FOR SALE
2015 RFR Firman F1000 / FA
This is one of the fastest most developed F1000 / FA car-programs on the planet.
Car is fully sorted and has endless specially developed proprietary components.
Multiple track records, Major’s & Runoff’s wins.
Car is 800Lbs, well maintained and is race ready.
Car Unique Features include: ($125k VALUE )
Chrome moly Frame w/ lite-weight engine frame
F1000 Spec Kawasaki 2017 Gen 5 Engine with 5 hours
Custom Dry Sump Oil System w/Oil De-aerator
Advanced Composite Air Box w/ Large Air Filter & Fuel Cooler
Swain Coated 4:2:1 Header System w/ custom tailpipe
Head Impact Horse Collar
VHE light weight Uprights
Wilwood 4 piston lite-weight calipers & PFC Rotors (Outstanding Brakes, Saving 20+ Lbs.)
Gun Drilled Mark Williams Half Shafts w/ Lightened Tripod Joints
Geartronics Paddle Shifter System
Custom Mil-Spec Wire Chassis & Engine harness’s
AIM EVO4 Data Acquisition System with AIM Formula Steering Wheel II with Kawasaki Data stream, Brake, Coolant & Fuel Pressure Sensors, Water & Oil Temperature Sensors, Gyro, Shock Position Sensors
Ohlin’s 4-way Adjustable Dampers with custom valving and digressive pistons
ARAM Steering Rack (Raised Pinion)
Updated Composite Floor & Diffuser w/ Rear Aero Tire Kickers
Updated Front Wing Assembly
Updated Swan Mount Rear Wing & Diffuser Pump Wing Assembly
Front & Rear Anti-Roll Bars w/cockpit adjustment
Taylor Race Engineering LSD Differential (updated w/ Stiffener Frame)
Front Wheel Inner Fairings
Custom Engine Cover w/ Shark Fin & cooling exits
Includes a Shop day for training on systems including AiM data, geartronics, Kawi Engine management, Etc
Lots of Spares –( $165k VALUE ) (Inquire for a comprehensive list - Sold Seperately )
5 sets of Jongbloed Wheels
3 spare Kawasaki engines
Enough suspension to replace all corners twice minimum
A-Arms, Pushrods, Toe links are complete w/ rod ends and are jigged.
4 spare uprights complete w/ rotors & calipers
Spare steering arms/camber blocks
Spare Wings - Front & Rear
2ea Spare Front Nose/Wing Assembly
Spare Bodywork
Spare Sprockets & Chain
Much, much, more
Almost an entire cars worth of spares and then some !!! (less chassis)
Serious Inquiries only.
Contact : dave at davecaswell dot com
Phone/Text inquiry : three zero three three two four two three seven five
