Results 1 to 2 of 2
    Stockton California
    Default Formula First rims
    we are converting a Vee to a FST. Looking for some rims. We have hubs and rotors drilled for the original VW pattern. Any ideas?
    Cupertino, Calif.
    Liked: 24
    Default Machining FST Discs
    Blake,
    You should be able to just drill new holes clocked 45 degrees from your existing locations, you will need to spot-face the inside of the discs but that was likely done for the holes already done. I had to drill new holes in my discs because the original holes didn't run true to the axle. I highly recommend using a milling machine to do this; a rotary table on the mill will speed up the process somewhat, but is not required. Even with the extra holes, the discs are well over the minimum weight. BTW: I did find that with the rigidity of the milling machine, these were relatively easy to machine. If it helps, these are supposed to be G3000 cast iron.
    -Jim
