Results 1 to 26 of 26
    Liked: 440
    Default encased rubber bushing
    Where can I find these? I need 1 inch outside dia, 1 inch long with a 7/16" hole. I know they are out there somewhere but I can not seem to able to find them. Thanks.
    Graham
    Kaufman, TX
    Liked: 63
    Try McMaster-Carr
    Arizona
    Liked: 378
    Fallen Friend
    Pensacola, Florida
    Liked: 168
    a couple of thoughts:
    Looks similar to those on Lotus 23... try Lee Chapman: http://www.leechapmanracing.com/
    Also, looks like bushing on Westfield 7 or 11... don't have contact for that....might have a couple of arms on shelf, would need to check dims. but those have bushings are already installed..
    Bob L.
    Savannah, GA (via Montreal)
    Liked: 1005
    Quote Originally Posted by Bob L. View Post
    Bob L.
    I just checked my Lotus 7 spares, uses every size except that one sorry
    Member T-Tom's Avatar
    Mobile, AL
    Default Bushing
    As Bob L said, Lee Chapman has some. The closest that I see as to what you are seeking is;
    P/N X023D6011Z
    Lower Wishbone Bush
    7/16 I.D. x 15/16 O.D. x 1-3/8 Long
    Chrome Moly Steel Inner Sleeve
    $23.50
    I found this for a Lotus 18 but they are also used on other models.
    It might help to know what you are working on.
    Liked: 440
    Thanks for the help so far guys but nothing has panned out so far. Checked all of the above. The parts I need are used for the motor mount bolts to go through the frame on a Merlyn MK29A. Thinking that they are 1" in diameter, I thought they would be easy to find.
    Graham
    Liked: 1005
    Graham,
    these are yours for postage if you can make either pair work:
    1.063 dia x 1.067 long w/ .5 hole
    or 1.065 dia x 1.378 long w/ .5 hole
    Liked: 440
    Thanks Ian for the offer. I will keep those in mind if I can't find the others. The thing is the cast aluminum motor mounts have the 7/16" unf thread which the bolt goes into. Thanks
    Graham
    Contributing Member Ken Lawrence's Avatar
    Tulsa, OK
    Liked: 54
    Default Bushings
    Triumph used these on the front and rear suspension, Spitfires, Tr6. Don't remember the size, Moss Motors has some.
    Liked: 1534
    Check for leaf spring bushings. You will have to cut them to length but you might just find what you are looking for OD and ID size wise.
    mukwonago, wisconsin
    Liked: 96
    Liked: 2056
    They are called Lord Mounts.
    St Cloud, Fl
    Liked: 136
    try taylor race. looks same as ones on my rp31
    Senior Member Wes Allen's Avatar
    Lexington,Ky.
    Liked: 64
    You might consider making some solid bushings out of steel. I cracked several gearbox cases on my Merlyn -025 before I figured out what was happening. The gearbox ears are mounted solid to the rear frame but the engine is allowed to move around because of those bushings.
  17. #16
    Liked: 440
    Quote Originally Posted by Wes Allen View Post
    Didn't think of the motor moving around and the trans solid. There was a pretty good crack in the tranny magnesium housing I had welded up.
    Thanks Wes.
    Graham
  18. #17
    Hoschton, GA
    Liked: 758
    I got mine from URS in the U.K.
  19. #18
    Lincoln NE
    Dave Bean used to keep a couple of sizes in stock
  21. #19
    Milan, MI
    Liked: 330
    BAT British Amerian Transfer
    Or
    Dave Bean
    I bought a set of four a couple years ago.
  22. #20
    Sydney
    I'd expect Silentbloc was probably the original supplier.....there were several durometer grades, but haven't seen the catalogue in the chaos here for several years.
  23. #21
    Liked: 1079
    Silentbloc is one manufacturer,
    Metalastik brand has a very wide product line.
    http://www.missionsupplyonline.com/M...etalastik.html
    Neil Porter stocks several sizes for Crossles.
    Dave Bean or JAE Parts in Santa Barbara also stock them.
  24. #22
    Houston, TX
    Liked: 77
    Earley Motorsports
    Did you ever locate this bushing? My '88 Reynard FC uses the same fully bonded bushing and identical dimensions on the front engine spider that ties to the frame. 1" OD, 7/16" ID 1" W
    My current bushing is tired with the rubber no longer bonded.
    John
  25. #23
    Liked: 170
    Default Chapman right here in the US
    http://leechapmanracing.com/
    A great resource for these kinds of bushings
  27. #24
    San Diego,Ca
    Liked: 635
    Default Bush
    They sound like Crossle 30 series motor mount bushings. Call Neil Porter in California. 209-722-7373
    Roland Johnson
    San Diego, Ca
  28. #25
    San Diego,Ca
    Liked: 635
    Default Bush
    Roland Johnson
    San Diego, Ca
  29. #26
    Liked: 440
    Thanks Roland. I got it sorted out quite a while ago. This was an old post. Cheers mate.
    Graham
