep in an unairconditioned trailer at the track to save money on lodging
    The real deal is how the average human visual system works..............and it's this > when one views a display of two different lights to the right or left of straight ahead and one is flashing, the eye will look generally at the flashing light first. FACT. Sure some of you will argue > exception to the rule !! ........and you may surely be occasionally right..................occasionally...........and even then, that individual will only some of the time look at the steady light first. So go ahead, please move air in and out of your lungs and argue with me but this is visual physiology.....known fact for decades.
    The considerations must be > does the light flash? ....in addition to how bright the light is. If both considerations are not part of a new rule, then the rule is essentially obsolete to begin with by ignoring biology.
    If an Afterburner doesn't flash, the light is living in the past far enough that any new rule proposed fails to properly address the properties of the human visual system. If one can render an Afterburner light to flash at roughly 4Hz, then I'm all for that and not just some $200 light.........because it (older FIA - read > Afterburner) which then flashes and is way brighter than some Miata light
    BLS
  29. #180
    Liked: 1469
    The Afterburner - old FIA approved - does flash.
  31. #181
    Late Braking Member
    Danville, California
    Liked: 269
    Default EYE might be on to something
    The CRB,BOD, et al are looking for alternate wording for GCR 9.3.32.B.2.
    How about specifying that the rain light on a formula or prototype (sports racers but not a SRFx) must be red and flash. Seems to match human perception triggers.
    How about this for 9.3.32.B.2
    A red taillight that flashes at a rate between 4Hz and 8Hz (flashes per second) is
    required on all Formula (open wheel) and Sports Racing cars. This light shall be mounted approximately
    on the centerline of the car. Light assemblies are considered one light for the purposes of
    this rule, irrespective of the number of individual lamps the assembly may contain.
    This doesn't require Tech to do anything new other than recognizing a flashing red light (I believe 99% of us are capable of doing this). This eliminates the use of trailer marker lights which seems to be hot button for some AND allows some bicycle rear lights to be used which a sh!tload of racers did in the rain at Thunderhill in April.
    All those in favor say EYE.
  32. The following 3 users liked this post:
  33. #182
    Duncannon, PA
    Liked: 343
    Quote Originally Posted by TimWalsh View Post
    Tim Walsh
    ACT Inc.
    Thanks for replying and getting involved with this issue. I have been using your rain light on my FV since you introduced them many years ago. I did actually by 10 from you and sold them to my fellow competitors since if they saw it in operation they were immediately impressed.
    Ed
  34. #183
    Torrington CT
    Liked: 618
    Found this in the UK version of the GCR
    Red Warning Light
    5.1. A rearward facing red warning light of a minimum of 21
    watts, with surface area minimum 20cm2, maximum 40cm2, or
    of 21 watts with a surface area minimum of 50cm2 and with
    lens and reflector to EU Standards, must be located within
    10cm of the centre line of the vehicle and be clearly visible
    from the rear. Vehicles fitted with full width bodywork may
    alternatively use two lights equally located about the vehicle
    centre line. An alternative light unit of equal or enhanced
    constant luminosity or LED lights that are either homologated
    by the FIA or comply with relevant EU Regulations may be used.
    5.2. The warning light must be switched on when visibility
    conditions are reduced, or as detailed within championship
    and/or event regulations, or when so instructed by the Clerk of
    the Course.
    They still dance around the watts when we need candlepower or luminosity.
    I give kudos to the Afterburner guys to get FIA approval - but worry about the cost of certification...
    Still think self certification is better that Enterprise certification, but at least that keeps it in the Club. "SCCA Approved" Could be a new profit stream (did I really say that???? )
    ChrisZ
    BTW - I wrote my letter - has everyone else?
  36. #184
    near Athens, GA
    Liked: 1099
    Red Warning Light
    the Course.
    ChrisZ
    That sounds pretty 'doable' to me ... simple enough to WORK.. and complex enough to suit most lawyers.. and no FIA CERTIFICATION required... .
    FYI.. ANY LED light can be made to flash (if it doesn't /can't already. Just google 'LED LIGHT FLASHER' .. all day long and reasonably cheep. The 'flashing part' of my Afterburner died 2 years ago.. I installed one of these 'flashers' for about 10 bux and it works EXACTLY as the original AB did when I got it.
  38. #185
    Liked: 59
    Default flashing light
    I agree with Steve, I have a 40 bulb round LED light that already works as a rain light and a P2 brake light so i can just splice a flasher in the rain light side and that should work i think???
  40. #186
    Liked: 991
    Default post 178
    What Greg said is the most sensible suggestion I have heard or thought of. I say let's push that
  41. #187
    NC
    Liked: 411
    All LED's are not the same.
  42. #188
    Liked: 4371
    What does that matter?
    We are not rocket scientists. We are racers putting lights on our cars to help with visibility in the rain.
    This is a completely artificial crisis which needs to be resolved with a simple common sense solution.
  43. The following 5 users liked this post:
  44. #189
    Late Braking Member
    Liked: 269
    This is the statement I will include in my letter.
    We DON'T need another sanctioning body to validate a rain light.
    We DON'T need Enterprises to validate and/or sell complying rain lights.
    We DON'T need any light output measurements because they will be subjective.
    Light needs to be red.
    Light needs to flash.
    How much simpler common sense can it be?
    No rocket surgery is required.
  46. #190
    Liked: 4371
    Why does the light need to flash?
    When I wire in my afterburner lights, I choose the non-flashing option.
  47. The following 2 users liked this post:
  48. #191
    Late Braking Member
    Liked: 269
    2 reasons:
    A brake light is used on a sports racer, so solid red = brakes, flashing red = rain.
    Post #179, human eye is drawn to flashing.
    Liked: 900
    2 reasons:
    P1 and P2 do not require brake lights.
  50. The following 2 users liked this post:
  51. #193
    Liked: 4371
    You can argue either way. A brake light goes off and on with application. Therefore a steady light would indicate a rain light.
    The commentary in 179 does not apply in this context. I would hope the race driver is looking directly ahead for any indication of a vehicle. As previously pointed out, in order for there to be spray, we know a car is there. Whether a light is flashing or not has little or no relevance in this context. The flashing may actually delay the reaction of a following driver.
  52. #194
    Ferdinand, Indiana
    Liked: 164
    Default "It's a trap!" - Admiral Akbar
    Here's the trap we've fallen into:
    1. Someone writes a letter to the CRB stating we need to change our rain lights.
    2. The CRB agrees, chooses an over-the-top FiA certified solution for ill-thought-out reasons already mentioned in this thread.
    3. The CRB/BoD publishes the recommended technical rule change to the GCR saying it will take effect 1/1/2024.
    4. The CRB/BoD tell members through questionable channels to write letters if the change isn't wanted; the decision has already been made, friends. We are being told to try stop it through a letter-writing campaign.
    5. We here discuss options to avoid a $200 FiA certified light because we're told by those same bureaucrats that if we don't like their wording and gizmo, we should recommend something else through said letter-writing campaign.
    6. We here come up with a gizmo and wording then write their letters.
    7. The CRB and BoD would supposedly then accept our lower-cost, certified gizmo and publish that in the GCR for 2024.
    8. We have tacitly accepted their premise that a rule change is needed, when it hasn't really been shown that it is needed.
    9. The trap closes and we're in it. Check and mate.
    Dean Fehribach
  53. The following members LIKED this post:
  54. #195
    Prescott, AZ
    Liked: 202
    193 posts about a light. No wonder SCCA is in trouble.
    If it’s raining that hard I’ll be in the trailer saving my car.
  55. The following 2 users liked this post:
  56. #196
    Liked: 529
    Fastrack is a questionable channel?
    Your trap analogy fails for the simple reason that the same process killed changes to the Runoffs this year.
    Error 404 Outrage Not Justified
    Peter Olivola
    (polivola@gmail.com)
  57. #197
    Liked: 4371
    I think, as paying SCCA customers, we all should be outraged that the club continues to operate with a business model created in the 1960s. That includes fast track and letter writing. That is the trap.
    That this artificial crisis has created such discussion is humorous.
  58. #198
    Ferdinand, Indiana
    Liked: 164
    For clarity, I've made bold Point #8 that defines the trap. It's not about the notification methodology or their methodology for counter-proposals.
    Dean Fehribach
  59. #199
    Liked: 529
    Unlike the Runoffs format change proposal, which was rescinded, you have six months to convince the BoD.
    Still no outrage justification detected.
    Peter Olivola
  60. #200
    Liked: 991
    But Peter, Just how convinceable do you think they will really be. This is proposed as a safety issue, correct? If that is the case the BOD would be hard pressed to vote it down.
    I think what will make it into a more sensible proposal is if the CRB modifies their proposal.
    In AOBA powerboat racing, when a rules change was proposed, every registered owner of an affected boat got a ballot in the mail so that there was control by those spending t6he money.
    Not sure how this would work with SCCA because of the size and the fact that car owners are not registered.
There are currently 169 users browsing this thread. (0 members and 169 guests)
