Results 1 to 6 of 6
    Lafayette INdiana
    Liked: 302
    Default Wanted for LD200 diff....a 9:31 ring and pinion...used.
    Will pay a reasonable price.
    Tom Walgamuth
    765 490 0275
    England
    Liked: 17
    I can supply u with a new diff
    used diffs hard to find these days as are good used 931 for the cost saving I would fit new CWP so that job is done and not need to revisit later when the used one wears out.
    I have new 1336 cwp on the shelf
    its ratio i prefer to use as it has more flexability in ratio options to change for a few hundred rpm that u can do with the 9 31
    Lafayette INdiana
    Liked: 302
    Quote Originally Posted by march718 View Post
    its ratio i prefer to use as it has more fallibility in ratio options to change for a few hundred rpm that u can do with the 9 31
    So is it a 10:31 ratio?
    Lafayette INdiana
    Liked: 302
    It looks like I'll be keeping my 10:31 diff. It worked fine Sunday at the test and tune. I just had to carry more speed into the fast places.
    Mississauga, Ontario
    Liked: 959
    Tom Walgamuth
    765 490 0275
    Tom,
    I may be the outlier here, but I see little sense in installing used CWPs in what is a very expensive gearbox. And prices (new or used) ceased to be "reasonable" for these decades ago.
    Would I do an emergency fix using a used CWP? Sure, if I had to. But, not knowing the history of it, I'd worry about it every second it was in the box, and I'd whip it outta there at the first opportunity.
    Just my 2 cents man
    best
    BT
    Lafayette INdiana
    Liked: 302
    Thanks for your thoughts Billi. As noted above I will be keeping my R and P for now.
