Results 1 to 13 of 13
    Farmington Hills, MI USA
    Liked: 60
    Default FE2 Public service message: set a low voltage alarm!
    In case your alternator decides to depart from its bracket, which is apparently a thing, you also lose the single belt that drives the water pump. Mine let go, and while I was getting intermittent high temp warnings, it was bouncing between 180 (normal) and 226, so I thought it was a bad sensor. My voltage alarm was set at 12.4 (which was just below what the old generator would maintain at idle), but my battery stayed above 12.6... so I ran 6 laps with no water pump. 3 weekend engine going back to Enterprises for rebuild. Looking at data, the alternator is consistently above 13.5 volts... so set your alarm somewhere around 13. Would have saved me.
    Vancouver, BC, Canada
    Liked: 259
    Where is your water temp sensor? If in the motor, I would have thought that the lack of circulation would result in such high water temps that you'd get an alarm for that?
    -Mark
    Mark Uhlmann
    Vancouver, Canada
    '12 Stohr WF1
    Liked: 60
    -Mark
    It's at the back of the engine, in an assembly with a bleed line and the pipe for the radiator hose/tube.
    From the first increase in temperature (from 183 to 184), which I assume is within a couple seconds of when the alternator broke off, it took 8 seconds for the voltage to drop below 14.0.
    Within another 10 seconds temp reached 200 and I got my first alarm (and voltage was 13.1). So, if my alarms were set for 200 and 13.2, I could have known to shut off after 18 seconds.
    Another 10 seconds, temp was 226 and voltage 13.0.
    Curiously, the temp never recorded higher than 226... not sure if that's a function of the sensor range, or the PE3 calibration limits, or what. I will look into that, as well. My car normally runs 180-183 coolant temp.
    Also curiously, over the next few laps, the temp reading would bounce between 180 and 226. Maybe that's a function of the sensor being splashed vs steam, or the system burping. Not sure, but I think if the sensor isn't immersed, it doesn't function properly. Unfortunately, this tricked me into thinking it was a bad sensor, loose wire, etc.
    Oil temp started to rise also, from 230-ish, up to 287 6 laps later. I guess I should set an oil temp alarm, as well.
    Liked: 913
    Could you run a coolant pressure sensor? Or just a dummy light?
    Liked: 60
    Not sure if there's a port available for pressure. Knowing what I know now, alarm for high temp and low voltage and at the correct limits serves the same function. Having this type of detail from SCCA-E would have been nice. On many SRF3 cars, there is an rpm sensor on the alternator, for the same reason. Guess I could have added something like that, as well.
    Liked: 558
    This is what I run. 4lb pressure switch with light. But it won’t tell you if the water pump goes since system will hold pressure until it cools.
    Liked: 573
    Yeah, I've always thought the WP pressure sensor was for something like a holed radiator or loose hose or clamp.
    Good info and thank you for sharing.
    A friend also ignored a water temp gauge they thought was faulty, several thousand$ later they were back racing.
    The takeaway I get from this is don't ignore gauges (we put them there for a reason). If we think they're faulty, wiring or sensor on the fritz pull off/in and check it out back in the paddock. Unless you're fighting for, or in the lead at the RunOffs on the last lap, then feel free to ignore all gauges and funny sounds. Or if you're just having so much fun and engine rebuilds aren't a major concern feel free to carry on.
    Santa Rosa, CA
    Liked: 296
    Default message
    If the water is leaking your temp gauge will let you know as it will fluctuate a bunch while you are driving, same is true if water stops moving in the system. Good reason to glance at the gauges and any needle that is moving around is certainly a warning sign meaning you already have a warning device on board!
    Liked: 60
    Default 180° - 226°
    I think what threw me is that the temperature stopped at 226°. That is not inordinately high for a glycol/water automotive system with a pressure cap. Then, it was bouncing between 226 and 180 (which is the normal temp). So, frankly, I didn't understand the messages I was getting. Like I wrote before, if I'd seen temp and voltage warnings I'd have stopped. If I saw 240° or 250°, I would have stopped.
    Lap 12 data (water temp is the bottom signal):
    Lap 13 data:
    Vacaville , California
    Liked: 79
    Default alternator bracket
    So did the bracket on the alternator brake ? Or did it loosen up? Any photos of the bracket if it did brake?
    JR
    Senior Member Gary_T's Avatar
    Regina, Sk. Canada
    Liked: 106
    Based on how the temp graph gets 'clipped' at 226, I'd say there is something that is artificially limiting your data to that maximum - either logger config, or sensor calibration.
    Gary Tholl
    #24 BlurredVisionRacing
    Liked: 60
    I believe the lower, pivot bolt broke first. There appears to be some fretting on the mounting face between the alternator and the lower machined mount. The upper machined mount then broke at the forward bolt hole.
    Both the PE3 and CDS systems do not appear to limit temp to 226 - they should read up to 240. Possibly a bad sensor, or a bad sensor calibration.
