Results 1 to 8 of 8
    Santa Clarita, California
    Liked: 32
    Default Speeds On Willow Springs Big Track
    I had another track day yesterday in my PFM. The car ran great and I’m feeling a lot more comfortable in it.
    I had a question on the top speed everyone is reaching right before turn 1. I was able to sustain 103mph through turn 8, then slowed a bit for turn 9 because of the decreasing radius turn. I accelerated hard out of turn 9, but at the end of the front straight I was only at 130mph. Is that close to the speed where everyone is? Should I be going faster than that? The motor was turning about 7500rpm right before I braked for turn 1.
    Paso Robles, CA
    Liked: 316
    You will never achieve top speed at Willow Springs until you are completely flat from T6 until you reach T1. That is what a pro driver in a PFM would do. Top speed would probably be 140+. Min speed in T9 would be in 110+.
    I suggest you hire Mike Anderson as a coach -- he can make sure the car is setup and working correctly, then set down a reference lap to show you what's possible. He holds the FM track record at Willow Springs 1:23.7, the SCCA PFM record is 1:19.2, but that might be a little soft.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Liked: 32
    Thanks Dave, where is Mike Anderson located? Is he at one of the businesses at Willow Springs?
    Paso Robles, CA
    Liked: 316
    Default Mike Anderson contact email
    I sent you an email with his email address.
    David Ferguson
    805-238-1699
    Liked: 32
    Got it, thx!
    Circuito Do Sol Portugal
    Liked: 384
    My entry in turn 8 was 147mph.( your gear stack might be low one)
    However at the time i wasn't too comfortable with PFM speed
    so my best in PFM is Andersen's best in FM.
    1.23.5 was my best.
    Dave is right T6 to T1 flat.
    I would lift slightly before T9 and back on throttle into it for first
    and go as wide as your balls would allow.
    lol
    Maris Kazia ,CEO
    EuroKraft Inc Racing
    Circuito do Sol
    Liked: 384
    Pro driver in PFM is probably capable
    to go 1. 16 , 1. 17 .
    Maris Kazia ,CEO
    Circuito do Sol
    Liked: 32
    Quote Originally Posted by Kazis31 View Post
    1.23.5 was my best.
    lol
    Ok, my gears may be too low. Im assuming I should be at 8600 rpm right before I brake for turn 1? With my existing gears I don’t think my car would get to 147 mph before the rev limiter hits.
    As far as flat out from turn 6 to turn 1, I’ve got a lot of work to do lol.
