Results 1 to 25 of 25
    Contributing Member steve everard's Avatar
    Nashville TN
    Default EVO4 + G dash lap times error
    Seem to be getting 0.2 sec per lap difference between G dash and track timing (FRP events.) Mid ohio and VIR ???
    Londonderry, New Hampshire
    Liked: 108
    Are you using the same location as the timing loop?
    Nashville TN
    The map on race studio shows start finish at same point race monitor flashed drivers name so I am thinking yes.
    Buffalo, New York
    Liked: 269
    Is Evo or track showing you faster?
    Where is your transducer and your GPS reviever?
    Nashville TN
    Yes showing that we are faster, GPS is 24 inches behind transponder , Nothing has been moved and this has just become a problem
    Leominster Ma.
    Quote Originally Posted by steve everard View Post
    Steve we were getting same on Jenks car at Mid-Ohio. Aim was always .2 faster.
    Lenny
    Liked: 532
    Curious – is this error cumulative/additive? After 10 laps are you two seconds off from official timing? Do you have any correlating video that you can compare time too?
    Is the error absolutely repeatable at different times and locations? Perhaps some weird atmospherics interfered with the signal on those days?
    Senior Member Pi_guy's Avatar
    New York
    Liked: 234
    My .02 is GPS vs beacon is not as accurate as the GPS result is based on calculations and the other is triggered.
    I have gotten slightly different result time by downloading data to different computers with different processors.
    Buffalo, New York
    Liked: 269
    GPS is actually military. They can code in an error or a delay for strategic reasons. Earth rotation is 19miles per second. 0.2 error is about 3.8 miles, enough for an incoming warhead to miss its target. Just a thought if this is a new phenomena.
    Liked: 108
    All firmware up to date? Where is the GPS mounted?
    Is it a GPS08? In the data, what does it show for the number of satellites and accuracy?
    Buffalo, New York
    Liked: 269
    GPS to transducer distance doesn't make a 0.2 difference. At 60mph 0.2 seconds is 17 feet, more than a car length. Now if it was 0.02 then 2 feet will make a difference. If the EVO timer shows you quicker then I suspect it is the timing system which lags. The GPS calculations are made after the signal is recieved so it doesn't matter how long it takes to calculate.
    North Carolina
    Liked: 42
    He is asking where it is mounted as in "how well does it see the sky" not relative to the transponder. For example if it is mounted near carbon fiber that block the 'sky' it can really challenge the system to keep up.
    Liked: 108
    In my experience, it's not the system keeping up, but the time delay in the signals to the GPS. The signals will bounce around inside the bodywork before getting to the antenna and cause it to read wrong. The time differences in the sat signals is minuscule, so any small error really matters.
    The check of sat count and error usually tells a lot.
    Buffalo, New York
    Liked: 269
    Maybe I misunderstood but isn't the EVO showing a faster time?
    Leominster Ma.
    EVO showing faster .2. First time ever happening for us, 2nd year with car. GPS has been mounted on roll hoop since first lap we ran and have not been moved.
    Vancouver BC
    Liked: 473
    That's referred to as "Selective Availability"...
    ...and the US military turned that off in 2000.
    Liked: 108
    What was the satellite count and error measurement?
    Buffalo, New York
    Liked: 269
    If the EVo shows him faster then it is not an EVO error, no amount of bouncing around, under or going through glass/carbon or metal will make the signal appear sooner. Plus he said it is on his roll hoop. Source is bad signal reception by AMB.
    Leominster Ma.
    Can bad signal reception by AMB be corrected ?
    Liked: 108
    In my experience, when the receiver gets a bad signal, it creates all kind of lap timing problems. It will lose position, create short laps, etc. It's normally not like the OP posted, but I haven't heard of an AMB transponder all the sudden going .2 seconds faster either.
    Buffalo, New York
    Liked: 269
    The AMB is slower. I've seen it happen many times at many tracks. We time our cars manually and many times the AMB times are off.
    But the good news is they are off for everyone and finishes are supposed to be sight, not AMB time.
    Nashville TN
    # SATELITES IS BETWEE 7 AND 10, ACCUACY 1.24-1.78m
    Nashville TN
    Default Big Clue
    I compared aim data timing and race monitor(which I assume uses track amb)
    I made sure I did not just overlay lap 1 aim with lap1 race monitor because they display differently,
    example: lap 3 shows faster on race mon 0.254 then next lap minus 0.255 like it corrected itself. similar on other laps.
    Liked: 4363
    This is not my topic of expertise, but since no one else has identified the exact problem, I will offer a theory.
    At some tracks on some days, our aim system misses inserting a break in our data at the finish line. What we often do, is open up the radius on our GPS coordinates, so that there is a larger target for us to drive through and have the the break inserted. When we do this, we are sacrificing some accuracy. So for example, we may have our break inserted at different times, depending on where we are on the track width. If we were on the right side of the track, we would get the break inserted as we entered our target zone. If we entered our target zone in the middle of the track, the insertion may be phased slightly differently. If, for another example, there was a overhanging starter stand, as at M-O, our insertion point may be delayed. With overhanging trees, buildings, fencing, cloud cover, etc, if your quantity of satellite signals are reduced, perhaps some irregularities are occurring,
    I would suggest that the AMB was accurate, and your GPS performance was being compromised. Your AIM system is not correcting itself, but reacting to the GPS inputs.
    Perhaps your video may offer some clues, but if it was me, I would shrink my GPS zone some, and relocate my GPS antenna to get more satellite inputs.
    If my theory is nonsense, be kind. Cheers!
  26. #25
    Nashville TN
    I checked video and crossing start fin line same point ie not beneath overhang flag station
