Results 1 to 15 of 15
    arkansas
    Default Suzuki code reader
    Has anyone had any luck coming up with a code reader for the Suzuki motor. The bike people just use the dash for flash codes, but this won't work on the f1000. I can rig up a test connector if anyone knows what protocol Suzuki uses for the SDS. My car has started randomly dieing on the track but it won't due it in the shop. I am hoping some code might point me in the right direction. When it dies it will not restart with the clutch out but will start right back with the starter button.
    Eric
    Hartford, WI
    Liked: 237
    Default One call...
    Call George Dean at GDRE (425) 778-4431
    He can give you some suggestions for a remedy for your symptoms. He may have some cheats for reading the DTC's as well.
    Is it killing quickly and completely, or sputtering/stumbling/then dying?
    Marietta, GA
    Quote Originally Posted by Jon Jeffords View Post
    This is very good advice. George is fantastic
    arkansas
    It shuts off like you turned of the switch. I suspect the crank sensor, but can't confirm.
    Hartford, WI
    Liked: 237
    Default Hmmm...
    Per a recent conversation with George regarding the 07/08 GSXR-1000:
    1. The only sensor that will kill the engine outright when it goes bad is the crank position sensor. All the other sensors will still allow the engine to run if/when they go bad, but at a reduced performance level.
    2. A failed sensor will frequently pass a volt-ohm meter bench test. Don't trust the positive VOM results; replace the suspect sensor with new when troubleshooting.
    The fact that it dies quickly without a stumble points a little more to an electrical issue rather than fuel delivery. You indicated "When it dies it will not restart with the clutch out but will start right back with the starter button." So if it suddenly dies with the clutch engaged (engine and rear wheels turning) it will not restart on its own, but if you push the clutch pedal down (disengage the clutch) and hit the starter button, it will start right up without hesitation and have full performance? Is this correct?
    Could this be due to a tip-over sensor that was never filled with epoxy?
    arkansas
    Have checked the tip sensor, it is filled and I can not shake it, tip it or anything else and make the car die. The car would restart with the starter button only. Dragging the wheels would not restart, but after three or four restarts with the button it would fail to restart and I would have to be pulled off the track. It would restart before I could get the body panels off to check it.
    Alpine California
    Liked: 273
    My guess is a bad crank position sensor.
    I'm going to assume you tried a different ECU?
    Is this car equipped with a Geartronics or Flatshifter?
    Gary Hickman
    Edge Engineering Inc
    FB #76
    arkansas
    It does have a flat shifter.
    Alpine California
    Liked: 273
    Quote Originally Posted by strosek View Post
    As I recall the Flatshifter does a coil cut.....or is it fuel? Could this somehow be the cause?
    I'd at a minimum remove it from the circuit just for trouble shooting process of elimination...or maybe you've already done that.
    Other than the Crank pos. sensor the Suzuki 07/08 is near bullet proof. Frankly I've only had one CPS go bad in 9 years of running this config.
    Gary Hickman
    FB #76
    Florida
    Liked: 280
    The Flatshifter does a coil cut. I had this problem when the Flatshifter control box would get hot. Problem goes away when box cools down. Moved box to a cool location and helped but did not eliminate the issue.
    Ciao,
    Joel
    Piper DF-5 F1000
    Hartford, WI
    Liked: 237
    Default Overheating Flatshifter control box?
    Eric, your previous comments below would seem to be consistent with jhc's experience in which the Flatshifter control box is overheating and causing an unwanted ignition coil cut.
    "My car has started randomly dying on the track but it won't do it in the shop."
    "…after three or four restarts with the button it would fail to restart and I would have to be pulled off the track. It would restart before I could get the body panels off to check it."
    arkansas
    Yes that is a possibility. The last time I got towed off the track I had left the body panel off so I could get to thing quickly, I have the Flatshifter plugged into the ign coils with male and female spades so I can remove quickly, I took it out of the loop and it still would not start. After messing with the car for about ten minutes it started and ran again. I am planning on using a heatgun on the cranksensor and see if I can get a fail. I will try the same on the Flatshifter.
    Alpine California
    Liked: 273
    Don't you just love chasing intermittent problems down, especially electrical
    Gary Hickman
    FB #76
  15. #14
    Senior Member JJLudemann's Avatar
    Thailand
    Liked: 36
    Default Suzuki GSX-R1000 ECU Communications Protocol
    If you're really interested in using the Suzuki ECU protocol, here's a file full of notes I gathered from various places on the internet while doing the same thing. I was successful. If you're using an Arduino, I could send you the code to do it. Good luck!
    -JJ
    https://forum.arduino.cc/index.php?topic=236092.30
    Here are the steps that need to happen. In my case, I used a variable called mode to step through my code.
    1. fastinit(); Using pinmode, and HIGH and LOW
    2. send message = 0x81,0x12,0xF1,0x81,0x05
    3. wait for response 80 F1 12 03 C1 EA 8F C0
    4. send data request 0x80,0x12,0xF1,0x02,0x21,0x08,0xAE
    5. read incoming data "I believe you will receive 56 bytes back
    6. store results
    7. repeat steps 4 through 6 over and over as long as you are getting response from the ECU.
    I am not sure how to properly stop communication but, I do know that there is a message that can be sent to do it.
    /////////////// decoding protocol values ///////////////////////////////////////
    /////////////// mode 2 (read Values) //////////////////////////////////////////
    int const engine_value[9] = {
    ((rx_data[15] / 50.5) * 9.2) - 14.7,
    (rx_data[17]*256 + rx_data[18]) / 2.56,
    125*(rx_data[19]-55)/(256-55),
    rx_data[20]*4*0.136,
    1.1 * (rx_data[21] - 15),
    1.1 * (rx_data[22] - 15),
    rx_data[23] - rx_data[20]*4*0.136,
    rx_data[24]/12.7,
    rx_data[26],
    String const engine_value_desc[] = {
    "boost ",
    "rpm ",
    "tps ",
    "ip ",
    "ect ",
    "iat ",
    "iap ",
    "bat ",
    "gear ",
    Boost: 15
    RPM: 17
    Throttle Position: 19
    Intake Air Pressure 1: 20
    Engine Coolant Temp: 21
    Intake Air Temp: 22
    Intake Air Pressure: 23
    Battery: 24
    Gear: 26
    Intake Air Pressure 2: 27
    Second Throttle Pos: 46
    RPM = Value*100/255
    Throttle position (°) = Value*125/255
    Manifold pressure = (Value*5 - 153)*133/4/255
    Temperature (C) = Value*160/255 - 30
    Temperature (F) = Value*288/255 - 22
    Voltage = Value*20/255
    Secondary throttle position (%) = Value*100/255
    EXCVA sensor = Value*100/255
    http://ecuhacking.activeboard.com/t2.../sds-protocol/
    Command Response
    Wakeup
    81 12 F1 81 05 80 F1 12 03 C1 EA 8F C0
    Model number? Model number
    80 12 F1 02 1A 9A 39 80 F1 12 12 5A 9A 33 32 39 32 30 2D 31 38 48 32 00 00 00 00 00 00 99
    Request Model number
    80 12 F1 02 1A 91 30 80 F1 12 12 5A 91 33 32 39 32 30 2D 31 38 48 32 2A 00 00 00 00 00 BA
    Keep alive Pair repeats forever
    80 12 F1 01 3E C2 80 F1 12 01 7E 02
    Data Monitor Returns 21 sensor values
    80 12 F1 02 21 08 AE 80 F1 12 34 61 08 0C 16 50 E0 17 50 E1 FF FF FF FF 00 00 01 FF 00 00 FF 00 FF 00 FF
    7C FF 00 00 00 00 00 00 00 00 FF FF 40 40 40 40 FF 00 FF FF 26 00 00 01 22 FF FF D0
    Disconnect
    80 12 F1 01 82 06 80 F1 12 01 C2 46
    From Tester: 80 12 F1
    From ECU: 80 F1 12
    4th byte: # Data bytes
    Last byte: Checksum = sum all bytes && FF
    Command bytes are responded with same byte OR'd 0x40
    Tester: F1
    ECU: 12
    ISO 14230-2 Commands
    10 Start Diagnostic Session
    11 ECU Reset
    12 Read Freeze Frame Data
    13 Read Diagnostic Trouble Codes
    14 Clear Diagnostic Information
    17 Read Status Of Diagnostic Trouble Codes
    18 Read Diagnostic Trouble Codes By Status
    1A Read Ecu Id
    20 Stop Diagnostic Session
    21 Read Data By Local Id
    22 Read Data By Common Id
    23 Read Memory By Address
    25 Stop Repeated Data Transmission
    26 Set Data Rates
    27 Security Access
    2C Dynamically Define Local Id
    2E Write Data By Common Id
    2F Input Output Control By Common Id
    30 Input Output Control By Local Id
    31 Start Routine By Local ID
    32 Stop Routine By Local ID
    33 Request Routine Results By Local Id
    34 Request Download
    35 Request Upload
    36 Transfer data
    37 Request transfer exit
    38 Start Routine By Address
    39 Stop Routine By Address
    3A Request Routine Results By Address
    3B Write Data By Local Id
    3D Write Memory By Address
    3E Tester Present
    81 -> xx xx Start Communication
    82 Stop Communication
    83 Access Timing Parameters
    85 Start Programming Mode
    Fastinit:
    ______ _____ ____ ____
    ----------\_____/ \/\/\/\/ \/\/\/\/
    300ms 25ms 25ms packet response
    1) Wait for 300ms with K line high.
    2) Pull K line low for 25 +/- 1 ms
    3) Let K line rise high and wait 25ms
    4) init serial connection to 10400 baud, 8N1, 1=0Volt 0=12Volt, least significant bit first
    5) send package c1 33 f1 81 66 33=dest, f1=our tester id, 81=start comms
    6) wait for response 83 f1 01 c1 e9 8f ae 01=physical address, c1=response ok (7f=fail), e9=kb1, 8f=kb2
    Slowinit:
    _______ S ___ 2 3 ___ 6 7 ___ ___ ____
    ------------\_/0 1\___/4 5\___/P \/\/\/\/ \/\/\/\/
    300ms 200 400 400 400 400 250 packet response
    2) send a byte 33 hex at 5 baud. 200ms per bit
    startbit: 200ms low
    databit0,1: 400ms high
    databit2,3: 400ms low
    databit4,5: 400ms high
    databit6,7: 400ms low
    stopbit+pause: 250ms high
    The comm protocol itself was figured out by RR several posts back. Basically its:
    Command 80, destination, source, # of data bytes, data bytes, checksum.
    The starting packet is a little different, using Command 81 instead of 80 and not showing a data byte count.
    http://freediag.sourceforge.net/Scantool-Manual.html
    Data Monitor Response
    Byte Value
    1 80
    2 f1
    3 12
    4 34
    5 61
    6 08
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18 RPM Hi
    19 RPM Lo
    20 TPS
    21 IP
    22 ECT
    23 IAT
    24 AP
    25 Batt
    26 O2
    27 Gear
    28
    29 Idle Speed Target
    30 ISC Valve Position
    31
    32 Fuel Hi 1
    33 Fuel Lo 1
    34 Fuel Hi 2
    35 Fuel Lo 2
    36 Fuel Hi 3
    37 Fuel Lo 3
    38 Fuel Hi 4
    39 Fuel Lo 4
    40
    41
    42
    43
    44
    45
    46
    47 STP (Secondary Throttle Pos)
    48
    49
    50
    51 Mode ABC
    52 PAIR
    53 Motor Start / Clutch
    54 NT mumble_on
    55
    56
    Packets
    Send command packet:
    header: [c0+cmdlen] [destination=33] [source=f1]
    data: [cmd0] [cmd1] ... [cmd(cmdlen-1)]
    checksum: [sum(header)+sum(data)]
    cmd0 = service ID
    cmd1 = PID
    Received response packet on success:
    header: [80+datalen] [destination=f1] [source=01]
    data: [40+cmd0] [cmd1] ... [cmd(cmdlen-1)] [result0] [result1] ... [result(datalen-cmdlen-1)]
    Received response packet on failure:
    data: [errorcode=7f] [cmd0] [Response Failure Code, see below]
    Multibyte data is sent high byte first.
    Tester Commands
    request and response packet diagram format:
    cmd0 cmd1 ... -> result0 result1 ... comment
    Note: only the data of the request and only the result of the response are show.
    yy 00 -> xx xx xx xx bitmask of capabilities for mode yy, bit7 represents pid 1, bit6 pid 2, etc, if
    data4:bit0 is set then pid 20 contains capabilities for pid 21-40
    00-0F: SAE J1979 Diagnostic Test Modes
    01 00 -> xx xx xx xx capabilites
    01 01 -> [b7: MIL light, b0-6: dtc count] [b4-7: readiness] [b5: o2monitoring] [b0-7: readiness]
    01 03 -> xx xx Fuel System Status bitmap b0:Open, b1:Closed, b2:Open-Driving, b3:Open-Fault, b4:Closed-Fault
    01 04 -> xx Calculated Load Value % x*100.0/255
    01 05 -> xx Engine Coolant Temperature C x-40
    01 06 -> xx Short term fuel trim Bank 1 % x*(100.0/128)-100
    01 07 -> xx Long term fuel trim Bank 1 % x*(100.0/128)-100
    01 08 -> Short term fuel trim Bank 2 % x*(100.0/128)-100
    01 09 -> Long term fuel trim Bank 2 % x*(100.0/128)-100
    01 0a -> Fuel Pressure kPaG x*3
    01 0b -> xx Intake Manifold Pressure kPaA x
    01 0c -> xx xx Engine RPM RPM x*0.25
    01 0d -> xx Vehicle Speed km/h x
    01 0e -> xx Ignition timing advance Cyl #1 deg X*0.5-64
    01 0f -> xx Intake Air Temperature C X-40
    01 10 -> xx xx Air Flow Rate gm/s X*0.01
    01 11 -> xx Absolute Throttle Position % X*(100.0/255)
    01 12 -> xx Commanded secondary air status
    01 13 -> xx Oxygen sensor locations bitmap b0=sensor1, b1=sensor2, ..., b7=sensor8
    01 14 -> xx yy Bank 1 Sensor 1 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 15 -> xx yy Bank 1 Sensor 2 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 16 -> Bank 1 Sensor 3 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 17 -> Bank 1 Sensor 4 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 18 -> Bank 2 Sensor 1 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 19 -> Bank 2 Sensor 2 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 1a -> Bank 2 Sensor 3 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 1b -> Bank 2 Sensor 4 Voltage/Trim V, % x*0.005, if y!=ff then y*(100.0/128)-100)
    01 1c -> xx Auxiliary Input Status bitmap b0:PTO Active
    01 20 -> xx xx xx xx capabilities
    01 21 -> xx xx
    02 00 00 -> xx xx xx xx capabilites SMART: 2 3 4 5 6 7 b c d
    02 02 00 -> [dtc1h] [dtc1l] DTC that caused freezeframe
    03 -> [dtc1h] [dtc1l] 00 00 00 00
    05 00 00 -> xx xx xx xx capabilites
    06 00 -> xx xx xx xx capabilites
    06 yy -> [max=01,min=81] [valH] [valL] [limitH] [limitL] example 01 00 23 01 2c is value 23 (=35 dec)
    with limit maximum 12c (=300 dec)
    06 01 -> xx xx xx xx xx ncms
    06 02 -> xx xx xx xx xx ncms
    06 09 -> 01 xx xx xx xx -> 81 xx xx xx xx ncms
    07 -> 00 00 00 00 00 00 cms
    08 00 00 00 00 00 00 -> xx xx xx xx capabilites SMART: none
    09 00 -> 01 30 00 00 00 capabilites 5 bytes???
    11 ECU Reset
    1A Read Ecu Id
    26 Set Data Rates
    27 Security Access
    34 Request Download
    35 Request Upload
    36 Transfer data
    3E Tester Present
    Response Failure Codes
    10 General Reject
    11 Service Not Supported
    12 Sub Function Not Supported - Invalid Format
    21 Busy - repeat Request
    22 Conditions Not Correct Or Request Sequence Error
    23 Routine Not Complete Or Service In Progress
    31 Request Out Of Range
    33 Security Access Denied - security Access Requested
    35 Invalid Key
    36 Exceed Number Of Attempts
    37 Required Time Delay Not Expired
    40 Download Not Accepted
    41 Improper Download Type
    42 Can Not Download To Specified Address
    43 Can Not Download Number Of Bytes Requested
    50 Upload Not Accepted
    51 Improper Upload Type
    52 Can Not Upload From Specified Address
    53 Can Not Upload Number Of Bytes Requested
    71 Transfer Suspended
    72 Transfer Aborted
    74 Illegal Address In Block Transfer
    75 Illegal Byte Count In Block Transfer
    76 Illegal Block Trasnfer Type
    77 Block Transfer Data Checksum Error
    78 Request Correcty Rcvd - Rsp Pending
    79 Incorrect Byte Count During Block Transfer
    80 Service Not Supported In Active Diagnostic Mode
    C1 Start Comms +ve response
    C2 Stop Comms +ve response
    C3 Access Timing Params +ve response
    81-8F Reserved
    90-F9 Vehicle manufacturer specific
    FA-FE System supplier specific
    FF Reserved by document
    Sample scan obtained of a SMART FOR TWO car
    --wakeup
    81 -> e9 8f
    --get capabilities
    01 00 -> b2 3f f8 11 capabilities service 1: 1 3 4 5 6 7 b v d e f 10 11 12 13 14 15 1c 20
    01 20 -> 80 00 00 00 capabilities service 1: 21
    02 00 00 -> 7e 38 00 00 capabilities service 2: 2 3 4 5 6 7 b c d
    05 00 00 -> 7f 05 11 capabilities service 5: none
    06 00 -> ff c0 80 00 capabilities service 6: 1 2 3 4 5 6 7 8 9 a 11
    08 00 00 00 00 00 00 -> 7f 08 11 capabilities service 8: none
    09 00 -> 01 30 00 00 00 ???? expected 4 byte response...
    --get status
    01 01 -> 01 07 69 00 MIL light off, 1 dtc, ready, no 02monotoring
    --get dtc's
    03 -> 07 02 00 00 00 00 dtc P0702
    --scan sensors
    01 03
    01 04
    01 05 -> 3a engine coolant temp = 18C (3a=58 dec - 40 dec)
    01 06
    01 07
    01 0b
    01 0c
    01 0d
    01 0e
    01 0f
    01 10
    01 11
    01 12
    01 13 -> 03 2 sensors
    01 14
    01 15
    01 1c
    01 20 -> 80 00 00 00 (always same: capabilities 21-40)
    01 21 -> 00 37
  16. #15
    arkansas
    Thanks JJ, I will check that out.
