    Atlanta, Georgia
    Liked: 15
    For Sale 83 Reynard FF2000 parts
    1983 Reynard FF2000 parts for sale, all in decent condition, have been stored for a long time, so will need checking over, the plating on A arms/Rockers needs to be re-done to be really nice.
    1 x front nose frame - $30.00
    1 x bare LH front upright - $75.00
    1 x front LH upright assembly with spindle/rotor and wheel flange - center lock - $120.00
    1 x front RH upright assembly with spindle/rotor and wheel flange - center lock - $120.00 - SOLD
    1 x front sway bar - $20.00
    2 x alloy steering arms with rods ends - $25.00 each
    1 x front w/bone with camber adjuster and rod ends - $80.00 - SOLD
    Pair front rockers - $120.00 each - SOLD
    Pair front rocker mounting plates with braces - $25.00
    1 x water swirl pot with cap - $15.00
    1 x front engine mounting frame - $20.00
    Car set of alloy water pipes - $20.00
    Pair outer aluminum radiator fairings - $25.00 each
    1 x rear wheel flange with splined axle and CV flange - $30.00 - SOLD
    4 x 94mm CV joints - $15.00 each
    1 x long rear radius rod - $20.00
    2 x short rear radius rods - $20.00 each
    2 x rear toe adjusters with rod ends
    Pair of rear rockers with pivot shafts and spherical bearings - $120.00 each - SOLD
    Top braces for g/box to mounting plate - $15.00
    Bottom g/box suspension mounting frame - 15.00 - SOLD
    Gearbox to chassis mounting plate
    Gear linkage rods - $20.00
    + postage
    Pictures available for individual items - open to offers, the more you buy the better the deal!
