View Poll Results: What is the best spec tire for Formula F?
Voters
114. You may not vote on this poll
  • Toyo R888
    57 50.00%
  • Hoosier F1600 Radial
    57 50.00%
Page 11 of 11 FirstFirst ... 7891011
Results 401 to 412 of 412
  1. #401
    Muncie, Indiana
    Liked: 1238
    Default Pro tires
    I understand the pricing associated with the pro tire includes a percentage for contingencies, however I don't understand why the pro tire is not approved for club racing.
    This should be taken care of shortly. A weight adjustment would need to go through the letter process.
    John
  3. #402
    Toronto
    Liked: 654
    John
    Letter submitted to increase weight by 10 lbs, the approx difference in weight the radial adds compared to a similar sized bias ply from what I understand.
    Tracking Number: #18229
    Steve Bamford
  4. #403
    Liked: 170
    Default Letter sent
    #18230 sent in asking for weight increase by 10 lbs
  5. #404
    Big Canoe, GA
    Liked: 38
    Don't see a need for a weight increase. Leave it alone.
    Crossle 32F, Piper DF5 Honda
  6. #405
    Toronto
    Liked: 654
    Only reason for a weight increase is to keep weight inline where basically it was before. Some newer cars are built lighter then older cars and this helps keeps things in check. In the past, in series that have spec tire rules, I have seen them increase min weight when introducing a new tire that weighs more then previous spec tires.
    If you wish to leave it alone I'm not going to argue, I simply feel it fair for the entire class to simply bump it up a few lbs to avoid people spending more dollars to try to shed the extra weight they are now adding by running the spec tire.
    Steve Bamford
  7. #406
    South Carolina
    Liked: 713
    Anyone know the actual weight of the old and new tire?
    Swift DB-1
  8. #407
    Senior Member S. Frebert's Avatar
    Frederick, MD
    Liked: 74
    Does this mean we can set new Records at the track for FF?
    Hoping I can look forward to doing that hahahah (until it gets beaten!!)
  9. #408
    Contributing Member Mike Scanlan's Avatar
    New York
    Liked: 94
    11 lbs was the increase per set from last years pro tire to this years new radial
  10. #409
    South Carolina
    Liked: 713
    I thought last years pro tire was the same tire as the new spec tire. I was given 17 lb as weight for an R45, and the Hoosier website list the R60 at 16 fr / 18 rear. Anyone have different data?
    Swift DB-1
  11. #410
    Liked: 170
    Default I know the info is on the Hoosier site
    look at the F1600 tire information against R45 or R35 bias tire. 10 or 11 pounds as I recall
  12. #411
    Santa Fe, NM
    Liked: 25
    Default Vintage CF Tires
    Reawakening this thread. What tires are Vintage CF cars running in 2016? Is there any market for a new set of R35s?
    Frank C
  13. #412
    Liked: 1095
    Quote Originally Posted by Frank C View Post
    Frank C
    Hello Frank,
    I think it depends on the organization. Monoposto CF insists on treaded avons or dunflops. SVRA allows the same until midyear, then all on toyos.
    SCCA Regions each have their own rules.
    SoloII CM drivers would buy them for hot weather/abrasive courses.
There are currently 10 users browsing this thread. (0 members and 10 guests)
