Results 1 to 18 of 18
Thread: Trailers
    Saint Louis, MO
    Liked: 339
    Default Trailers
    Hey guys.
    We are still shopping trailers. What I want is a small, low profile, light weight trailer. I've looked at all sorts of low profile aluminum trailer, then I found https://ironhorsetrailers.com/2-bike...cycle-trailer/
    What do you all think?
    Tools, rain tires etc will go in the truck.
    PA
    Quote Originally Posted by Lynn View Post
    Hey guys.
    Every trailer is a compromise.
    This one is fairly light and looks pretty aero.
    That said,
    I'd double check your length vs the 12'6" 'Body Length' to make sure you have enough interior length - especially considering the axle on that trailer looks a little far forward - you may not have enough 'positioning' room and/or have to load the car backwards to get a good tongue weight.
    You won't have good access to the front end of the trailer with the car in there, so front restraint might be a bit of a pain.
    With a 'short' rear door, you will need some type of helper ramps for both approach and breakover.
    For me, especially since our tow vehicle is a DD SUV, loading everything besides the car in the tow vehicle would quickly get tiresome.
    San Jose Ca
    Liked: 88
    I'm looking into the widebody trailer because it's 13.6 long? on the interior length. Will call tomorrow to double check but if it's not an arm and a leg like other trailers I may order one.
    jdr17, I know what you mean about having a trailer thats a little small and you have to carry everything in the back of my truck.
    Ben
    Saint Louis, MO
    Liked: 339
    I had been concentrating on the width of the tailgate opening an didn't realize the overall width of the wide body is only 2" larger than the two motorcycle trailer. The wide body is the way to go, if it doesn't cost too much.
    Prescott, AZ
    Liked: 205
    Very nice, hard to find trailers. Not inexpensive.
    San Jose, CA
    Be sure to consider axle location and tongue weight with your car loaded. Floaty trailers are not fun!
  8. The following 4 users liked this post:
    Red Neck Riveria, FWB, FL
    Liked: 105
    Default Thank you - thank you!
    Lynn,
    I have been searching for a trailer for my wide-body Corvette. Its fenders 80" wide.
    You have sufficiently "narrowed" my search to their Dual-Axle version.
    Best of luck in your purchase - and again thanks!
    Cheers - Jim
    Contributing Member Gary Godula's Avatar
    Farmington Hills, MI
    Liked: 66
    Default PRI Show
    Lynn, if you are heading to the PRI Show in Dec, there are a lot of trailer suppliers displaying their wares in the Lucas Stadium. We have seen some interesting trailers there. If you are planning to hit the show, and can wait that long prior to purchase, you might want to do some research there. Good Luck.
    Gary Godula
    '88 Reynard FF88
    SCCA Club Racing / Solo #57 FF/CM
    St. Louis, MO
    Liked: 34
    Lynn- I have a Trailer from Montrose which likely fits your requirements. And, you can customize it dimensionally. I had them make mine about 4" narrower than their standard width.
    I see you're in St. Louis, as am I. I would be happy to show you the trailer in person, if interested.
    I'm at work and and blocked from adding a photo, but found a previous thread where I had posted a picture.
    https://www.apexspeed.com/forums/sho...697#post625697
    Saint Louis, MO
    Liked: 339
    Gary, Don't you have to have a motorsports business to get into PRI?
    Steve, I would like to see your trailer, but I would like to see the Mallock even more.
    St. Louis, MO
    Liked: 34
    Lynn - Happy to make it a twofer.
    I'll send you a PM with contact info.
    Lafayette INdiana
    Liked: 302
    Me too.
    PA
    Just following up to my own and DSR3's posts after seeing the pic of Steve's Montrose and this video of the widebody: https://www.youtube.com/watch?v=z5Z7R1t51u4
    I'd really double check the length available and find out the position of the axle to do some calcs before buying.
    My single axle is a 12' box + ~3' v nose and I have to load the car really far forward to get to 10%+ tongue weight.
    Here's a couple pics to (kind of) show interior placement and relative axle location.
    PS: That the double axle Montrose is only ~1500 lb is impressive, my (steel frame) single axle measured in at 1623 empty!
ID:	104650   Click image for larger version.
    St. Louis, MO
    Liked: 34
    Me too.
    Happy to show you if you are in St. Louis, but this will give you an idea.
ID:	104651   Click image for larger version.
  17. #15
    St. Louis, MO
    Liked: 34
    And here is the trailer, which I actually purchased for my Seven.
ID:	104655   Click image for larger version.
ID:	104654   Click image for larger version.
  19. #16
    Lafayette INdiana
    Liked: 302
    The Mallock looks well thought out.
  20. #17
    Minnesota
    Liked: 28
    Default Another option
    Hey guys.
    Aerovault (bre2.net)
  22. #18
    Liked: 66
    Default PRI Show
    As SCCA members, we are eligible to attend PRI. Pre-registration is required to attend. SCCA normally has a booth at the show.
    Gary Godula
    '88 Reynard FF88
