Results 1 to 10 of 10
    Lincoln NE
    Liked: 90
    Default Hoosier Vintage FF tires ?
    Had a problem this weekend with a new set of Hoosier vintage treads...car was fine during Friday practice, using up an old set of Dunlops. For Sat quali session, we put on a new set of Hoosiers---big issues. They are great everywhere, except under very heavy braking, then the fronts get a bounce/shudder going that will almost take the steering wheel away from you. No hint of it any other time, so I don't think it's balance or out of round. Not the track surface, he was in the same line as with the D's, and trying another line didn't help.
    Great tire otherwise,
    Liked: 388
    Switching tires doesn't necessarily mean it's being caused by the tires. I would do a thorough check for suspension binding, shock behavior and look at brake bias adjustments. Seldom will changing tire brands/sizes take the same brake bias settings.
    Peter Olivola
    (polivola@gmail.com)
    Lincoln NE
    Liked: 90
    turned out to be low air pressure...we just weren't getting them up to hot pressure they like
    a bad tire gauge wasn't helping, either
    Senior Member captdigi's Avatar
    Phoenix, AZ
    Liked: 123
    Default wheel hop
    I had the same issue. What pressures did you use to stop the violence??
    Lincoln NE
    Liked: 90
    still a work in progress once we got them around 17 hot, they got much better
    according to Hoosier, we might need a couple more to dial them in
    Phoenix, AZ
    Liked: 123
    Ok. Thank you
    CA
    Liked: 262
    Digi, several of us during the recent Indy/ mid Ohio run found putting on new tires really caused handling issues the first heat cycle the tire were very slippery and hard to drive (1-2 secs off the pace). The second heat cycle was a bit better, but still not good. The third heat cycle and after they were great. But still no faster than the old tires that came off. So in my opinion that is the perfect tire in that putting on new tires is actually a disadvantage and even when they come in around the third heat cycle are no faster than the 1.5 yr old 20 something heat cycle worn out tread set they replaced. We are running hot pressures in the 16-18 psi range and very little camber and it seems to be working really well. Todd
    Denver
    Liked: 323
    Quote Originally Posted by tstrong View Post
    Digi, . . . . We are running hot pressures in the 16-18 psi range and very little camber and it seems to be working really well. Todd
    Todd,
    Same on all four corners, or different front to back? Seems like 2 lbs. more pressure in rears has been typical for FF spec tires as long as I can recall. Any thoughts on this? (Don't give away ALL your speed secrets.)
    Winter Garden, Florida
    Liked: 162
    Robert,
    I started out with 2 lbs more in the rear which is what I used on the Avons and Dunlops. I am now about equal front to rear at most tracks using the Hoosiers. The most difference I have used recently is 1 lb. I check my tire pressures when I come in and look for 18 lbs hot.
    Best Joe
    CA
    Liked: 262
    Agreed, ran 2 lbs more in rears with Dunlops. With Hoosiers run 1 lb more or same depending on how the car feels ( and tire temps) but not more than 1 lb more in the rear. Todd
