Page 10 of 11 FirstFirst ... 67891011 LastLast
Results 361 to 400 of 434
  1. #361
    Harrow, Ontario CA.
    Liked: 23
    Default FF Gear Ratios
    Good evening to all
    Does anyone know the gear ratios used at the Cdn GP Circuit in Montreal for a Formula Ford ?
    I have a 9 / 31 ring and pinion, but what ever information I can get would be most helpful....I can do the conversion if your information in for a 10/31
    Dave McGinnis
  2. #362
    Placentia, CA
    Liked: 341
    Quote Originally Posted by McGinnis View Post
    Good evening to all
    Dave McGinnis
    I have never been there so I cannot vouch for it but from the thread 'The Perpetual "What Gearing Do I Run at This Track?" Thread'
    http://www.apexspeed.com/forums/sear...archid=1205570
    "The Arizona group that goes to Montreal each year runs these:
    Montreal
    1st 18:33 1.833
    2nd 21:30 1.429
    3rd 23:27 1.174
    4th 25:26 1.04"
    Eric Little
  3. #363
    Liked: 1218
    The hairpin is surprisingly slow - even for the F1 cars. With a 17:35 first I was nearly tracking out before having to shift up, would recommend a tooth taller for a better driver.
    The straight after that goes on forever. My Crossle' hit terminal velocity at 6600 RPM with 25:26. A slicker car, a good tow, a fresher motor might need 25:25.
    YMMV but that's a good place to start.
  4. #364
    Buffalo, New York
    Liked: 269
    I am running CTMP (Mosport) in a few weeks in a club ford on vintage hoosiers, I have the following ratio's recommended for a 9:31:
    17/34 2.0
    20/31 1.55
    22/28 1.27
    25/27 1.08
    i realize Moss is a very slow corner but 17/34 seems awful low...input?
    Thanks, Robby
  5. #365
    Fallen Friend
    East Haven, Connecticut
    Nevermind. Wrong Track
  6. #366
    Senior Member Wes Allen's Avatar
    Lexington,Ky.
    Liked: 64
    Default need gears for watkins glen
    Hi All,
    I need gear choice for Watkins Glen long course. 10:31 Club Ford
    Thanks Wes
  7. #367
    Asheville, NC
    Liked: 115
    Default IMS GP Course - SVRA CF on Treads 9.31
    Going to Indy first time. Not certain these are best but this is what I'm thinking below. We don't normally run 1:1 top but watching lots of videos, it looks like with a good tow you'll run out of gear with a 25:26.
    20:32, 22:29, 24:27, 25:25. 9.31 CWP
    Thoughts? Is first too long?
    Thanks! Pretty excited.
    JG
  9. #368
    St Augustine, FL
    Liked: 34
    17/34 2.0
    20/31 1.55
    22/28 1.27
    25/27 1.08
    Thanks, Robby
    That is the gearing given to me by a person who ran a FF at Mosport.
    chris
  10. #369
    Contributing Member Bernard Bradpiece's Avatar
    Annapolis, Maryland
    Liked: 185
    Wow, looks awfully low - guess if you are revving to 7500 or 8000 you should be OK. Lower than Lightening and Thunderbolt. First is lower than Summit or VIR both have 2 slow turns. Robby, I would gear higher and just go faster around the slow turns. Anyone else offering help here?
    BB
  11. #370
    Liked: 1681
    Default FC gears for Barber?
    anyone have a suggestion?
  12. #371
    Santa Fe, NM
    JG, One of our NM drivers used this set and was very successful A bit hard to get out of the paddock he said.
    INDY Road 19/32 21/29 24/28 25/26
    By comparison I ran
    18/33 20/30 23/29 25/26
    and was off the power band more than I liked.
    Hope that helps
    Larry
    Larry H
    Santa Fe, NM
    4- Elden MK10
  13. #372
    Asheville, NC
    Liked: 115
    Thanks, Larry. Sure does. John
    Quote Originally Posted by lch Racing View Post
    By comparison I ran
    Hope that helps
    Larry
  14. #373
    Senior Member Nardi's Avatar
    Southeast
    Liked: 126
    Default X-2!
    Rick Kirchner asked about gears for Barber the other day so that makes 4 people in FC who want to run Barber in August.........and they have NEVER BEEN THERE BEFORE.......plus they will be making LONG TOWS......and they really want to help support the SOUTHERN CONTINENTAL CHALLENGE aka Brad's series which in turn helps FC CAR COUNTS in addition to OVERALL FORMULA CAR COUNTS!!!
    Ok, that's the best whining I can come up with........... Somebody throw us a bone! Please?
  15. #374
    Ofallon, MO
    Default Mont Tremblant ratios
    Going to the HMSA event at Mont Tremblant in July. Gear ratio suggestions, anyone? 9:31 Diff, 1975 Zinc Club Ford. Thanks.
  16. #375
    Liked: 1218
    I did pretty well with
    17:35 20:31 22:28 24:26
    Better driver might need a tooth taller - the back straight goes slightly downhill before the braking zone, and Namerow winds out in first before any comfortable place to shift.
  17. #376
    PA
    Default Thunderbolt NJMSP
    Hi
    I searched the thread, but no answer to Thunderbolt at NJMSP.
    Can someone supply the gearing for 9 31 ring and pinion.
    Greg Kokolus
  18. #377
    Contributing Member Andrew Stein's Avatar
    East Varick, NY
    Default NJMP Thunderbolt
    Greg:
    Here's the link to a separate thread from 2013: http://www.apexspeed.com/forums/show...erbolt-8-17-18
    I've also received recommendation from BB2 who last ran the track on Avons, and is a little different than those provided on the above link. He ran 20:31, 22:29, 23:27 and 25:26.
  19. #378
    Senior Member AVR_Shane's Avatar
    Barrie, Ontario, Canada
    Liked: 200
    Default Road America
    From Jake Lamont's book, a great source of info for every FF'er:
    18/34 20/30 23/29 25/27 with 10/31
    Looking into Road America gearing and found this. Anybody know what tires and era car this would be for? I'm looking for gearing for a club ford on dunlops
    Shane Viccary
    #27 Citation-Zink Z-16
  20. #379
    Liked: 931
    That was for a "modern FF" although Jake's book is almost 20 years old.
    The tires were the bias ply Hoosiers that I used back in the days of the 40th. My car is a DB6. I think I changed my 3rd a little but the other gears were fine.
    Quote Originally Posted by AVR_Shane View Post
  21. #380
    Los lunas NM
    Default Texas motor speedway
    We are going to Texas motor speedway for the first time in a vintage formula ford. Does anyone have gears suggestions?
  22. #381
    San Antonio, TX
    Liked: 40
    Default TMS Gears
    [QUOTEWe are going to Texas motor speedway for the first time in a vintage formula ford. Does anyone have gears suggestions?[/QUOTE]
    Per Mike Sauce, who I believe holds the lap record there:
    10/31 R&P
    18:34
    20:31
    23:28
    24:26
    Hope this helps
  23. #382
    Vancouver BC
    Liked: 498
    Quote Originally Posted by Woodracing29 View Post
    Quote Originally Posted by GregSmith View Post
    10/31 R&P
    18:34 [(1.8889)]
    20:31 [(1.5500)]
    23:28 [(1.2174)
    24:26 [(1.0833)]
    Hope this helps
    I bought my car from a guy who only raced it (as in once) at Texas Motor Speedway and my gears were;
    16:29 (1.8125)
    20:30 (1.5000)
    19:24 (1.2632)
    24:26 (1.0833)]
    So very similar to what you were just told except for 3rd gear. Could there have been a typo, Greg?
  24. #383
    San Antonio, TX
    Liked: 40
    16:29 (1.8125)
    20:30 (1.5000)
    19:24 (1.2632)
    24:26 (1.0833)]
    Nope, that’s what Mike told me. He also mentioned that 2nd gear is the really important one, as that’s the gear used in the two “horseshoe” turns in the infield. I’ve driven it in a Vee several times in the past, this will be my first in a Ford. Pretty slow infield but you really get moving by the time you get to turn one.
  25. #384
    PLANO
    Liked: 35
    If anyone would know that track , It would be Mike
    I ran the ratios . 10-31 @6800 with a 22.5 tire
    MPH and RPM drops at the bottom of the chart
    Scotty
    Est. 1990
    Taylor Race Engineering
  26. #385
    Vancouver BC
    Liked: 498
    Quote Originally Posted by SCOTTY81 View Post
    Interesting.
    What's the reason for the big jump between 2nd and 3rd? Is it optimizing for a couple of important corner exits?
    Just trying to understand this stuff better.
  27. #386
    PLANO
    Liked: 35
    Not for sure Alan . If they are running the old SCCA lay out , You turn into the infield half way on the back straight .
    Then you reenter almost the the same spot .
    Scotty
    Est. 1990
  28. #387
    Muleshoe, Texas USA
    Liked: 257
    Default Tms
    Starting out with:
    19 32
    22 30
    24 27
    26 26 on a 9:31 in my Titan - hope to see you there.
    What car will you be in Woodracing29?
    JM
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
  29. #388
    Los lunas NM
    Default Thank you everyone.
    We will be running the 063 Crossle 25. Thank you to everyone who helped us.
    Quote Originally Posted by Messenger Racing View Post
    Starting out with:
    19 32
    22 30
    24 27
    JM
  31. #389
    Trois-Rivieres
    Thanks to everyone who is sharing their gears ratio. I would like to learn how to select the good ratio by myself. I already have spreadsheet to help me but is there any doc I can read to understand how does is work?
  32. #390
    Sequim, WA (USA)
    Liked: 35
    Default A incomplete spreadsheet from this thread...
    Hi all:
    I have started compiling a spreadsheet of the gearing recommendations from this thread and other sources. It is geared to my Tiga FFA-77 with American Racer slicks, but I think it would work for other 9:31 gearboxes, as well.
    I've attached it as a .xls file...
    It's just a start - feel free to change, fix, etc.
    Regards,
    James
    FF Gears for North American Circuits rev 1-20-20.pdf
    Tiga FFA-77 s/n 38
    fred short motor racing
    "Turning money into noise for over 2/100 of a century"
  33. #391
    Sequim, WA (USA)
    Liked: 35
    Default Excel files apparently aren't liked...
    I couldn't attach the live Excel file - so I uploaded a .pdf version.
    Please email me fshortATflashDOTnet for the Excel version.
    Also, a list of gears currently available.
    Mk 9 Gear Ratio Chart.pdf
    Tiga FFA-77 s/n 38
  34. #392
    Prescott, AZ
    Liked: 202
    Default Sandia , Abq, NM gearing
    I would appreciate suggestions for club 1.6 Kent and 2.0 pinto.
    Thanks!
  36. #393
    Phoenix, AZ
    Liked: 79
    Default Sandia
    For an 85 Van Diemen FF Sandia with a 9/31; I used 15-36 17-34 20-32 22-29 I recall wanting a lower first.
    Tight track that powders off track. I recall running off track at one point and having waves of powder coming over the nose and over me. Like a boat in a storm. Very tight track but fun in October 2015.
    Jim Edmonds
    Phoenix, AZ
  37. #394
    Santa Fe, NM
    Thanks!
    I run 16:36, 18:32, 20:30, and 23:29 with a 10:31r&p in my Elden FF at Sandia, home track.
    Sean Guthries advice several years ago was: 14/36, 17/34, 20/32, 22/29. if you don't have a real low 1st then 17/35, 19/33, 20/30, 22/29 and run 3 gears.
    I would have to dig for my F2000 gears but if I recall they are similar.
    Hope to see you there as soon as we can open up. If I can help w/anything let me know by pm.
    Larry H
    Santa Fe, NM
    4- Elden MK10
  38. #395
    New Jersey
    Liked: 40
    I am thinking of running CF at the upcoming Barber race. Any recommendations on gear ratios? I didn't find any when searching.
  39. #396
    Kansas city
    Liked: 22
    Default Cota
    Does any one have good Cota gears for VFF or CFF? All we seem to have on the data base is "should be Atlanta gears with slightly taller 1st". Thanks!!-BGG
  40. #397
    Phoenix, AZ
    Liked: 79
    In my RF94 10/31 I've run 17/33 19/31 20/27 and 24/27 Not a bad place to start.
    YMMV
    Have fun today
    Jim Edmonds
    Phoenix, AZ
  41. #398
    Liked: 1218
    In 2018 with my Crossle' 30/32/45, a soft redline of 6500 and a 9/31 I was pretty happy with
    18:33 20:30 23:29 25:27
    but I was turning 6800 at the end of the back straight and could have used higher corner entry speeds several places so planned for 2019 to run
    18:32 21:31 23:28 25:26
    Unfortunately never got to try it, but that's another story.
  42. #399
    Contributing Member Gary Godula's Avatar
    Farmington Hills, MI
    Liked: 66
    Default Pitt Race Gearing
    Does anyone want to share their gearing for Pitt Race running the Hoosier radial and a 10/31 R&P?
    Gary Godula
    '88 Reynard FF88
    SCCA Club Racing / Solo #57 FF/CM
  43. #400
    Muleshoe, Texas USA
    Liked: 257
    Default Carolina Motorsports Park - CMP
    We are looking at running Carolina Motorsports Park - CMP in a FF with Hoosier radials. Anyone with a starting point?
    TIA,
    Jay Messenger
    Messenger Racing Team
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
There are currently 38 users browsing this thread. (0 members and 38 guests)
