    Cumming, GA
    Liked: 215
    Default Formula Mazda parts for sale
    Trying to get rid of the last bits of my Formula Mazda inventory as I do early "spring cleaning" at the shop:
    Bare standard frame, jigged, needs some paint touch-up in some spots: $1,000
    "Tall Man" frame with front bulkhead, master cylinders, brake & clutch lines, partial shift linkage, interior sheet metal, AMB transponder, wiring harness & switch panel, steering column, stainless belly pan, inner radiator shrouds, oil & fuel lines. Also has SCCA logbook & chassis ID plate (serial # 00-200): used $2,000
    Center cowl with mirrors, yellow, used in good condition: $300
    2 Noses, used in good condition. One are yellow in good condition for $150, one is yellow/white & could use some repair on the lower front $100.
    Engine cover, used in good condition. Yellow. $250
    Rear lower shock mounts, 2 each left & right: $50 each.
    1 Used rear hubs with drive pins, $200 each.
    6 #5 shear plates, $12 each
    Weber DCOE jets & other parts. Wide range of idle, air corrector, pump, and main jets as well as emuslifier tubes and various other small parts. Well over 100 pieces. $500
    1 used outer rear wheel halves, $80 each
    2 used inner wheel halves, $80 each
    3 new front swaybar sliders, $26 each
    5 aluminum front upper comp spacers, $4 each
    5 front swaybar drop links, $15 each
    4 front upright pin spacers, $3 each
    2 shock spacers (3/8), $2 each
    3/8 tapered spacer, $2
    Used wheel centers, used and pin holes refurbished using the drill & press-in kits previously sold by MSR, 7 in the older style centers at $150 each, 6 newer style centers $200 each.
    Front gurney material. One is enough for a single gurney & painted white, $4. Two more are enough for two gurneys each, $9 each.
    5 front gurneys, trimmed for left side, one painted white & the rest plain, new $4 each
    1 front gurney, trimmed for the right side, used & painted yellow, $2.
    1 pieces rear gurney material, new & plain, $9 each.
    Pair of left & right sideskins, in good condition, $140.
    Oil injection pump with lines. Pump is good but one line is missing a banjo end. $100
    2 intake manifolds, used, $180 each.
    NEW complete DCOE carburetor with chokes, may need some setup, $600
    Complete DCOE carburetor with chokes & air filter stack. This one was set up & running with our jet setup (the one that can actually idle for a while without fouling). $500
    Used Facet fuel pump with weatherpack connector & AN adapters, $50.
    Factory wiring harness (part # 080-112), new, $20.
    2 shift fingers, one unused, one drilled for 5/16" bolt, $80 each.
    6 short shock bump rubbers, $11 each.
    Used engine spider with hardware, $140
    Used fuel pressure regulator, $20
    Pair of used Bosch blue coils, $60
    Used clutch slave cylinder with adapter & mounting bracket, $50
    3 #6 shear plates, $13 each
    2 adjustable rev chips $15 each
    Photos of all this stuff are available here: https://www.facebook.com/media/set/?...1&l=74d73e7163
    Prices don't include shipping. You can also pick up at the shop or I can load them with me when I travel to the track.
    Sam Lockwood
    Raceworks, Inc
    www.lockraceworks.com
    Madison, Wi.
    How much of this stuff do you still have?
    Cumming, GA
    Liked: 215
    From memory, that's what I've got left. I may have sold some of the bump rubbers but I'll have to get in the shop tomorrow to be sure.
    Sam Lockwood
    Raceworks, Inc
    new jersey
    You wouldn't happen to have any 1st gen rear lower control arms kicking around would you?
    Cumming, GA
    Liked: 215
    I do not.
    Sam Lockwood
    Raceworks, Inc
    Milwaukee, Wisconsin
    Liked: 22
    Im interested in the good condition side pods, engine cover, and one nose. Is there any damage that would need to be repaired before installing on car? Would you be willing to ship these parts? Any idea how bad it would be to Milwaukee WI? Thank you.
    Arizona
    Default center section
    I do not.
    Hello hope all is well. do you still have the center section to the formula mazda if so what year? se need the older model not the pro mazda. mvellone@cox.net
