Page 6 of 17 FirstFirst ... 234567891016 ... LastLast
Results 201 to 240 of 670
  1. #201
    Sagle, Idaho
    Liked: 186
    Regarding the header crack;
    If that coating is Jet Hot you have to file or sand it off prior to attempting to weld the pipe.
    We've broke a pipe per weekend since we bought our Pinto. They shake so much it destroys mild steel headers. If you want them to last buy some stainless ones.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  2. #202
    Liked: 3795
    In my experience, it's more the 1500-degree EGT's you need for top performance in the Pinto's that kills the mild-steel headers, although the vibration sure doesn't help. Similar SS headers hardly crack at all, which tells me its mostly the temperature issue.
    Coating only on the outside or wrapping will accelerate header destruction since that makes the header metal run hotter.
  3. #203
    Sagle, Idaho
    Liked: 186
    I think that 304 and 316 SS has a higher tensile strength then mild steel as well, like 20%.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  4. #204
    Liked: 3795
    You are likely correct on this, but it's the difference in tensile strength above 1300F near the head (where they all crack) that makes the mild steel headers break. Mild steel loses more than 90% of its strength at that temperature. Below 500F, away from the exhaust port, both are plenty strong.
  5. #205
    Tacoma, Washington
    Liked: 210
    ..... We've broke a pipe per weekend since we bought our Pinto. ...
    WHOLEY cracks Batman!. All the years we were racing Lensen we as in our cars and his I only know of our one header that cracked. If we had lost one per weekend I would have needed my heart surgery a couple of years earlier.
  6. #206
    Sagle, Idaho
    Liked: 186
    Always in a slightly different spot, different pipes, etc. Thanks to Archie Hodge for his acetylene torch set and coat hangers we never missed a session from that!
    One pipe is now stainless as it broke so many times.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  7. #207
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    Got these back from the powder-coater.
    I know color is a personal preference, but so glad to have the red gone. However three of the wheels have holes drilled and taped in the outside bead. Why would this be? And are regular rubber valves you get from autozone ok?
    Also, I will be testing the dry sump pan to see if it leaks out of the welded up holes. But before I go and bolt this thing back up I was wondering about the piece that looks like it is supposed to wipe off oil from the spinning crank. Is that thing a must have? I ask this because I have a feeling I am going to have quite a bit of blow by this first season. And I think anywhere the oil can squeeze out it will. Like the cap and rotor are soaked in oil (I already have that o ring on order).
    Do you guys have photos of your water pumps? This site has deleted most of the older photos if you attach them to this site. And it looks like its been a while since this car was a hot subject. BUT, the ones I do see look nothing like the water pump you get from Pegasus.
  8. #208
    Liked: 3795
    Quote Originally Posted by xmazdatracy View Post
    ...I know color is a personal preference, but so glad to have the red gone. However three of the wheels have holes drilled and taped in the outside bead. Why would this be? And are regular rubber valves you get from autozone ok?...
    I use rubber valve stems. The ones I use are made for golf carts, IIRC, and are super short, keeping them from getting damaged in wheel-wheel contact.
    Before that, I used the metal valve stems, but had a couple knocked off in wheel-wheel contact, so I switched to the rubber ones. Try to get quality ones, because maybe 8-10 years ago there was a recall on some Chinese ones made with the wrong compound, so they cracked and leaked.
    Also, the threaded holes in the outer wheel bead area were likely there to insert pointed screws that dug into the tire beads to keep the tires from slipping on the rims, which is a fairly common issue, causing the tire/wheel ass'y to go out of balance if they slip too much.
  9. #209
    Arizona
    Liked: 378
    Coating Magnesium Wheels: I have been told not to blast and powder coat magnesium wheels. Why is this? Anyone with some experience in this matter have some input?
    Water Pump: I recently replaced the water pump on my 2.0L. I was advised by another Apex member to look at purchasing the pump from Dave Bean. I contacted them and had great telephone support with the salesman at Dave Bean. I even requested to the salesman that I send in a picture of what I had so that he could confirm what he had is what I needed. They did so, and it was the right part. I can HIGHLY recommend using Dave Bean when you need some engine parts.
    I too was confused that the photos you see online are different than what was in my car. The pump comes with a 'port' that is intended for use to a cabin heater in a normal car. This is not needed in our application so, I cut this off and threaded it and put in a plug. In the future I am considering moving the probe for my AIM system into this port to get water inlet temp. Then put a capillary gauge into the top of my tank to get water outlet temps.
    I think it is a standard now that all these water pumps are made out of Aluminum. There is a little weight savings over the stock metal one that I pulled off. The nicest thing about this is the fact that it made chopping off the heater line and threading it simple !!
  11. #210
    Liked: 3795
    Default Link to thread about coating wheels
  13. #211
    Liked: 3908
    I'm a bit concerned by this statement: I ask this because I have a feeling I am going to have quite a bit of blow by this first season.
    I'm wondering why you think this? And if so, you have the engine out and almost stripped. Why not just throw a new set of rings in it now?
    I say that because a good pinto doesn't have blow-by. In fact it usually runs with enough scavenge from the oil pump to have negative crankcase pressure.
    OBTW leave the hardware in that pan, its there for good reason.
  14. #212
    behind you
    Liked: 130
    This car has had more surprises than I can financially handle. So I am at the financial verge of being able to run next season or having to wait till 2018 to be my first FC season. So as for now I just wanted to make sure the pinto will not explode during my first season. I will wait till next off season to tear it down and build it right.
    Jeremy and myself were informed that this motor was a fresh rebuild, so my suspicions are that they do have new rings in there. But looking in the spark plug holes I can see no one ever had the block honed (hence the blow-by comment). I know this motor is from the 60's but this is a bit more groovy than a set of new rings can fix!
    I have been busy at work and have been a bit too tired to come home and continue to work on this little guy, but today I will be pulling off a cap or two off the bottom end, and plasti-gaugeing to check if bearing tolerance was paid attention to. If not then maybe I will not make it to the track this coming season and do a full pinto rebuild now.
    The piece that I was talking about is not on the oil pan. It was smushed between the pan and the block. Here you can see it in this pic.
    I know the one on/in the pan is very common, and I will not touch it. But that other piece looks to be just a extra oil wiper. Not sure if it is needed, and is mounted down there in a poor fashion. I do notice the many views since that post but no one except you has taken a stab at saying anything about it. So I am thinking not a lot of people here build their own motors. Since I still have to test the oil pan for leaks that should give me enough time to wait, and I will call Ivey again and ask them about that piece. The motor does have a I.V. number on it, but I have a felling it has been a long time since they have seen this block. I would not think a pro engine rebuild shop would stick weld a mounting tab on, and paint it some other color than their own trademark color.
    Here is to hoping for good luck today!
  15. #213
    Pittsboro IN
    Liked: 313
    Another vote for leaving the scraper.
  17. #214
    Liked: 3908
    In SCCA racing because of the rule concerning max cylinder diameter; wear can only be solved by re-sleeving the block. About a $400 expense. Many regional guys try to "get by" with piston-to- wall clearances that are excessive. Or, they break the rules and throw in oversized pistons, something I could not do.
    The original pinto piston design might be fine for 2300 rpm. At 6800 the distance the wrist pin is from the rings creates "rocking" and cylinder wall wear, along with piston ring groove wear.
    Unfortunately the solution is available but illegal. (I have given up that fight.) One reason the newer engines in our classes (Zetec/Fit) have longer duty cycles is their pistons are so much better designed.
  18. #215
    Livonia,MI
    Liked: 39
    If you can...figure out a way to send it to Ivey........if you run it , and blow it up, it will cost you tons more!!!
  19. #216
    Liked: 3908
    The one good thing about pintos is that for the most part they don't "blow up" and gernade all over the place, unlike FA or FB. In most cases pintos just keep getting "softer" and "softer".
    The exception would be incredible over revs, or someone trying to use the original stock rods. For the most part stock rods haven't been in the engines for almost two decades.
    The problem with "soft" engines they are completely no fun to drive. IMHO a waste of entry fees and travel expenses.
  21. #217
    Contributing Member mblanc's Avatar
    swisstown.com
    Liked: 42
    If you want to bring that engine by our shop, We can measure the cylinder bores, and give you an idea of the clearances, and even check the ra finish of the cylinder wall, and let you know what you are dealing with. Glad to do pics of the process, to add to the thread. If it needs sleeves, we could photo document that the bore/resleeve process also.
    I "think" you're not that far away ?
    Sent from my SM-G900R4 using Tapatalk
    FFCoalition.com
    Marc Blanc
  23. #218
    Paddock Lake WI
    Liked: 204
    Quote Originally Posted by mblanc View Post
    As a bonus you can stop by the New Glarus brewery while you're at it!
  25. #219
    behind you
    Liked: 130
    Never taken much to make me visit there again, and again, and again... one of my faves
    Never thought about wall limits put in place by the GCR. I was thinking a quick hone would never get it that far, but then again all the sleeve to piston wall specs I have done before was done at a machine shop, and not me. If that is at end spec... then instead of sleeving it maybe its time to go back to my roots and toss a modern motor in here. Who knows. Just want a season under my belt before I can say anything like that.
    Good news... all main caps and con caps are good!
  26. #220
    behind you
    Liked: 130
    Well not very confident with this oil pan. I had to reshape the mating surface as the pan was over torqued and every screw hole was pushed down considerably. Also I had to re-braze one of the holes from a previous motor explosion (leaking badly) just to find out it now touches the oil pump. Don't want to push it in with of fear I might open up that pin hole again or crack the new brazing. But I will fill the motor up and test for leaks before I put the engine back in.
    I also spent the last 45min looking for a post from one of the regulars on here that he said that he opens up his new hella kill switches, and does some sort of spacer thingy and never has a problem with the switch failing again. Can anyone find that or let me know what he did that would be great.
    Also is it a sin to mount the switch up by the battery? It would save weight and cost of 4g wire. Not sure if the GCR states that it has to be back by the hoop. Reading that thing tends to put me to sleep.
    Thanks!
    9.3.33.
    MASTER SWITCH
    All cars, except Touring shall be equipped with a master switch easily
    accessible from outside the car. Spec Racer Fords shall be wired per
    GCR - 103
    9. Cars and Equipment
    General
    RFSRII. The master switch shall be installed directly in either battery cable
    and shall cut all electrical circuits but not an on-board fire system. All
    terminals of the master switch shall be insulated to prevent shorting out.
    It shall be clearly marked by the international marking of a spark in a blue
    triangle and mounted in a standard location. Off position shall be clearly
    indicated at the master switch location. The standard locations shall be
    as follows:
    A.
    Formula and Sports Racing Cars–In proximity to the right-hand
    member of the roll bar, but in a location so that it cannot be oper
    -ated accidentally. It can be mounted on a bracket welded to the
    inside of the upright member or mounted so that the operating lever
    or knob is outside of the body panel immediately in-board of the
    upright member. This is the standard location on Formula cars built
    to the Constructor’s Association requirements for Formula 1.
    B.
    Closed Sports Racing
    Cars, Production Cars, Improved Touring and
    GT Cars–In front of the windshield on either the cowl or on top of
    the fender, but close enough to the windshield to be accessible
    if the car is overturned. Alternatively, it may be mounted below
    the center of the rear window or on a bracket welded, clamped
    or bolted to the
    roll cage or dash, easily accessible through the
    open window. (Drilling of holes in roll cage to attach the bracket is
    prohibited.)
    C.
    Open
    Production, GT, and Improved Touring Cars–May exercise a
    choice among the above locations.
    Damn it....
  27. #221
    Liked: 3908
    Some, DaveW as an example, have the kill switch positioned on the dash so the driver can control it.
    In an earlier picture on this thread; on my Reynards i mounted it outside on the right side on the panel behind the radiator.
  28. #222
    behind you
    Liked: 130
    In MC they don't mention any location (for formulas), however I still would like to stay with SCCA rules. So yes I will be placing mine just like yours. I saw they have a remote kill switch for the main kill switch so you can have two spots and not have 4g going everywhere. That was pretty neat, but very pricey. I am still wanting to do the jump/start the car with the kill switch off to save on battery life, and that will mean a new run of 4g from the battery to the switch, and then to ground. Also I went with a PC680. Guess if I am going to be slow, I might as well make it to the end of the "Looong" race slowly too. Since I will not have the switch to act as a point of distribution I will get one of those distribution blocks, and make it a bit more safe/pretty.
  29. #223
    Liked: 3795
    My kill location is legal per SCCA - there is a pull cable from just behind the roll hoop on the RH side to the actual switch on the dash. This has the advantage of no extra length of heavy gauge wire (my ETX18L battery is below my knees - no jump battery needed). Also, I use the main switch to turn everything on and off every session, which I can do while in the car.
    Photos below. The RH photo is from before the conversion to Zetec.
  31. #224
    Liked: 3908
    It doesn't hurt to jumpstart the car with the switch on. Just don't leave the jump start battery plugged in when you are not actually jumping.
    That will save you a lot of wiring hassles.
    You could move the jump start plug to the rear of the car to get a real short run to the starter.
    The newer batteries have so much better power supply that many times one doesn't need a jump battery.
    I have a stock oil pan if you are feeling energetic and want to construct a new one. Otherwise I would call an engine builder and see what they have laying around.
    Interesting thing about pinhole leaks in the pan. If they are up high, they don't leak oil out, they leak air in; because when the engine is running there is negative pressure in the crankcase.
    Grind the outside for clearance, put a patch on the inside...
  32. #225
    Tacoma, Washington
    Liked: 210
    .......Also is it a sin to mount the switch up by the battery?
    terminals of the master switch shall be insulated to prevent shorting out........
    No nothing wrong with that but....
    [COLOR=Red]
    9.3.33. MASTER SWITCH
    accessible from outside the car. ..
  33. #226
    behind you
    Liked: 130
    I also will be putting my oil cooler in the same spot. I love the rear cover that works with the new wing style. I got half of it (bottom of the clam shell style) with the purchase, but have no idea where I would find the rest.
    I want to call around for a steel dry sump pan to see if anyone can remember if they have one in their attic/shop that they no longer want/need, and would be willing to part for cheap. I did see a nice aluminum one on ebay for 425, but that is gone now. That is a bit pricey as I also have a dog that needs surgery next month. BUT, first let me test this pig.
    Also when I went to test the oil pan last night (filing motor with oil) it helps to have a oil filter on...
  34. #227
    Liked: 1682
    Aluminum pans were made for stressed installations and they have more protuberances. You really have to look at the specifics of your floor bracing to guarantee fit with any different pan.
  35. #228
    Tacoma, Washington
    Liked: 210
    Call Keith, he used to make the rear body work clam shell or at least knew where to get them.
  37. #229
    behind you
    Liked: 130
    Ahh, thanks!
  38. #230
    behind you
    Liked: 130
    how can you tell if the distributor is a dixon fixed?
  39. #231
    Liked: 3908
    With the cap off you should be able to grab the rotor and rotate it about 20 degrees against the internal springs. If its fixed, you can't rotate it. It will not advance.
  41. #232
    behind you
    Liked: 130
    OK it is the regular style with the old black pentronx in it.
    What are your guys views on speed bleeder screws???
  42. #233
    Sagle, Idaho
    Liked: 186
    Speed bleeder good.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  43. The following members LIKED this post:
  44. #234
    behind you
    Liked: 130
    OK all the hoses for the coolant are bulging and are needing to be replaced. I will be buying new silicon hoses, but since the car was running fine (I hope) I was just going to leave everything the same. Unless you guys think that running the radiators in series instead of parallel is a horrible thing to do. What do you guys think???
    Good news is the car is starting to get back together.
  45. #235
    Sagle, Idaho
    Liked: 186
    I think there's another thread regarding the series or parallel topic.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  46. #236
    Liked: 1070
    You don't need silicone hoses. Conventional cooling system hoses are perfectly adequate.
    It is nearly impossible to adequately split flow to operate a cooling system in parallel. My Zink Z10 ran the rads in series, I never had a cooling problem.
    Simple is better.
    Regards,
    Dan
  48. #237
    Liked: 991
    As far as the coolant hoses go, follow Carroll Smith's advice: Gates Green stripe or similar. Do not buy no name hose from China.
    Also, if you are friendly with the counter guy at the local parts store talk him into letting you go in back and match the curves that you need with their stock. much cheaper that way.
  50. #238
    Glendale, Arizona
    Liked: 502
    Eliminate the bottom half of the clamshell, it's a parachute
  51. The following members LIKED this post:
  52. #239
    behind you
    Liked: 130
    I'm hoping I timed this right. I believe the cam is a touch behind/retarded cause that is what you guys run...
    This dizzy stuff is new to me. I normally just plug the laptop in and do everything from there...
  53. #240
    Sagle, Idaho
    Liked: 186
    Welcome to the old days.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  54. The following members LIKED this post:
There are currently 24 users browsing this thread. (0 members and 24 guests)
