Results 1 to 6 of 6
    Member Crowe Composites's Avatar
    Chattanooga, Tennessee
    Liked: 32
    Default 2001 Van Diemen RF-01 Zetec
    SOLD
    2001 Van Diemen RF01 Zetec - Chassis #2823
    With everything listed below a lot of spares.
    Located in Chattanooga, TN
    History to the best of my knowledge car was prepared and run in the F2000 Pro Series by the Canadian Brian Graham Team and then purchased by Lindsay Wolfer. His son or grandson worked for Anze and they did shocks and gearbox. I was going to run car but just don’t have time with running my F1000 car.
    I have invested over $2k in car recently:
    Zetec by Quicksilver
    AIM MXL Pro 05 dash was sent for testing/replaced plug-in/new cord/added with GPS
    New (not rebuilt) master cylinders and new slave (Includes bottle of brake fluid I use)
    New fuel pump, injectors, throttle position sensor with used spares that were all working before I replaced.
    All Fluids changed
    Fresh painted side-pods
    Dynamic 3 ways shocks (required by FRP Series) rebuilt by Anze before I bought car.
    Pennon rear Diffuser
    Remote battery set up with plug in on car
    Cockpit has driver side protection panels covered with nomex and seat frame cover
    JABROCK covers underside of car floor full length for the most part
    SPARES:
    Two spare sets of wheels (3 total sets)
    15 gears stacks for tracks and a several dog rings.
    Complete NOSE, WINGS and SHOCK cover PAINTED to match (one nose set up is high downforce)
    Spare rear wing is high downforce
    2 or 3 sets of OEM spare front wing end plates with foots painted to match car
    Used spare working throttle position sensor, injectors, MSD Coil Pack
    New relay
    2 spare alternator belts
    4 rotors. Ran finger across them and I think they are new or have minimal use. Just surface rust from sitting.
    2 extra sets of Eibach spring
    Front sway bar
    Lift jack
    I have odds and ends fasteners etc. I will include
    Note book of all set up info, car manual prepared by Cape Motorsports, Gear box manual, Shock Manual, and a lot of info on Car including gears needed for most tracks in US.
    Other details advertised when I bought car
    Twin disc Tilton clutch
    Diff rebuilt with Cryo treated Diff. by Anze Suspension
    Cockpit adj. front sway
    Cockpit adj. brake bias
    On-board fire suppression
    Ceramic bearings
    Dynamic 3-way adj. shocks. rebuilds by Anze Suspension
    Custom air ducts for oil cooler, starter
    Tilton starter
    Fuel filter
    Reusable oil filter
    JET HOT Coated treated exhaust system
    Custom aluminum oil/water overflow tanks (nice and compact)
    Momo steering wheel with quick disconnect
    Rubber duck radio antenna, radio box, Push to talk on steering wheel.
    Odyssey (military grade) battery
    In the spirit of full disclosure, car has been used, body has some gel coat spider cracks in areas. While not perfect, it’s in nice condition and priced accordingly as is.
    It does need belts and Transponder
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Still for sale?
    Jupiter, Florida
    Liked: 79
    Call ya tonight
    Liked: 32
    Default Car is Sold and will be running the FRP Championship Series
    4/9 Car is for sale as buyer changed mind.
    Liked: 32
    Default Van Diemen RF01 Zetec
    Great deal with a lot of spares. Will package as as desired with or without spares.
    Run
    • SCCA
    • FRP USFF 2000 sanctioned by SCCA Pro
    • Southern Formula Car Series
    • SVRA. I verified with SVRA.
  9. #6
    Liked: 32
    Default Van Diemen RF01 Wide Track Zetec For Sale
    SOLD
    We need garage space. A platform that is still a proven relevant and competitive car that can run:
    • SCCA
    • FRP Pro Series
    • SVRA Vintage
    Michael
    423-888-7125
