Page 1 of 2 12 LastLast
Results 1 to 40 of 47
    Fairfield, CA
    Default Open Nose vs. Closed on Sports Racer Design
    All.
    Focus is on aero drag reduction, not downforce generation or reduction.
    Given:
    1) The radiator in the front of my sports racer is no longer required for cooling.
    2) Radiator is removed and air flow passing into the chassis/body will have little to no interference.
    3) Clear/clean flow into the driver's compartment.
    4) Most air flow exiting through the driver opening. Some exiting through normal body openings in rear of car.
    5) Radiator opening is small and air speed is low enough that flow through the driver opening will create only very small internal drag.
    4) No safety-related issues to comply with.
    5) Loss of down force from nose mounted splitter in front of radiator opening is not an issue.
    Again, focus on lowest drag design:
    Should I cover the opening to force air to flow around the sides and top of body, or, leave the hole open and let air flow through the body and out the driver opening?
    Liked: 3888
    I am not an aero expert, but it is generally accepted that air flowing through the car body usually creates what is called parasitic drag - i.e., the increased surface contact plus any twists and turns the air does inside the body results in more drag than keeping it on the outside.
  3. The following 5 users liked this post:
    Liked: 3950
    Maybe do a simple coast-down test? Run it up to 100mph, throw it in neutral and see how far you roll with the nose taped closed and not closed.
    YMMV
  5. The following 5 users liked this post:
    SoCal
    Liked: 102
    The masters of low drag vehicle design are competition sailplane creators. Next on the list are land speed racing streamliner racers. A lot can be learned from what they do and how they do it.
    A sudden expansion of an internal airflow path, caused by a rapid increase in cross section area, high-drag objects in the flow path, tight flow path curvature, or the lack of a smooth-walled internal duct, creates an airflow energy loss from flow separation. That energy loss adds drag to the car.
    If an internal airflow path is smoothly ducted all the way from entry to exit, the skin friction drag caused by the additional surface area exposed to airflow, also adds drag.
    Having said all of that, here is a brilliant statement that I read recently:
    One test is worth a thousand expert opinions.
    Fairfield, CA
    Thank you Gents for your well-considered responses.
    I test is in order!
  9. #6
    Liked: 2057
    First question to answer is this:
    What do the rules say about the ducting of air?
    Liked: 297
    seems like another test will be required!
    Fairfield, CA
    No rule issues with ducting through the driver's compartment.
    Quote Originally Posted by ReynardF1000 View Post
    What class and what sanctioning body?
    Woodstock, NY
    Liked: 81
    At one time,and I haven't' looked for a while, the rules said something to the effect of "any openings the bodywork have to supply air to a heat exchanger".
    My understanding was that the nicely sculpted bodywork deflecting air through the car around, say, the front wheels, was in fact illegal in the SCCA.
    Has this been changed or did I imagine or misunderstand?
  14. #11
    Contributing Member quartzracer's Avatar
    Chris why don't you post a photo of the bodywork you designed for the Kokopelli. Truly a work of art!
    Quote Originally Posted by ChristopherBernard View Post
    In certain classes of the SCCA air passing through forward facing openings in the body must flow through heat exchangers.
    The exact wording from one sports racing class is:
    "All forward facing openings must be connected to duct(s) connected to heat exchangers or brake cooling ducts. All air entering duct must pass through heat exchangers or be used to cool brakes and must not be used to generate aerodynamic downforce or any other purpose."
    Your interpretation may be different than mine and my opinion is worth nothing.
  17. #13
    Liked: 1003
    If I interpret that wording strictly and literally, it prohibits forward facing oipenings for driver cooling.
    Or am I missing something??
  18. #14
    Liked: 1003
    If I interpret that wording strictly and literally, it prohibits forward facing openings for driver cooling.
    What about forward facing openings to allow air into the engine compartment for cooling it and what about scoops.
    Boy I am really confused now??
    Sorry about double post. Thought I was editing my original
  19. #15
    Liked: 2057
    Ever thought of reading the relevant section of the rule book for that class? It's all in there.
    Read the rules?? No one except crazies do that.
  21. #17
    Liked: 297
    Quote Originally Posted by reynardf1000 View Post
    all.
    Given:
    1) the radiator in the front of my sports racer is no longer required for cooling.
    2) radiator is removed and air flow passing into the chassis/body will have little to no interference.
    3) clear/clean flow into the driver's compartment.
    4) most air flow exiting through the driver opening. Some exiting through normal body openings in rear of car.
    5) radiator opening is small and air speed is low enough that flow through the driver opening will create only very small internal drag.
    4) no safety-related issues to comply with.
    5) loss of down force from nose mounted splitter in front of radiator opening is not an issue.
    again, focus on lowest drag design:
    should i cover the opening to force air to flow around the sides and top of body, or, leave the hole open and let air flow through the body and out the driver opening?
    yes absolutely
  22. #18
    Fairfield, CA
    Hello Provamo.
    What are you basing your response on, please?
  23. #19
    Mn
    Liked: 202
    As others have stated, I highly recommend the coast down test or some comparitive track testing.
    The GCR can be intimidating. Check with the group you're racing with for the rules. I've had lots of help going thru tech
  25. #20
    Liked: 1480
    But I am a heat exchanger
  27. #21
    Is the air passing through you?
  29. #22
    Woodstock, NY
    Liked: 81
    Eric, thanks so much for the compliment! I would if I had the faintest idea how but that would also be hijacking the thread.
  30. #23
    It doesn't pass through a heat exchanger per se, it passes through tiny openings in the heat exchanger. My suit has those same openings, they are just much smaller and do aid in removing heat from my body
  32. #24
    Good thinking Daryl. I hope that someone does this and that someone else protests it. I want to see the tech guys deal with this one.
  34. #25
    Plantation, Florida
    Liked: 232
    Default Back in the day .........
    Or am I missing something?? ...........
    Lola 340/342/440
  35. #26
    Liked: 297
    whatever Lola wants Lola gets.................or was that Carl LOL
  36. #27
    Liked: 297
    seen this at he run-offs.........legality is determined tech/stewards
    that is where the rules are interpreted and enforced
    just consider the GCR, etc as a fairly comprehensive guide, not law
  37. #28
    Quote Originally Posted by Swift17 View Post
    Lola 340/342/440
    Actually the original question was about Sports Racers and the GCR quote I posted was also from the 2015 P2 Sports Racer rules and not FF rules, thus the quoted rule has no application to FF at all.
    But that enough on this dead horse.
  38. #29
    Fairfield, CA
    An open wheel car with a nose opening, no radiator and clear flow out through the driving compartment is a good comparison as well as a sports racer.
    Again;
    Open nose in high-pressure area with free flow inside the car, out through the driver opening. Better or worse drag than closing the high-pressure area, when down force is not in play?
    Horse is still alive.
  39. #30
    Liked: 297
    "......."CLEAR".... flow through the driving compartment"?
    this horse needs reshoeing
  40. #31
    Liked: 3888
    Default Another aspect...
    Something off the main issue in this thread, is the effect for road-racing cars in the rain. I once had my nose cone knocked off by a driver I was lapping in a downpour. So much water was blowing through the cockpit and up into my helmet that I could hardly see or breathe!
  41. #32
    Fairfield, CA
    Okay not perfectly clear, but no horseshoeing needed.
    Large expansion and slowing of airflow therefore very low resistance.
    Thanks for the nose missing in the rain. Obviously, much flow through the cockpit when not diverted!
  42. #33
    Liked: 3950
    I can think of a lot of reasons not to have it open into the cockpit...
    When racing in a field of cars there is an amazing amount of debri flying through the air. Tire rubber, gravel, parts of opposums, half-shafts, tail pipes, sand, etc (those are just the things I've experienced). just look at the leading edges of your A-arms after a season... sand blasted.
    I expect that leaving it open is going to create more drag from everything I've read.
    Maybe, only maybe, on a hillclimb/autocross car I might leave it open.
  43. #34
    Liked: 297
    "f" duct?
  45. #35
    West Union, IL USA
    Liked: 360
    Default Correct answer to the original post:
    Fill it. It makes the perfect spot for your "SCCA Club Racer" decal.
  46. #36
    Fairfield, CA
    Will a dead horse find its way through the opening?
    Thanks Gents!
  47. #37
    Senior Member tige00's Avatar
    arizona
    Liked: 49
    It sounds like you want to keep it open so keep it open and try it if rules allow. Otherwise test , test , test. Or you will never know
  48. #38
    San Jose Ca
    Liked: 88
    Or Test, Test, Test and know for sure!?
    Ben
  49. #39
    Red Neck Riveria, FWB, FL
    Liked: 105
    Default What is in a Name?
    Or, does anybody have a name for the front body section (non-wing) like on many Brabham F1s, others and of course the Novacar? The "goofy" looking white one in the middle was called the "Crab Claw"-- but is there any other name than, "That Nose-Thing?"
    Does the Novacar have a reference to it on a parts list that is "more descriptive?"
    Thanks and as always,
    Cheers - Jim
  50. #40
    Liked: 573
    I've often heard them called "sports car" noses. Some cars/models started life with them and later replaced them with front wings, like, around the 1970's?
