Results 1 to 8 of 8
Thread: Honda ecu
    Beaver,PA
    Liked: 24
    Default Honda ecu
    Does the ecu perform in a closed loop regarding a/f and then go to open loop at full throttle?
    greg
    Hartford, WI
    Liked: 230
    Default Wide Band Sensor
    My recollection is that the oxygen sensor is of the wide band design, and therefore the fuel strategy stays closed loop at all times. Disclaimer: I am not 100% confident on this; interested in what the smarter people have to say on this.
    Cumming, GA
    Liked: 230
    Quote Originally Posted by GregPeluso View Post
    greg
    If I recall correctly I think the only thing that changes how the O2 sensor works is water temp: like if it's below the minimum operating temperature (which I think is 167F). Even then it's not as big an issue as if you start running above 210F on water temp (where the engine loses power noticeably).
    Sam Lockwood
    Raceworks, Inc
    www.lockraceworks.com
    Beaver,PA
    Liked: 24
    Works on water temp? How would that figure A/f ratio?
    greg
    Beaver,PA
    Liked: 24
    Is the o2 sensor a stock o2 that I could buy at a parts store?
    greg
    Cumming, GA
    Liked: 230
    greg
    I think it's just inoperable when it's cold. But I'd double check that with HPD.
    Sam Lockwood
    Raceworks, Inc
    Cumming, GA
    Liked: 230
    greg
    Yes, but it's not from the Fit. If my records are correct the part # is 36531rcaa02 (I think it's an early 2000's Accord). The best pricing I've been able to find is from HPD.
    If you've got the fault light hooked up you should be getting a code whenever the engine is running (7 flashes) if the O2 sensor or the wiring is bad.
    Sam Lockwood
    Raceworks, Inc
    Vancouver BC
    Liked: 498
    Looks correct. RockAuto lists equivalent parts for that from about $84 to $130 USD, and shows compatibility with... ...a mid-2000s Accord.
    If anyone needs a PDF of the manual for the ECU, shoot me a PM...
