Results 1 to 8 of 8
    Oshawa, Canada
    Default Gearing for Mosport
    Greetings all
    I will be running in the Vintage Festival at Mosport next month and have a 1988 Citation F2000. Does anyone know what gears to use?
    Oshawa, Canada
    Default Staffs vs Hewland
    Greetings All.
    A quick question - can you use Hewland Gears in a Staffs Gearbox?
    Thanks. Robert
    Liked: 4368
    Quote Originally Posted by Rob22 View Post
    Greetings All.
    Thanks. Robert
    You use the same gears as for Hewland Mk 8/9 but not for the Hewland LD200.
    Liked: 3454
    Default Mosport gears
    When I last ran Mosport with a Pinto engine, Staffs gearbox and a 10/31 CWP, I used 19/32, 21/30, 23/28, 19/21.
    If you have a recently built top of the line (long rods, etc.) Pinto, you might want to raise 2nd, 3rd & 4th one tooth.
    Oshawa, Canada
    Thanks Dave. I had the correct gear sets for first, second, third but I am off by a slight margin for fourth gear. Seeing I haven’t raced in 25 years I am confident that it will make an infinitesimal difference.
    This is your 1988 car so I will send some pic from Mosport.
    Many thanks for your reply!
    Best Robert
    Oshawa, Canada
    Thanks Greg! I happened to have a few of those gears!
    Best. Robert
    Liked: 3454
    This is your 1988 car so I will send some pics from Mosport.
    Best Robert
    Well, that's neat that you have one of my previous cars ! The 4th I ran (19/21) is no longer available. You'll have to use a 24/26, 25/27 or other similar gear. Good luck at Mosport. I loved that track, but haven't been there since 2011. As Sam Posey once said, it's a real test of one's "attachments."
    Bowmanville, Ontario, Canada
    I use:
    First 18/32
    Second 20/30
    Third 22/28
    Forth 25/27
    https://youtu.be/pZgRFC8vvRk
