Results 1 to 8 of 8
    Member beavertail's Avatar
    Montreal, Quebec
    Default Oil pan plug screen
    I was replacing the engine oil on my Zetec engine, when I removed the oil plug at the bottom of the pan, this screen came out.
    Should this have come out so easily?
    Wilson
    Ottawa,ON
    Liked: 138
    Yes.
    Or at least that is what Francois told me haha.
    Liked: 993
    Absolutely. The screen is supposed to stay attached to the plug. Otherwise think what would happen
    Senior Member JLind's Avatar
    Brantford On Canada
    Liked: 53
    You can epoxy the screen back in. I have made aluminum AN pan fittings this way
    James
    Liked: 3851
    Default ???
    Is that just a drain plug? If so, why would it have or need a screen? Or does that connect to the hose to the oil pump?
    You should only need a screen on oil pickup(s) that lead to the pump.
    Pittsboro IN
    Liked: 317
    It really should not detach from the plug but it also should index into the other side of the pan so it is not gong anywhere
    Montreal, Quebec
    I took a better look at it last night......it turns out that this screen is inserted between this drain plug and the oil pickup tube on the opposite side of the oil pan.....well that makes sense!!!
    Thank you for your input
    Liked: 3851
    Quote Originally Posted by beavertail View Post
