Results 1 to 21 of 21
    Default Novarace Blade F600 for Sale SOLD!
    I'm selling my Novarace Blade.
    This is the sister car to the Blade that won the runoffs. Car is complete except the data system and the transponder will be removed. Car has less than 5 laps on track.
    No expense was spared in the build of this car.
    2011 Suzuki 600 GSXR with less than 3000 miles (engine hasn't been on track)
    Novarace wet sump pan
    2 qt. Accusump
    Braille Lithium-Ion battery
    Custom Fuel Safe fuel cell with molded in surge tank and internal Walbro fuel pump
    Aeromotive Fuel filter
    All fuel hoses are stainless steel braided hose with AN fittings
    All coolant hose is silicon hose except for vent hose which is stainless braided hose with AN fittings
    Custom aluminum crank case vent tank
    Custom aluminum coolant tank
    Professionally built car electrical harness
    Professionally stripped engine harness
    Cast SFI rated foam seat (not the cheap 2-part boat foam)
    Brakeman calipers front and rear using all LD19 pads
    Floating rotors
    Momo Mod 12c open top steering wheel
    Custom paddle shifter
    Schroth Formula Car Harness with pull up adjustable lap belts
    Custom built ballistic heat shield between block and header.
    Ceramic coated exhaust from end to end
    Extra front and rear sprockets (should be enough to set the car up for just about any track)
    3 Sets of wheels
    Asking $30K, but open to negotiate. Also open to trades. Considering FE or P2, but open to others. 704-604-5436
    I'll post more photos when I get them. Car is currently located outside Atlanta.
    https://goo.gl/photos/fHWnkB84aaM2Vu3DA
    Chris Ross
    covington ga
    Liked: 82
    If anybody has any doubt on which car they would want to buy right now this is it .I have it in my possession and if I could buy it I would.
    The right driver with the right setup can win any race including the Runoffs with this car. This car is not for larger drivers. The new Blade has a wider cockpit.
    Open to trades also. Considering FE or P2, but open to others.
    Chris Ross
    Marietta,Ga.
    Liked: 61
    Quote Originally Posted by lancer360 View Post
    Things that make you go, hmmm.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    I realize that it is raising some questions why I am selling a brand new car that is currently one of the fastest chassis's in the class. Issue is I just don't fit in the car. This car needs a smaller driver. I learned the hard way when having a car built I should have put specifications in the contract regarding the size of the cockpit. I'm not giving up on the F600 class. If the right deal came along for an F6 trade I would consider it too.
    Chris Ross
    Senior Member thunderracing91's Avatar
    WI
    Default .
    Out of curiosity what size of driver would fit comfortably?
    I'm 5'10 and 210 lbs and the car is tight on my hips. I have had several smaller drivers sit in the car tight but still comfortable like Clint McMahan and Matt Strand. I don't know their measurements though. They will hopefully chime in.
    Chris Ross
    I am 5' 9" and 190 lbs and I fit snugly in the hips. Slimmer is better...
    Liked: 297
    Default stupid question
    why not just modify the frame to fit the driver?
    Not easily done. Would require a frame off tear down and significant cutting apart of the frame to widen the mid rail by 4 inches overall (2" per side). Would also require a new wider and shorter fuel cell. All of this requires a large labor component as I'm paying someone else to maintain the car. It is an expensive proposition.
    Chris Ross
    Detroit, Mi
    Liked: 32
    Just for measurements, I fit ok in one. I'm 5'9" 160.
    Senior Member bluterek155's Avatar
    Iowa
    I realize that it is raising some questions why I am selling a brand new car that is currently one of the fastest chassis's in the class. Issue is I just don't fit in the car. I'm not giving up on the F600 class. If the right deal came along for an F6 trade I would consider it too.
    I would look at the Wildcat from Ryan Barth at RJB motorsports . I am 6'1" and was 225 and fit with a lot of room to spare. He has been great to work with and is working with us to make a lot of improvements over the winter. The car will be great this year and it keeps you in F600!
  15. #14
    covington ga
    Liked: 82
    I am 5ft 9in 150lbs. My pants size is 30-32. I fit snug in the car which is the way I like it. I have Chris ross old car and it does have a decent amount more room in it. The cockpit is a KBS not to be confused with a QRE invader. The QRE invader has more room than a KBS in "factory" form.
  16. #15
    Price Drop to $30K negotiable.
    Chris Ross
  17. #16
    this is a deal. you cannot build a car with all the extra special parts Chris has put on the car. Can win any race with the right driver.
  18. #17
    Simpsonville, SC
    Good luck selling your car Chris. As F600 cars go, it is one of the nicest out there. Have you listed it in SportsCar magazine? I've been out of SCCA for a few years and no longer receive it.
  19. #18
    No, I haven't listed it in SportsCar yet. I was hoping it would sell thru the forums, but I might go ahead and list it there and maybe get a broader audience. Still waiting on getting interior pics of the car, but I have to wait for Dan to finish the work on the other F6's they maintain so they can get mine out of the trailer.
    Chris Ross
  20. #19
    Greenwood Indiana
    Default Interested!
    Hi Chris,
    Please send me additional pictures of the car with the body off if possible. I would also like to know the dimension of the distance between the hip bars if possible.
    Thanks, Darrin DeVault
    email: zollie1967@gmail.com
    Phone: 317-496-8731
  21. #20
    I just called the gentlemen who is storing the car. He is going to try and get some photos tonight. If not it will be Monday as he is heading to the track this weekend.
    Regards,
    Chris
    Chris Ross
  22. #21
    Car is sold.
    Chris Ross
