    Bloomington, Indiana
    Liked: 24
    Default Need seat for Merlyn MK20A
    Hey gang,
    As I am making some changes this off season-I was looking at my seat and placement in my Merlyn. I am wanting to do the foam seat, but before I do that-I wondered what seat options anyone has used to support the foam insert? My current seat was for a much taller driver-it bolts to a crossmember at the front/floor area and the other crossmember at the upper back-not much room to make any adjustments to driver position. Ideas?
    Petaluma, CA
    Liked: 705
    If you care about comfort, safety and performance then you are in luck as the answer is simple one!
    http://www.speedseatfactory.com/Full...ontact_Us.html
    Jody is the best. In my opinion, there is no point in doing a seat any other way, especially since you are in the midwest. You will not regret it.
    Ethan Shippert
    Liked: 24
    I will check the link out-Thanks!
    Paddock Lake WI
    Liked: 210
    Quote Originally Posted by Velodrome Racer View Post
    Jody came and poured me a seat in November. I also highly recommend you get a seat from them. You can pour one yourself with some help, but it won't be done nearly as well!
