Results 1 to 5 of 5
    Liked: 1886
    Default Wheel studs for a Z16
    Anyone know a source for studs like the one pictured?
    7/16s-20 at the long end, 12mm - 1.5 at the other, and 1/2" barrel in the middle. 2 inches long.
    Have to replace 4 on a customers rear upright that I just rebuilt.
    mukwonago, wisconsin
    Liked: 96
    They look like they were single pointed and not rolled thread. Just a thought.
    john f
    Tacoma, WA
    Liked: 324
    Can you just change them all to 12mm? That way you can use good quality studs. Unless the wheels are Revolutions, it would be a simple matter of changing the lugnuts
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Liked: 1886
    Yes, I could probably change them all, but getting them out of the hubs is damned near impossible without damaging the hub - the 12mm threads were apparently made oversized a bit to be an hard interference fit into the hub, and on one hub ( one that has been replaced with a new one) to get them out, I'll have to mill away the hub around the threads - not something that I want to do on all 4 hubs, nor would he like the extra expense.
    Liked: 958
    Hello Richard,
    Have you looked at Dorman Products? They show having double ended studs in their automotive catalog similar to what you are looking for.
    https://www.dormanproducts.com/pages...px?origin=menu
    The other source is Prestige Wheel. When the threads in the rear hubs in my Z-10 were worn out, I replaced them with double ended studs. I also bought some 60 deg wheel inserts, then had my revolution wheels counterbored and installed them. Worked great using standard 12mm nuts.
    http://www.prestigewheel.com/Image2800.asp
    Thanks so much for all of your help when I restored my Zink.
    Regards,
    Dan Wise
