    Maineville
    Liked: 108
    Default 1600 Dry Sump Pans
    2 New Formula Ford 1600 Steel Dry Sump Oil PansDesign based from the steel 1600 Titan dry sump oil panwith update modifications. $550.00 each plus shipping. Improvements: 1. 3/4 O.D. scavenge outlet tube.2. Dry Sump Pan zinc plated not painted.3. Removable scavenge tray baffle for easy pancleaning. (Original Titan pan tray baffle is welded inplace making proper cleaning under baffleimpossible.)4. Large scavenge oil pickup box with built in screen.5. Separate oil pan drain plug. (Not part of original Titandesigned drain plug with finger scavenge screen.)6. Rare earth magnet attached to oil pan drain plug tocapture ferrous material to protect oil pump scavengerotors and for engine analysis.7. Pan TIG welded with original Titan Pan mountingflange weak area. Contact Rex Gunning at (937) 218-6967 All Sold
    Destin FL
    Liked: 729
    Righteous deal. If you do not grab this, you will regret it. Just say’in
    England
    Liked: 17
    Need to make these sumps with the rear cut out to fit Van Diemen chassis
    I have bought a few street car sumps had them converted to dry sump but always have the rear inch cut out so they are of use to fit an engine into a VD car
    St. Louis, MO
    Liked: 30
    Is this still available?
