[SIZE=2]
F[SIZE=2]or a Merlyn, there are plastic/nylon flanged sleeve bearings in the A-arms with a metal sleeve inserted though the sleeve bearings to bolt to the frame.
Does anyone have a distributor that has an exact replacement for these? I searched on web, but have yet to find an exact match.
I am leaning to buying an undersized ID and reaming it out from 1/2 to 9/16 to make it work. All other dimensions should work as is.
These at McMaster are a close match, but the 9/16 ID is a bit tough to find. And for Merlyn owners, I know I can call Cap, but they don't seem to sell just the sleeve bearings, and the set with the metal sleeves is a bit pricey.
https://www.mcmaster.com/#6294k223/=18oadbw
Light Duty Dry-Running Sleeve Bearing, Flanged, MDS-Filled Nylon, 3/4" OD, 1/2" Length
Thanks in advance! [/SIZE][/SIZE]![]()
[SIZE=2]
[/SIZE]
