Results 1 to 5 of 5
    Ridgecrest, Ca
    Liked: 259
    Default GCR piston rule question
    reading the GCR tonight, I finally "saw/recognized" something that's been right in front of me for an unknown length of time. in the Kent piston rule, minimum weight is specified as:
    515 grams (w/ clips, pins and rings)
    what "pins" are being referred to in the rule as currently written ???
    as shown in the attached image, wrist pin requirements are included in 6.
    Art
    artesmith@earthlink.net
    Liked: 566
    The GCR has a long and storied history of repeating itself. Given that, the most straightforward reading is that the wrist pin weight is repeated. This is reinforced by the "pin" weight matching the "wrist pin" weight.
    Peter Olivola
    (polivola@gmail.com)
    Liked: 1482
    The way I read it, if you believe 'pins' are something mysterious and not the wrist pins, then the minimum weight of the assembly goes UP by 115 grams...
    Is that what you want?
    Ridgecrest, Ca
    Liked: 259
    my question is NOT with the fact that 5. includes "Weight of pin: 115 +/- 2 grams" and 6. includes "A. Weight is 115 +/- 2grams." they match. the question is specifically the plural "pins" (ie: the s) in 5. "Minimum weight 515 grams (w/clips, pins and rings)"........... why "pins" and not 'pin' when defining the make-up of the 515 grams??
    Art
    Ottawa
    Liked: 1282
    Art
    The GCR's technical specifications have gone through many, many, many iterations over the years. I guess about 50 years' worth in the case of Formula Ford (as was). It is no surprise that there are grammatical errors and/or artifacts of earlier versions. The surprise is that there are so few.
    A CRB letter would get this corrected.
    As always, let GCR 1.2.3.A. be your guide when reading the book.
    John Nesbitt
    ex-Swift DB-1
