Results 1 to 8 of 8
    Roseville, CA
    Liked: 46
    Default Carbir FB for Sale - Sold
    For sale: Carbir formula B car SOLD
    Converted FC Carbir Formula B, Conversion done by Kevin Mitz completed in around 2015. Car was run once and finished every session of the weekend. I have moved on to a P2 and this car needs to go.
    2009-12 GSXR 1000 motor George Dean sorted the oiling system, dry sump, drilled crank, external oil feed for the crank. There is a bit of an oil leak in the oil pan other than that the motor is pretty well sorted. Uses stock pick-points for the rear suspension and stock Carbir/Piper DS-3 geometry.
    Asking 17.9k
    John (408) 356 two eight four three or Racerh@msn.com
    • Exhaust is a custom 4 into 2 into 1 stainless system by Kevin Mitz
    • Exterior fuel fill, so you don’t have the take the car to pieces and risk filling the car with gas when you fuel up.
    • Includes MXL Pista Dash,
    • Belts good to 2023
    • Pedal mounts from a piper so you can unbolt the mount and move the whole unit forward
    • Full plumbed in Fuel injection system, in tank pump, pressure sensor to the Pista
    • Has SCCA logbook as an FC and ICSCC logbook as FBX.
    Extensive spares including:
    • 2 Core motors (one is missing a clutch basket) the clutch wrench I should have bought is included
    • Spare dry sump pan and pump
    • Spare injectors
    • Spare starters and water pumps
    • Engine tools
    • Engine: Gasket set, Gear nuts, valve shim set other parts as well.
    • Gears front 14, 15, 16 (I think the 17 is in the car)
    • Gears Rear 41, 42, qty 3 44, qty 2 45, 47,48 (not sure what is in the car)
    • 1 sets xtra wheels (2 total sets), and a set of pit wheels
    • Spare nose
    • Spare front wing and winglets
    • Spare rear wing (upper, lower and end plates)
    • Spare radiator
    • Spare rear suspension (front is available from Carbir)
  2. The following 4 users liked this post:
    So cool!
    Roseville, CA
    Liked: 46
    Default More information
    I realized that this post is lacking a bit of information.
    The build we did on the car was from a bare frame with some of the body work. I got a few used things, dash (new loom) new sensors, Diff (it was freshly rebuilt, tank (from Carbir) pretty much everything else was new, all of the suspension, and nearly all of the hardware is new. All the rod ends are new. There are a some scratches on the body work from the move from Seattle to California in a loaded up trailer.
    I may be able to help with transport if you need it.
    John
    Roseville, CA
    Liked: 46
    Default New Price 17.9k
    New project is in the garage and I need some room
    Senior Member Michael Lensen's Avatar
    Vancouver, Canada
    Liked: 15
    Default Reply?
    John, did you receive my PM?
    Michael.
    Roseville, CA
    Liked: 46
    Default No
    No I did not you can email me at racerh at Msn dot com
    I looked and there is no PM from you in my PM list
    Quote Originally Posted by Michael Lensen View Post
    Michael.
    South Ga.
    Is the F1000 still available? Thank you.
    Roseville, CA
    Liked: 46
    Default Deposit
    I have a deposit on the car.
    Thank you,
    John
