Page 5 of 17 FirstFirst 12345678915 ... LastLast
Results 161 to 200 of 670
  1. #161
    Liked: 1681
    you can plug it or run it to the bottom of the header tank and use that point as the fill point for the water system. A lot of cars just fill off the water neck at the front of the head. If you fill through the water pump heater inlet, keep the header tank above the top of the head, and run steam bleeds off the top of the radiators, you won't have any air buildup in the system and it will be easy to bleed.
    With a new water pump you might want to compare with your old one - sometimes the impellers are trimmed to reduce cavitation at the higher RPM we run.
  2. #162
    Tacoma, Washington
    Liked: 210
    Quote Originally Posted by xmazdatracy View Post
    searched to no avail; The new water pump has an extra outlet. Do I plug it or use it some how?
    Use it to pump hot water to the cockpit on those cold autumn weekends.
  4. #163
    Sagle, Idaho
    Liked: 186
    Did you get the aluminum or cast iron pump?
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  5. #164
    Tacoma, Washington
    Liked: 210
    Ours were both aluminum.
  6. #165
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    The pump came with the car. It is an aluminum "stock pump" from Pegasus.
  7. #166
    Paddock Lake WI
    Liked: 204
    Default Wheel spacers
    Went to mount the rain wheel set and the fronts do not clear the calipers...
    Do I have to buy new mid sections of the wheels or can I use spacers?
    update photo.
    Two Dogg, Inc in Rosco IL can supply you with wheel spacers.
  8. #167
    behind you
    Liked: 130
    By header tank do you mean the swirl pot with the radiator cap and overfill outlet?
    I gave them a call for some prices on stuff and seemed not to interested, and they never gave me a call back.
  9. #168
    Liked: 1681
    Yes
  10. #169
    behind you
    Liked: 130
    OK, 100LL (local airport) or 110 sunoco (local gas station)?
  11. #170
    San Diego,Ca
    Liked: 621
    100LL for 30+years
    Roland Johnson
    San Diego, Ca
  13. #171
    Global Moderator Chris Robson's Avatar
    Hebron, CT
    Liked: 113
    +1 for Avgas
    Chris Robson
    Accelerated Performance Coaching
    http://APCDriving.com
  14. #172
    behind you
    Liked: 130
    Great! It's 4.29 a gallon and the air port is in my neighborhood. No questions asked, just wants your credit card number.
  16. #173
    Howell, MI
    Liked: 218
    Ours is also automated. Wants a tail number. I tell it N1111.
  17. #174
    Tacoma, Washington
    Liked: 210
    Avgas is less expensive but in a pinch Sunoco usually has 110LL at most tracks where they have pumps installed. We used both just depending upon which was easier to get on any given weekend.
  18. #175
    Liked: 1070
    Any difference in jetting?
  19. #176
    Liked: 3908
    Not that any mortal can notice. Jetting has more to do with altitude, barometric pressure, humidity.
    my job is to stand in the staging lane with the portable weather station....
    not enough time to change jets, just change the predicted E.T. on the window.
    OBTW, back in the day, DaveW knew jets.
  20. #177
    Liked: 1070
    Thanks Mike. I'm still in school about them.
  21. #178
    Tacoma, Washington
    Liked: 210
    ...... Jetting has more to do with altitude, barometric pressure, humidity.
    Funny you should mention that and that. When we bought our two cars, we picked them up in Las Vegas but, they had not been run since they lived in Atlanta. Not knowing a lot about jetting, I looked up the altitude in Atlanta (about 1.050 ft.) and realized not the much different then here in the Seattle area. Although we live at near sea level, most of the tracks are between 700 and 1,000 feet. That was the last time I thought about jetting
  22. #179
    behind you
    Liked: 130
    Now I can see why you guys were saying no pressure, lol
    Man does that aviation gas stink!
    Also do I put on two beads on both sides of the center or just one huge bead that covers it all?
  23. #180
    Liked: 3795
    ...Also do I put on two beads on both sides of the center or just one huge bead that covers it all?
    I put a small bead on each joint between the center and rims and then use one finger in a rubber glove to smooth the beads and press the RTV into the 2 joints. It winds up looking like one large bead, but it is very thin in the center.
    I do this with the wheel mounted on my ancient dynamic balancer so I can rotate it easily to smooth the joint.
  24. The following 2 users liked this post:
  25. #181
    Liked: 1469
    Avgas stink? Hmmm... Something else going on? Breakdown of the cell?
    What kind of wheels are those?
    With my Jongbloeds you put the halves together and the center then on the outside.
    Screws come from the back through both halves and into the center piece.
    There is then only 1 joint to seal....
    During assembly you finger tighten it together, run the bead and let it cure, then torque everything. Creates pressure against the now cured sealant.
  26. #182
    Liked: 1681
    AVGAS stink? Not really. Kinda smells sweet to me, and distinctive enough I can tell when a WRX runners in town have taken off their cats to run it. Stinks far less than unleaded and the smell doesn't stay on your hands for very long.
    Are you sure that's what you have, because it should be blue.
  27. #183
    Liked: 3795
    On my Jongbloeds, I torque 1st, seal later because I do not want anything between the sections to relax later and cause things to loosen. That is an avoidable issue when using sealants. You want metal-to-metal for a solid, non-relaxing joint - that means NO sealant between sections. The sealant will work either way, but sealing last eliminates the loosening issue. This method has worked perfectly 100% of the time for me.
  29. #184
    Tacoma, Washington
    Liked: 210
    Is that your fuel cell??
    That looks way different from the cells in our 89 and 90
  30. #185
    behind you
    Liked: 130
    Its blue, and I got it from the only fuel pump at that the airport (very small). And it said 100LL all over it. I guess I just remember what the 110 smells like.
    It looks like one of the front compomotives has been in some sort of "instance". The rear of all the fins are smashed/smushed in and the inner rim has a pretty substantial wobble (out of true) with a dent in the middle of the wobble. I will seal them up (dow 832 was in stock down the street from my shop) and just remount the 11/12 year old rains. Ill install them to the car (with a half assed front rig for the fronts) and have the car be able to move to the chassis shop while I have the one piece wheels powder coated. There is always next year.
    Any one want some 10yr old slicks?
  31. #186
    behind you
    Liked: 130
    yup, so far no leaks at all. (its been the only thing on this car that hasn't leaked)
  32. #187
    Liked: 712
    Default Rebuild
    It may look different that what you remember but it looks like the same shape I've seen in a number of them around here.
  33. #188
    Liked: 1469
    Correct - nothing between the contacting parts of the halves. The bead sits away in the groove and final torqueing after creates a slight added pressure on the bead.
    The reality is when inflated the air pressure is pushing that bead further in improving the seal....
  34. #189
    Tacoma, Washington
    Liked: 210
    Wow Keith,
    After really looking at it again really closely, I see it now.. LOL. Did not realize the filler neck opening was under the plastic wrap.
    That one seems to be in almost too good a condition. Like it was painted.
  35. #190
    Liked: 1681
    if you have a gasketed surface, and coat the gaskets with silicone, then torqueing to a value - pick one - 1/3 to 1/2 the final value, letting it cure, and then re-torqueing to a final value is necessary to prevent the silicone from acting like a lubricant and causing the gasket to extrude out of the joint.
    Oil pans being different from wheels of course....
  36. #191
    behind you
    Liked: 130
    Before
    after
    Not perfect but no need to use duct tape to take in the 2" gap anymore. And yes I know not as much leverage blah blah, but there is always room to improve as I learn how to drive a rear rear with a dog box trans.
    These came out great!
    looking a bit less lopsided.
    But a big BIG thank you to everyone who has been helping me out. All your comments and posts are very much needed and used! Happy holidays. Stay tuned for more updates and pics during the holidays...
  38. #192
    Tacoma, Washington
    Liked: 210
    Man oh man oh man!!!
    That wing is a tight fit in the garage
  39. #193
    behind you
    Liked: 130
    LOL, yeah very tight. but plenty of room in front work on the motor. After cam assembly lubing the cam and letting the marvel mystery oil soak into the piston rings I re gaped the intake and exhaust leashes according to Quick Silvers recommendations found earlier in this thread. If you forgot here is a terrible pic of those numbers
    Just call me the Grinch. Because I bought plenty of presents, but only for me. ha ha!
    Did not leak, but still putting in the right one anyway.
    Is this crack something I should get fixed? I would assume these headers get moved around a bit during races, I could be wrong. Thoughts?
  40. #194
    Liked: 3908
    Who wants to tell you bad news on Christmas day?
    Those headers are probably pretty close to the end of their trail. A talented TIG welder might be able to patch. I've been know to shape another piece to bridge over the crack to provide a bit more meat to weld with. You'll have to grid off the coating. Here's hoping there is still some metal under the coating.
    one must remember that 2 liter motor was developed to get mom to the grocery store at 2300 rpms. When we wrap to 6800+ it creates some ugly harmonics. Part of the reason starter motors shake apart. Same with anything attached to the engine.
  42. #195
    Liked: 3795
    Default Oxy-acetylene works well...
    In an emergency, I've welded cracks like that with an oxy-acetylene torch and mild steel rod, or even a coat-hanger for rod. I had very good luck with that. But there is no guarantee that it would last very long. And the site does have to be very clean (bare metal) for a satisfactory weld.
    Back in my early FF days, that was almost an every-race-weekend occurrence with everyone trying to extend the life of mild-steel headers.
  43. The following members LIKED this post:
  44. #196
    behind you
    Liked: 130
    Sounds like I should leave it alone and buy a new set or at least that one pipe.
    Anyone know the fuel pump torque numbers?
  45. #197
    Pittsboro IN
    Liked: 313
    8mm bolt torque is 18ft/lbs
  47. #198
    Liked: 3908
    If one pipe is thin, they all are thin.
    But, i'd braze it/weld it for another season.
  48. #199
    Tacoma, Washington
    Liked: 210
    Had one like that but worse, it had split in two. A GT-! driver at the track with a welder welded it up for me between runs and the result lasted another year.
  50. #200
    behind you
    Liked: 130
    a little more work done.
There are currently 100 users browsing this thread. (0 members and 100 guests)
