Results 1 to 2 of 2
Thread: What is this?
    Az
    Liked: 166
    Default What is this?
    Starting in July SCCA GCR:
    Formula 1000 is a restricted class. Therefore, all allowable modifications, changes, or additions are as stated
    herein. There are no exceptions. IF IN DOUBT, DON’T. Homologation may be required. Refer to 9.2.2. for
    details. All FB Cars competing in Majors Races and the Runoffs must have the AIM part #X47KPFSOLO2R0
    data box mount installed on their vehicle to provide the necessary mounting of the AIM Solo Data box. The
    mounting surface is to be approximately oriented either horizontally or vertically either parallel or perpendicular
    to the longitudinal axis of the car and must be accessible from the exterior of the car with the driver
    on board - it should have a view of the sky, and not be located under carbon fiber or metallic body-work.
    In addition, the mount must not be on wings, and or wing end plates and where possible should be in the
    cockpit. Sufficient space should be left between the mounting plate and the surface to which it is attached
    to permit the use of zip ties/tie straps to restrain the data box to the mounting plate.
    The purpose of this
    requirement is to allow the random placement of data boxes on cars on pre-grid by SCCA assigned personal
    and the collection of the box when the car exits the race track. Contact AIM and their distributors for direct
    purchase.
    Effective date January 1, 2019.
    What data are they collecting and what is the purpose of it?
    Firman F1000
    Az
    Liked: 166
    This got posted twice. See my other thread under New Rule
    Firman F1000
