Results 1 to 10 of 10
Thread: PE3 pro map?
    North Carolina
    Default PE3 pro map?
    Does anyone know where I can download the PE3 pro map for the F2000 championship series? I have a car which has been out of commission for a few years with the newer ECU. Tried loading the SCCA map, but I think there are differences with some of the sensors and how they are mapped into the ECU because it's not working. The car originally had the pro map on it back in 2015 when it was last run.
    Paso Robles, CA
    Liked: 316
    Default The source...
    I would contact Eric or Sandy at Quicksilver RacEngines:
    https://www.quicksilverraceengines.com/index.htm
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Liked: 3905
    Default On the SCCA site...
    I don't know if this is the latest version, or if it is the current "pro" version, but here is a link to "a" PE3 map:
    https://www.scca.com/downloads/51949...c2000/download
    Liked: 1481
    Also here:
    There is a link to https://www.scca.com/pages/technical...-and-downloads
    Club and Pro ECU Map and Profile for Zetec engine classified in the FC class (Requires Pectel Software).
    Which for some reason links to the CRB site with additional downloads including a Pro map....
    Rocklin, CA
    Liked: 64
    Default PE3 Map
    You want the map that has an extension PED, which is on the SCCA web site download page. Also get the PE3 software, it is pretty good and will run on a modern computer.
    Ohio
    Liked: 71
    On a side note, where does one get a cable for the ECU to perform this function? We are in a similar scenario.
    J Swank
    Liked: 3905
    Default Pe3
    IIRC, QS has the needed conversion harness.
    Chatham Center, New York
    Liked: 1095
    It should be on the FRP F2000 website under technical specifications
    Liked: 3905
    Default OK, I found it - separate link on the Competitor's page
    I looked for it there but didn't find it.
    It's in this link titled F2000 ECU maps (Zipped folder): https://www.dropbox.com/sh/ohqkwqs5v...PRHU4Q9ma?dl=1
    North Carolina
    thanks everyone. I will give them a try
