Page 2 of 2 FirstFirst 12
Results 41 to 42 of 42
  1. #41
    Liked: 1481
    Quote Originally Posted by xmazdatracy View Post
    How come these guys don’t make a 10.5lbs one? Has no one asked, or should I email them about it? I don’t want to shave mine down, since I want to remove the weight from the outer most part of the f/w.
    Other than the GCR saying: @ 15C
    The flywheel shall be a standard component or the approved alternate Elite-001. The minimum
    weight is 10.5 lbs. with ring gear. The flywheel may be machined to achieve minimum weight. Spot
    machining to achieve balance is permitted. Flywheel bolts are free and locating dowels are permitted.
    Would those (even at 10.5) be considered a standard component?
    I consider a crank a standard component in any engine, but the fact that they use those terms....
  2. #42
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    Update:
    Emails sent to Burton Power, Turbo Sport, and Elite. No response by all three.
    Any other ideas where one could find a new 10.5lbs pinto flywheel?
