Stohr WF-1
Race car garage cleanout sale: one price takes it all:
Stohr WF-1 with 07-08 Suzuki 1000 dry sump GDRE stock motor with 1 hour run time
Aim EV0-4 fully sensored data system with Lambda and ECU data and Aim Smarty cam. Spare new Smarty camera, 2 spare brake pressure sensors, 7 spare patch cables, 2 oil pressure sensors, several other misc. sensors, Complete wiring diagram of the data system and Evo4 user manual.
Flat Shifter Expert paddle shifter, no lift upshifts and blipped down shift
3 sets of wheels, one set BBS on the car with 45 minutes run time on R 25 Hoosiers, BBS with Hoosier scoffs and one set of Hoosier rain tires.
HRP rear wing, original Stohr WF-1 floor
Brembo big brake kit with Tilton adjustable pedal/master cylinder set, rebuild master cylinder kits and spare Cobalt Friction brake pads.
Quaife diff.
Transponder, non-subscription, wired in.
Front and rear lift jacks
Front and rear sprockets and chain. Counter shaft sprockets: 2/17, 2/16, 2/15 with 3 spare sprocket nuts and washers. Rear sprockets: 44, 45, 3/46 and 48 tooth. New RK 530 and DID gold 120 link chain and master links. Other misc. used chain to fit sprocket combinations.
New Lithium-Ion (2.6 lbs.) battery and charger, spare Lithium-ion battery
Front suspension update with new uprights and lower suspension A arms.
Currently has carbon fiber springs in the front, with spares. Four sets of springs, 1000, 2/1400 and 1500, all 4 inches in length.
More Spares
07-08 Suzuki GSXR 1000 dry sump motor at George’s for refresh with injectors and ecu or can be included.
Repaired WF-1 front splitter.
Jigs for upper and lower front and rear Arms. Spare front upper and left rear lower A arms. All with Heim joints installed.
3 starters, Starter disconnect kit, 2 clutch packs, 2 voltage regulator, 3 countershaft covers, 2 fuel pumps, spare 14 lb. radiator cap, 2 main electrical shutoff switches, 2 fuel filters, 9 CV joints, various control cables, spreader bars for rear spar, electric water pump, overflow can fit in the spar.
Spare Dry sump tank
07-08 Suzuki ECU, 4 coil plugs, 4 thermostats, header gaskets, new set of spark plugs NGK CR9E1A, other misc. Suzuki engine parts.
2 complete trap door wet sump pans for Suzuki GSXR 1000
Radiator as used in the Stohr F1000, also a WF-1 radiator needing repair.
WF-1 oil cooler and smaller oil cooler for dry sump motors both just returned from cleaning with tags and plugs still in them.
2 pairs of hydraulic spring collars with repair parts, one pair on the rear shocks
2 first generation WF-1 front uprights and 2 lower A arms.
1 WF-1 Updated repaired left front upright with spindle and center lock nut.
Motorola radio set, two Motorola P1225 radios with chargers, earbuds, mic, all wiring, antenna, and grounding plate. Heavy duty case
$40,000 takes it all. Not interested in selling individual parts one at a time. I would die before everything is sold
Don’t make an offer unless you are willing to take it all. Dick Boggs 425 941 2864 Bdboggs@aol.com I am located 30 minutes North of Seattle in Marysville, WA.
