Page 7 of 17 FirstFirst ... 34567891011 ... LastLast
Results 241 to 280 of 670
  1. #241
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    Welcome to the old days.
    Lol, ok I am going to take that as I did it right.
    Setting timing is rev it up past 4K and listen for it?
  2. #242
    Sagle, Idaho
    Liked: 186
    A lot of chassis have the timing mark on the flywheel. Larger diameter = more accurate timing.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  4. #243
    Liked: 3908
    Hum.... i seem to remember the pointer on the cam gear being at the top, not bottom...
    I also seem to remember we only advanced the cam or retarded it about 3 degrees either way, depending on the track, using offset keys.
    Where is DaveW when we need him?
  5. #244
    Liked: 1070
    Quote Originally Posted by xmazdatracy View Post
    This dizzy stuff is new to me. I normally just plug the laptop in and do everything from there...
    If you had points and condenser, we would teach you how to set initial static timing with a Zig-Zag rolling paper....
  7. #245
    behind you
    Liked: 130
    well while I am getting ready to start plumbing this thing, I was wondering about tire sizes.
    I keep reading that FC is referred to as having 6 and 8 inch tires. But is that like a rule? On the car now I have 7 and 9 inch tires. Tax season (tire fund) is coming up and I will be purchasing tires (used) and everyone here is pretty hit or miss on tire sizes... Without messing up the suspension set up that is on the car from jrock how do I find these sized tires???
    Also arms up (local FC prep shop) only uses radial now. So no more take offs from them. As I was probing into the world of formula there where quite a few MC drivers that would run tires almost all season, but on here it seems people would only run tires for a day. I am lost in the bias of perceived value on take offs...
    Please all who use tires on their race car chime in.
  8. #246
    Sagle, Idaho
    Liked: 186
    6 and 8 inch rims are the rule for FC. AFAIK you can use whatever size tire on them but most use the 7 and 9 inch combination.
    Radials are spec. tire in some groups. Some older chassis don't have the adjustment range to set the camber where required.
    New tires = consistently faster lap times = higher cost. Few can run at the front on someone's take-offs. Not saying it hasn't been done though.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  9. #247
    Southeast MI
    Liked: 266
    The most common size is 7" in the front and 8" in the rear. The 9" is pretty much overkill on these cars. The wheel sizes are regulated but there are a few sizing options out there. The 8" and 9" tires have different diameters too so its not as simple as switching between the two as it will affect your gearing.
    There's still a takeoff source thru John Berget Tire. Cost is about a third on buying new. Overall, I've had pretty good luck with takeoffs from him.
    CJD
  11. #248
    Tacoma, Washington
    Liked: 210
    ......There's still a takeoff source thru John Berget Tire. Cost is about a third on buying new. Overall, I've had pretty good luck with takeoffs from him.
    Used John regularly for 3 years with no problems. At the time it was $280 for four tires delivered to my front door. With hard driving they were good for a weekend with maybe a little left over for one more practice. Was with 40 minute practices two runs on Saturday and one on Sunday, 40 minute qualifications one run per weekend on Saturday and 40 minute races one on Sunday.
    CJD
  13. #249
    Liked: 991
    Third used tires from John!!
    Have used him for years. Never got a bummer.
    Doesn't get much better than that.
  14. #250
    Idaho
    I've only ever used take-offs. I've never had an issue with John's tires.
  15. #251
    behind you
    Liked: 130
    Liked: 3908
    Look at the bead rollers Eastwood sells.
    Manual units really require two people to do good work. Some rig electric motors with foot pedals to the manual units.
    YMMV
  17. #253
    Late Braking Member
    Danville, California
    Liked: 269
    Default Earl's EZ Beaders
    If you have just 1 size of tube to bead, the Earl's EZ beader is great. I've got one for 1.25" tubing, takes about 2 minutes to bead an aluminum tube.
  19. #254
    Sagle, Idaho
    Liked: 186
    https://www.youtube.com/watch?v=JVDUM2ZxoW0
    lol...
    What material are you wanting to roll?
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  20. #255
    Liked: 1469
    Here's one better than Mr Hayes' suggestion. More work but better...
    http://www.garagejournal.com/forum/s...ad.php?t=51655
  21. #256
    behind you
    Liked: 130
    You have? I cant find anyone who likes that thing, but for 82 bucks it seems the cheapest tool to get. If you can vouch for the thing Ill get it. Otherwise I am going to buy the jeggs one for 131 and turn around and sell it on ebay.
    On 247 mazda forum they would pass around tools like this. I wish this place would too.
  22. #257
    Chicago, Illinois
    Default :(
    ...bead rollers...
    And no machine/weld shop in the entire Chicagoland area has one. Trust me, I've checked.
    Half the people I asked didn't even know what a bead roller is.
  24. #258
    Sagle, Idaho
    Liked: 186
    Happy to send ours for you to use. Promise to send back :-) Pay shipping both ways.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  26. #259
    Late Braking Member
    Liked: 269
    I've never had a problem with mine on aluminum tube...
    You can borrow mine if you want, you pay shipping both ways.
  28. #260
    Liked: 1469
    Best offers you'll get all day...
  29. #261
    mukwonago, wisconsin
    Liked: 96
    Quote Originally Posted by OneWayOut View Post
    If you consider Mukwonago, Wi. part of the Chicagoland area I have both a bead roller and
    a beader for tubing. You're welcome to come up and use it.
    john f
  31. #262
    Sagle, Idaho
    Liked: 186
    That close to Lake Wobegon?
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  33. #263
    Liked: 1070
    Umm, no. Wobegon is in Minnesota. From the main highway, turn left at the Craig's Red Owl, then right after the Lutheran church.
  34. #264
    Bradenton, FL
    Liked: 14
    An example of a proper rebuild of an 87 Reynard currently be done somewhere south of Atlanta.
    Yep I recognize that car. It stares at me all the time; when I enter work and when I leave... Everyday
    -Head MRTI Indy Lights Mechanic: -Head SCCA USF4 Mechanic
    -Lead Cape Motorsports Mechanic: -Head PWC Audi R8 Mechanic
    -Lead IMSA LMP2 Mechanic
  35. #265
    Liked: 3795
    Is there a question here?
  36. #266
    behind you
    Liked: 130
    haha, in post 239 (linear style) I was hoping someone would let me know if the pictures of my timming marks are right. But I pretty sure its right.
  37. #267
    behind you
    Liked: 130
    Some nice goodies from a trip to Milwaukee!
  39. #268
    Cedarburg, WI
    Default Sprecher
    Yeah, those tires look good also.
  40. #269
    Paddock Lake WI
    Liked: 204
    Default New Glaus Spotted Cow
    Personally I would have brought back Spotted Cow
  42. #270
    behind you
    Liked: 130
    Racetech wiring
    Red wire, 12V power feed, must be through the ignition switch. Tach must be switched on and off via this switch
    Blue wire, Input signal, from CD output or negative terminal on coil
    Yellow wire, Tell Tale Sign, Connected to one terminal of a push button switch. The other terminal on the switch goes to ground.
    Green Wire, Atach to a good ground point on the chassis.
    __________________
    Thanks Keith!
  43. #271
    behind you
    Liked: 130
  44. #272
    Liked: 1681
    blue coil - no resistor, black coil - resistor
  46. #273
    behind you
    Liked: 130
    Cool thanks for the tip!. Since I pulled the MSD I just ordered up a pentronix rev limiter.
    Anyone run these anywhere besides the firewall?
  47. #274
    Liked: 1681
    Three considerations in mounting:
    1) don't subject it to a lot of heat
    2) don't subject it to a lot of vibration
    3) mount it on the other side form where your radio and instrumentation harness is located.
    The hardest thing to do if it's not mounted inside the cockpit is #1, and if it is in the cockpit then you usually have issues with #3....
  49. #275
    behind you
    Liked: 130
    Dang. A way from the wire harness. Thats going to be hard.
    Welp I guess I will post some progress photos despite some negative feedback. If you would please ignore the giant elephant in the room here they are.
    One last question... if I may (I think this is becoming a lot less a thread in a community and more of a blog), in this picture you can see the filler neck for the fuel cell is pretty low. Can I weld on a length of pipe and have that much closer to the top of the body work, or does it have to stay that low down?
  50. #276
    Southeast MI
    Liked: 266
    Default Fuel filler
    Just use a long funnel. I've almost exclusively filled any of my cars with the bodywork off. There's enough things you'll want to look over between sessions that there is no reason you should want to fill the tank while the bodywork is on.
  51. The following members LIKED this post:
  52. #277
    Livonia,MI
    Liked: 39
    Might check the clearance between the front "spider" engine mount , and that MSD....it's pretty tight up there. If it was me (and I did)...go back to points /condenser....simple , easy to change , easy to diagnose.......My .02......
  53. The following 2 users liked this post:
  54. #278
    Liked: 1681
    Just toss the MSD......
  55. #279
    Liked: 3795
    I'd avoid extending the filler neck. The longer it is, the more likely it is to be damaged or torn out in an accident. I agree with the long funnel approach. My fill opening is up fairly high, but inaccessible with a normal funnel. So I use a funnel that has an extension with 3 welded pieces changing direction twice. That allows me to fill from outside, so if I spill, it doesn't wind up inside the car.
  56. #280
    Ft. Myers, Florida
    Liked: 228
    Default Points/condenser
    Another in agreement with tossing the MSD and using points/condenser.
    Easy to diagnose and fix, plus they are inexpensive, small space requirement spares.
There are currently 40 users browsing this thread. (0 members and 40 guests)
