Results 1 to 10 of 10
    third stone from the sun
    Liked: 113
    Default Source for caliber O rings
    Looking for O rings to fit an ATE caliber on a Ralt Rt5 1982 , the pucks are 1.65 in /41.9mm in Da. any idea on a source.Thanks,Dee
    Liked: 2061
    Maybe check with Dave Bean?
    Powhatan, VA
    Liked: 171
    Call Keith Averill
    Florida Keys
    Liked: 33
    Default ATE Rebuuild Kit
    The last few ATE rebuild kits I bought (from some west coast buggy shop) were so old the o-rings had turned to dust. I finally gave up and started using square section metric o-rings from McMaster Carr. Check their website, for your dimensions. Only available in Buna-N so not optimal for long life, not a problem if you rebuild seasonally.
    Liked: 2061
    maybe just search for them on the 'net. look at suppliers like Zatkoff.
    Sacramento, California
    Default ATE caliper kits
    Quote Originally Posted by Dee View Post
    Can you post the piston diameters? When I rebuilt my SV calipers, I was able to source new parts from a Porsche aftermarket supplier.
    Liked: 113
    Default Thanks, for the help
    Thanks all, was able to get some from back east and a couple of kits from the UK
    Denver, CO
    Liked: 24
    Default source
    I found EPDM o-rings to fit ATE's at www.theoringstore.com. ordered AS568A 223 for nominal 1.625 id x .125cs. they are round, which their website said can be used in place of square, and they fit/working great.
    by the way, what brake pads are you using in these calipers?
    SeUSA
    @Fleetdude, Round section orings/seals for a brake caliper is not a good idea, they will "seal" but they will not provide the "return" that a square/rectangular seal would, and, the sealing area is much smaller.
    Quote Originally Posted by jkrt125 View Post
    That is correct. Provide them with the piston diameter and groove width:
    PMB PERFORMANCE
    162 W 9240 S
    SANDY, UT 84070 855 786-7104
    Contact This Porsche/ATE supplier for correct seals:
