I've lived with less than ideal radio reception for a while now, and I've finally decided to look into it. My antenna - https://racingelectronics.com/collec...cts/etrab4500n - is mounted to my fiberglass body using a grounding plate - https://racingelectronics.com/collec.../products/k332 - but the ground plate is not grounded to anything else. Shouldn't it be tethered to the chassis or battery negative? If so, can I get away with just running a wire from the plate the the chassis or battery negative connection?
Sent from my SM-G996U1 using Tapatalk
