Page 9 of 10 FirstFirst ... 5678910 LastLast
Results 321 to 360 of 392
Thread: 3D printed fun
  1. #321
    Pittsburgh
    Liked: 301
    Chris - have you swapped bed springs for silicone spacers yet? Those are huge - no resonance to loosen them up.
    Remember, just like on our spring perches they need sufficient pre-load to keep from backing off.
    I made a device that allows me to put a dial indicator in where the extruder goes on the carriage. Then I run the leveling program, and I can get it to a half-thou across the build surface. there's more variance in the build surface due to getting the decal to lay flat with no bubbles, than there is in my leveling process. Then I replace the indicator with the extruder, set z with paper/friction, and fine tune with z-offset. I used to have to do that in the slicer but Qidi now offers live Z adjustment at .02mm/step with a firmware upgrade.
    Some build plates aren't flat, especially when hot, and that causes people a lot of headaches. you'd have to build a fixture with a power supply, heat it up, and then flycut it to get it flat if you have that problem - or buy new parts.
    I have not tried silicone spacers. I did buy stiffer springs. I also tried to mount the bed via three points instead of four, but that actually made it worse. My bed is a bit convex, high in the middle. It's not been a huge deal, but sometimes I have to run clearance tight in the center if I am going to do a large print. On tall prints I struggle with the bed being on four posts with no lateral support, so the top of print tends to move around.
  2. #322
    Senior Member Spengo's Avatar
    Vancouver, WA
    Liked: 143
    Quote Originally Posted by RSS View Post
    For all those on the prusa train you might want to re-think your choices these days especially if going to a larger format printer. They are the apple of the printer world yes they work well but man are they overpriced.
    If going larger format look into the Bambu labs X1C or a Voron.
    I've had a prusa i3 for many years, Bambu X1C is the first printer I've seen that has actually made me consider upgrading from my old bedslinger. Has pretty much every feature you could want.
  3. #323
    Liked: 1705
    Quote Originally Posted by Chris Livengood View Post
    I don't see how you can effectively level it with four. 3 makes a plane. The Qidi has two in the front, one in the rear center. My scales are a PITA because of four contact points. I'm betting you are high in the middle because two opposite corners are "tight".
    I'd make a dial indicator jig, loosen up all the leveling knobs, and start playing around with it - including putting a good straightedge across the bed when it's not constrained at all.
  4. #324
    Liked: 1705
    Quote Originally Posted by Spengo View Post
    Core XY/cartesian is definitely the way to go. As the build area gets bigger it's hard to sling around a big print and a heavy heated bed. The mass of the extruder is always the same so the control system can be tuned tighter.
    The new Prusa is a Core XY machine.
  5. #325
    Liked: 913
    I just uploaded an .stl for the Hewland gear storage post thing: https://www.thingiverse.com/thing:5891462
    This is just a copy of the injection molded version that Pegasus sells. Post some pics if you print some!
  6. The following 4 users liked this post:
  7. #326
    Pittsburgh
    Liked: 301
    3 points make sense to me as well, but the ender for whatever seems to prefer 4. The dial indicator method sure would make adjustment a lot easier. I might have to print up a mount for an indicator. Ideally the bed would mount on like a spherical bearing and then have two adjustment screws. This would remove the lateral slop the ender 3 v2 bed has. It's really only problematic on very tall prints, it would be nice to reliably get to like 14" though.
    Speaking of tall prints I was around 12" up and there is just enough cumulative slop in everything that the machine crashed and ruined the part with about 2 hours left on a 26 hour print. Otherwise I have had good prints lately. My PETG game is spot on currently. I am working on some molds to make wing shoes for the Firman F2000 platform since they aren't available anymore. It's going to be a lot of printing. I might have to buy those silicon spacers sooner rather than later.
  8. #327
    Williamsport, PA
    Liked: 497
    It is a "best fit" system. It calculates a mean leveled plane from all 4 points.
    We do this at work on some of our engine pieces as well.
  9. #328
    Liked: 1705
    Default rain light
    I usually don't keep a rain light on the car. In SoCal, it's often "if it rains, put it back on the trailer". My rain tires are some ancient Hankooks bought old in 2015....
    For years I had a cheapo LED marker light as a rain light, with the wire coiled up in case I needed to hook it up, but out of the way otherwise. But then one day, said cheapo marker light's bracket experienced metal fatigue and departed. I decided I wouldn't put one on again unless someone insisted.
    Then came last weekend at Big Willow, where it rained on and off and the possibility that I might need to activate it before sliding off in a crash came to mind.
    Found these on Amazon: https://www.amazon.com/dp/B0BQHYFSKZ...t_details&th=1
    Hella bright, low power, and in a heavy metal shell that's potted. They come with a sort of odd rubber grommet that looks like it is designed to attach to a metal tube.
    So I learned how to import airfoils into F360 and designed this underwing mount. Unfortunately unlike Chris my PETG game has fallen off (and the reason I haven't printed any LD-200 jigs lately). I changed to the latest Simplify 3d at the same time I had some extruder issues and haven't been able to get that mojo back.
    Overall, not bad though.
  10. The following 4 users liked this post:
  11. #329
    Lurker Keith Carter's Avatar
    Mokena, IL
    Liked: 454
    Default Designed and printed illuminated name box
    Playing around and designed and printed my own USB powered led name box for my sim racing seat. Turned out pretty cool....
    2003 VanDiemen FSCCA #29
  12. The following 5 users liked this post:
  13. #330
    Liked: 556
    any have experience with printing metal? is aluminum an option? application would be for a swivel t-stat housing water neck. I need a custom angle that nobody sells.. working with Sean Kelly to get the 3d drawing done soon.
    wanted to see if anyone knows if 3d printed metal aluminum will work for this. water psi set at 16psi by the radiator cap.
  14. #331
    Williamsport, PA
    Liked: 497
    it is technically doable with a properly equipped home 3D printer, using metal impregnated filament, but then you have to sinter it... which can be a hassle.
    https://www.matterhackers.com/store/...et/sk/MPQJ2NTV
  15. #332
    Vancouver, WA
    Liked: 143
    You could try some of the nylons available. I really like Taulman Alloy 910 for a pure nylon and Matterhackers NylonX carbon fiber infused if you need something more rigid. They won't melt and degrade the way PLA does and they're stronger than cast aluminum parts in many ways. You need something with an all-metal hot end and also a hardened steel (or harder) nozzle for the CF stuff. I also recommend a G10 build plate and enclosure to help with warping, cardboard box is fine.
  17. #333
    Liked: 913
    Made a set of steering rack locks for setting toe. Certainly not an original idea but I added small tabs to make them easier to remove, or possibly to safety wire a larger "remove before flight" flag.
  18. #334
    Liked: 913
    Speaking of setting toe, I usually try to use Gammon reels for my alignment strings but they don't have any provision for mounting to anything. I printed a housing that they slide into and bolted it to some extra 80/20 extrusion I had on hand. Overkill? Probably, but now i have enough adjustment to use these bars on multiple cars.
  19. The following 6 users liked this post:
  20. #335
    Liked: 1705
    Default crash attenuator for 90-97 VD nose battery compartment
    I think I posted this thing way back in the thread. It was too big and too difficult to sand down to fit
    I had a couple of spools of some filament I just hate - spent a full day printing 8 minute test coupons trying to tune it in and finally gave up. Decided to use one spool to print this.
    You can see in the first pic the item it replaced - a chunk of pour foam painted with epoxy I made with my first seat over 20 years ago. Being made of expanding foam it fit pretty tightly and as it aged it became harder and harder to get it out as the devices I used to provide a puller hogged out bigger and bigger holes.
    I took my original STL and reduced it by 2% in x and Y in the slicer to ensure I would have enough room. It was printed with a .1 nozzle, in PETG, with about a 12% hexagonal infill, and two perimeters. Took 16 hours to print. It weighs about two pounds, the foam one was probably 1.5 pounds.
    Had I been willing to use a .04/.05/.06 nozzle I could have printed the same thing (with 7% infill) and it would have weighed half as much, but would have taken over 30 hours to print.
  21. The following 3 users liked this post:
  22. #336
    Liked: 1475
    I made some like this too. Camfer the 'corners' and they will go on and off a lot easier.
  23. #337
    Liked: 1475
    I've been using Overture PLA and PETG. I bought another brand off Amazon it was junk.
    I know there are others about 20% cheaper but I have had Zero issues with the Overture products.
    What are you using?
  25. #338
    Liked: 913
    I did exactly that on the second set!
  27. #339
    Liked: 1475
    Default Radiator Tray RF01
    So I had a leak in a radiator. Pulled it apart to fix and found the rear end of the radiator was sitting on the frame.
    The original fiberglass radiator tray had been trimmed for some reason and lacked original support so it collapsed.
    So as an experiement I decided to make my own. This prototype is in PLA but I plan to print one in black PETG once I get it all right.
    It's in 3 pieces because of my printer's limit (8.5) so I keyed it together.
    Screws hold the front and back so the middle section is just wedged in.
    Will it stay together? I think so. But with about $30 in material for a bunch of prototypes and est $10 for the final, I may just print a stare.
    If it doesn't work right I'll print a mold !
  28. The following 4 users liked this post:
  29. #340
    Liked: 1705
    I'd print that in ABS and glue it. Petg is hard to glue and I've found it gets brittle over time. Been replacing stuff made from PETG with ABS or TPU with very little infill.
  30. #341
    Liked: 1705
    Radiator trays on the 90-96s were aluminum hat section. Found mine worn all the way through in a couple of places and starting to get into the radiators. One of the first things I did on my major rebuild in 2003 was to have those copied in stainless. 20 years on they are still perfect. One of the things that helped was to put spacers between the radiator tray edges and the floors. This raised the tray and radiator up so they were flush with the bottom, rather than hanging down and catching curbs. There's plenty of room above in the sidepod.
  32. #342
    Liked: 1475
    The fiberglass trays had a rubber strip for the radiator to rest on.
    Plan to do that again. Think it'll help.
    Haven't printed ABS or ASA yet. I might give it a go.
  33. #343
    St. Charles, Illinois
    Liked: 222
    Has anyone printed or know of anyone who has printed a more aero friendly mount for an AIM smarty cam HD 2.2 camera for the top of a roll hoop on a formula car.
    Brian T
  34. #344
    Huntsville, AL
    Liked: 83
    Like this?
    George Bugg
    NovaKar
    F600
  35. The following 4 users liked this post:
  36. #345
    Huntsville, AL
    Liked: 83
    George Bugg
    NovaKar
    F600
  37. The following 3 users liked this post:
  38. #346
    Huntsville, AL
    Liked: 83
    George Bugg
    NovaKar
    F600
  40. #347
    Liked: 222
    Yes exactly. Did you print that yourself?
    Huntsville, AL
    Liked: 83
    I did. I’d be happy to send you the .stl files.
    George Bugg
    NovaKar
    F600
  43. #349
    Liked: 222
    Quote Originally Posted by GBugg View Post
    that would be great
    thanks,
    btomasi96@gmail.com
  44. #350
    Liked: 1475
    Default Latest Printer Choices
    I'm looking to replace my Ender3 s1 pro.
    I was all set on the Bambu X1C during the December sale but my order 'disappeared' and then they wouldn't honor the price. So I decided to wait. Now Bambu is caught in a pickle with their latest updates and people are jumping ship.
    Now looking at the Creality K2 Plus. Reviews are good and they no longer consider Creality a hobbyist brand.
    What are you all looking at as your next choice?
  45. #351
    Classifieds Super License helipilot04's Avatar
    Pine Bush, NY
    Liked: 113
    Default Bambu
    I replaced my Ender 5 plus with the Bambu X1C over a year ago, BEST decision I have made regarding 3d printing.. Super fast, multi-color, professional prints. I can monitor the work from anywhere. start, stop, etc from phone app. It has print fail detection and can print almost any Filament. Tho TPU cannot go thru the AMS (multi color "auto material system"). I have eight colors available with two AMS's connected. Build plate is smaller than the Ender 5 plus but I rarely need the size. Quality and Speed far exceeds the Creality products from the past. fully enclosed build area and filter make using ABS simple. And the ABS prints can be used in hot areas of the car where temp and strength are important.
    So far the support and products for the X1C have been great, their slicer/print utility works great. I have printed more kids toys than I can count, coasters are a popular multi-color print for the newbie and the color options make toys and race car parts so much more professional.
    good luck
    Bob
  46. #352
    Liked: 1475
    Quote Originally Posted by helipilot04 View Post
    The reviews put the K2 Plus on par with Bambu. But many other printers are there now too.
    How do you feel about their recent firmware update and requirement that everything passes through their online servers?
    The changes they made basically setup everything for forcing a subscription on you to use it.
    Can no longer use it to prototype sensitive designs since all your data goes through servers in China.
  47. #353
    Pine Bush, NY
    Liked: 113
    Two items.... one, I was worried about that to an extent... I tried printing an item of questionable legality, just to see,... it printed fine and so far no one has shown up at the house... I cut the part in a few pieces and saved one.. just because.. Second, I understand and have seen in my printer options to do local only printing and connection.. while I haven't tried it yet, i believe its still there after the update... I do a lot of long prints and its nice to keep track of them over the net... I guess the "private" prints will have to be done another way..
    Bob
  48. #354
    Liked: 1475
    Bob
    My concerns are:
    1. All designs go through their servers. Not concerned about legality of what is being printed. Concerned about the theft of copyrighted designs.
    2. Yes, you have a local/developer mode but you lose the ability to remotely monitor - or do anything remotely through the app. Some people are saying once you choose local mode, that's it. No more updates or fixes.
    3. As I said this also seems to set you up for paying service fees.
    Are they done? Have they shown all their cards? Who knows.
    They created the first 3d printer as an appliance instead of a fiddly maker tool.
    Others have followed.
    But I'm kind of holding back. They have damaged their reputation and the product.
  49. #355
    Liked: 1705
    I'm seriously considering an enclosed Prusia.
    if I ever get to print again. Fusion is still out of commission.
  50. #356
    Senior Member RSS's Avatar
    Sylvan lake, Alberta
    Liked: 453
    That firmware was in Beta and hasn't been released.
    I actually had to roll back to an older firmware recently because of a bug so just don't update then you dont have any problems and there is always the SD card method.
    The newer Creality printers are better now but they still have the usual Creality QC issues 2 out of every 10 are great the rest are?
  51. #357
    Liked: 1475
    I actually had to roll back to an older firmware recently because of a bug so just don't update then you don't have any problems and there is always the SD card method.
    But you lose features such as remote monitoring.....
    I think the QC on Creality is much better than you think. Yes they started out essentially selling low priced kits and it take a lot to work out of that reputation.
  52. #358
    Liked: 453
    True on the monitoring but with my Bambu's I hardly neeed to monitor anymore.
    I know a couple people with the K series printers from Creality and its still a crap shoot. One prints great the next can't even give you a proper benchy.
  53. #359
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 82
    That was one of the first things that I printed for the VD! And a great use case!
  54. The following members LIKED this post:
  55. #360
    Jupiter, Florida
    Liked: 82
    Thanks!!!
    Quote Originally Posted by mike b View Post
    i just uploaded an .stl for the hewland gear storage post thing: https://www.thingiverse.com/thing:5891462
    this is just a copy of the injection molded version that pegasus sells. Post some pics if you print some!
  56. The following members LIKED this post:
There are currently 12 users browsing this thread. (0 members and 12 guests)
